Topic: ARDUINO EXE DOESNT RUN (Read 2248 times) previous topic - next topic
SERET
Please someone help me.
I have     1 pc windows 7.  2 pc wuindows  vista.  Arduino exe doesnt run on  noone of 3 pcs.
I dont know what to do. My  MEGA 2560 is ok on pc.
I  do doble click  on arduino exe 1.0.2 , open a foto for 1 secont  ,  and  desapear the foto.
I tried   with other arduinos software.
Arduino 0016 and  earlier are  runing  normal.
Many thanks
Coding Badly
Try this...
• Open Explorer (the thing used to browse the harddrive)
• Navigate to your Roaming folder.  On my computer, the following "address" works...
[font=Courier New]%APPDATA%[/font]
• From there, navigate into the Arduino folder.  The full path is probably something like this...
[font=Courier New]C:\Users\{YourUserName}\AppData\Roaming\Arduino[/font]
• Rename the [font=Courier New]preferences.txt[/font] file
• Try to run Arduino 1.0.2
SERET
Thanks a lot.
I try this.
I find    C:\Users\????????\AppData\Roaming
In (roaming),     i dont find (arduino).
  You tell me to rename (preferences txt) I dont understunt this.
SERET
I  dont know if  i did someting  wrong.
You tel me.
1.I  was  dounload the  (arduino 1.0.2)
2.I open the file
3.I open the (arduino exe)
And nothing h?ppen.
Now the file (arduino 1.0.2) is  on desktop
Coding Badly
Quote
Bummer.  The problem must be something else.  (Or the [font=Courier New]preferences.txt[/font] file is somewhere else on your computers.)
Quote
I vaguely recall that newer Arduino versions sometimes won't start because of a problem with an older [font=Courier New]preferences.txt[/font] file.  If that's the problem you are facing, renaming the file will allow the newer version to run.
nickgammon
Download 1.0.1 is my suggestion.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
SERET
I  already have try ( as i said before) all olders versions.
This is happening to all my 3 pcs.
The version 0016 and olders are runing ok.
nickgammon
Quote
You said you tried 1.0.2 and 0016 and earlier.
That isn't 1.0.1.
SERET
The arduino 1.0.2 is new
Earlier i had 1.0.1
Before posting i dounload all versions one by one and try with these
Now i have some of theme in one file on desktop
Thanks a lot for  your attention
SurferTim
Quote
If you moved the file, then it will not work. The arduino.exe file needs to be in the directory it was installed in. If you want an icon on the desktop, you must create a shortcut and move it to your desktop.
SERET
When i dounload the file,i did double click to (exe) for instal ,nothing happen.
I do this again and again many times. This is the problem.
SurferTim
There isn't really an "install" last I checked. You unzip it into a local directory, and it is installed. I just installed v1.0.2 on my Windows XP box just now, and it downloaded, unzipped, and ran fine.
What version of Windows are you using? I hear Windows 8 has a security function that you must set to run executable programs downloaded from the internet.
SERET
I have vista  home premium and my other pc has windows 7
eried
Just double click this: http://arduino.cc/forum/index.php/topic,118440.0.html
My website: http://ried.cl
SERET
I did  this.( http://arduino.cc/forum/index.php/topic,118440.0.html ). It works.
I am very hapy.Thank you very much  ERIED.
Becose i am new on arduino tell me please.  I Have MEGA 2560. I  conect it only with usb.
  Do I need a programmer ?   Or not ?
