Author Topic: ARDUINO EXE DOESNT RUN  (Read 780 times)
Please someone help me.
I have     1 pc windows 7.  2 pc wuindows  vista.  Arduino exe doesnt run on  noone of 3 pcs.
I dont know what to do. My  MEGA 2560 is ok on pc.
I  do doble click  on arduino exe 1.0.2 , open a foto for 1 secont  ,  and  desapear the foto.
I tried   with other arduinos software.
Arduino 0016 and  earlier are  runing  normal.
Many thanks
Dallas
Shannon Member
Try this...
• Open Explorer (the thing used to browse the harddrive)
• Navigate to your Roaming folder.  On my computer, the following "address" works...
%APPDATA%
• From there, navigate into the Arduino folder.  The full path is probably something like this...
C:\Users\{YourUserName}\AppData\Roaming\Arduino
• Rename the preferences.txt file
• Try to run Arduino 1.0.2
Thanks a lot.
I try this.
I find    C:\Users\ΤΣΕΡΕΤΗΣ\AppData\Roaming
In (roaming),     i dont find (arduino).
  You tell me to rename (preferences txt) I dont understunt this.
I  dont know if  i did someting  wrong.
You tel me.
1.I  was  dounload the  (arduino 1.0.2)
2.I open the file
3.I open the (arduino exe)
And nothing hαppen.
Now the file (arduino 1.0.2) is  on desktop
Dallas
Shannon Member
Bummer.  The problem must be something else.  (Or the preferences.txt file is somewhere else on your computers.)
I vaguely recall that newer Arduino versions sometimes won't start because of a problem with an older preferences.txt file.  If that's the problem you are facing, renaming the file will allow the newer version to run.
Melbourne, Australia
Shannon Member
Lua rocks!
Download 1.0.1 is my suggestion.
I  already have try ( as i said before) all olders versions.
This is happening to all my 3 pcs.
The version 0016 and olders are runing ok.
Shannon Member
Lua rocks!
You said you tried 1.0.2 and 0016 and earlier.
That isn't 1.0.1.
The arduino 1.0.2 is new
Earlier i had 1.0.1
Before posting i dounload all versions one by one and try with these
Now i have some of theme in one file on desktop
Thanks a lot for  your attention
Miramar Beach, Florida
If you moved the file, then it will not work. The arduino.exe file needs to be in the directory it was installed in. If you want an icon on the desktop, you must create a shortcut and move it to your desktop.
When i dounload the file,i did double click to (exe) for instal ,nothing happen.
I do this again and again many times. This is the problem.
There isn't really an "install" last I checked. You unzip it into a local directory, and it is installed. I just installed v1.0.2 on my Windows XP box just now, and it downloaded, unzipped, and ran fine.
What version of Windows are you using? I hear Windows 8 has a security function that you must set to run executable programs downloaded from the internet.
I have vista  home premium and my other pc has windows 7
Chile
Just double click this: http://arduino.cc/forum/index.php/topic,118440.0.html
My homepage/blog: http://erwin.ried.cl
I did  this.( http://arduino.cc/forum/index.php/topic,118440.0.html ). It works.
I am very hapy.Thank you very much  ERIED.
Becose i am new on arduino tell me please.  I Have MEGA 2560. I  conect it only with usb.
  Do I need a programmer ?   Or not ?
