Topic: Tests performed with the DIY speedometer based on Fritzing+Arduino (Read 910 times) previous topic - next topic
TLERDRDEN
Hello;
Some weeks ago I posted some doubts related to the design of a speedometer that I was doing based on Arduino and Fritzing.
What I've done in this project:
-   Design of a speed sensor  wich consists of: Reed Switch+Resistor+Plug, using Fritzing.
-   Arduino Code- I will share it in my blog-.
-   Selection of Components and mount: Power source, mounting jack connectors, cables, etc.
Compounds of the project:
-   9V Battery + Jack connector.
-   Arduino R2.
-   LCD Shield from DFRobot.
-   Speed sensor -designed with Fritzing-.
-   Others: Cables, connectors, etc.
This weekend I've already mounted on the bycicle the speed sensor and I've performed the early tests of the prototype. Here I put you the conclusions I've arrived:
Conclusions after the first test:
-   Improper contrast of the LCD screen. In the day light I can't see the characters of the screen. . In the performed tests the contrast has been also adjusted using the 10k? potentiometer but the visualization hasn't bécome so good.
-   I need a box where I can put the electronics.
-   The speed calculated by the microprocessor is too high. I guess that, modifying the code I will solve the problem - I will share my experience when I do it-.
-   The speed sensor works properly. However, I would improve the design, some comments:
o   The connection between the 3 cables -VCC / GND /Signal- I've done is soldering
o   1 cable (with 3 wires), better than 3 cables.
o   The circuit is outdoors. How could I cover it in order to do the sensor more resistant?
Therefore, here I put my questions for you:
-   As the LCD can't show the data properly in the day light. ¿What options do I have in the market - other technologies I mean-?
-   What software or other tools exist in order to design a box where I can put the electronics - basically the arduino, batteries and LCD-. Do you know industrial designers who can help me? Do you have any other ideas?
-   What options do I have in order to improve the speed sensor design, because it must be more resistant and easier to mount it.
-   What cable -3 in 1- would suit to this application?
Finally, I attach you the link where I have posted photos and comments of the project:
http://opironelectronics.blogspot.com.es/
Thanks in advance,
Anton
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
