Topic: Help using templates. (Read 3292 times) previous topic - next topic
DigitalJohnson
Nov 26, 2012, 12:53 pm Last Edit: Nov 26, 2012, 02:21 pm by DigitalJohnson Reason: 1
I'm trying to learn templates. :~ I've been reading a tutorial (Web page: http://www.codeproject.com/Articles/257589/An-Idiots-Guide-to-Cplusplus-Templates-Part-1 ). I copied an example from the tutorial but when I compile I get an error: 'TYPE' does not name a type, it highlights the error line as the first line, the line declaring the template.
Here's my sketch:
Code: [Select]
template<class TYPE>
TYPE Add(TYPE n1, TYPE n2)
   TYPE result;
   result = n1 + n2;
   return result;
   float x = 2.1;
   float y = 5.6;
   Serial.println(Add(x, y));
I thought the purpose of using a template (in this case) was so you didn't have to (explicitly) name a type. Can someone help me understand why I'm getting an error and the author of the tutorial (obviously) is not.
Thanks for your time,
DJ
DigitalJohnson
pYro_65
This is the IDE's fault, add the function prototype above the definition:
Code: [Select]
template<class TYPE> TYPE Add(TYPE n1, TYPE n2);
The IDE otherwise generates a prototype as:
Code: [Select]
leaving TYPE as undefined.
Forum Mod anyone?
https://arduino.land/Moduino/
DigitalJohnson
@pYro_65
I did figure out it was the IDE when it compiled using atmel studio. I had no idea how to get it to compile in the arduino IDE. I'll give this a try and let you know if it works for me. ;)
Thanks,
DJ
DigitalJohnson
DigitalJohnson
Nope. Same error: 'TYPE' does not name a type.
My sketch:
Code: [Select]
    TYPE result;
    result = n1 + n2;
    return result;
    float x = 2.1;
    float y = 5.6;
The error is at line 3. I was mistaken in my first post. The error was in the same place as indicated this time. I'm using a Mega1280 & IDE1.0.2. Any further thoughts/ideas. As I stated above I can get this to compile using atmel studio. It's just easier to do short code tests using the arduino IDE.
Thanks again for any help,
DJ
DigitalJohnson
PaulS
You may need to put your template function declaration in a separate header file, and include it in the sketch.
By the time you get to templates, this should be second nature.
nickgammon
Code: [Select]
    TYPE result;
    result = n1 + n2;
    return result;
Yes, but the function above does not match the prototype.
This compiles under IDE 1.0.2:
Code: [Select]
template<typename TYPE> TYPE Add(TYPE n1, TYPE n2);
    TYPE result;
    result = n1 + n2;
    return result;
It won't compile under 1.0.1 because that doesn't honour function prototypes when the IDE tries to generate its own.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
DigitalJohnson
Thanks Nick, that worked. I didn't know the template was part of the function declaration.
Quote
Does this mean I'm in over my head?... You're probably right. :P
Thanks for the replies,
DJ
DigitalJohnson
WizenedEE
Templates are fun, especially when you start programming with them:
Code: [Select]
template <unsigned long n> struct Factorial {
    static const unsigned long val = Factorial<n-1>::val * n;
template <> struct Factorial <0> {
    static const unsigned long val = 1;
    Serial.print(" 3! = "); Serial.print(Factorial<3>::val);
    Serial.print(" 4! = "); Serial.print(Factorial<4>::val);
    Serial.print(" 6! = "); Serial.print(Factorial<6>::val);
    Serial.print("20! = "); Serial.print(Factorial<20>::val);
    Serial.print("30! = "); Serial.print(Factorial<30>::val);
void loop(){}
DigitalJohnson
@WizenedEE
You forgot Serial.begin();
To be honest I have no idea how your example works. :~ I'm not that good at coding yet. But thanks for it anyway. I'll study it some more and see if I can figure it out.
DJ
DigitalJohnson
nickgammon
He's trying to send the compiler into a loop. :P
PaulS
Quote
I think that that example is a bit contrived, since factoral doesn't make sense for anything other than ints.
What would the function body look like for:
Code: [Select]
template <String> struct Factorial
    Serial.print(" Joe! = "); Serial.print(Factorial<"Joe">::val);
void loop(){}
WizenedEE
Quote
The template's parameter type is unsigned long, not class or typename. It's just a way to shift the processing from the arduino to the compiler.
