Inland Empire, California, US
Offline
Full Member
« on: November 21, 2012, 03:51:16 pm » |
I am trying to build a 5v 3amp switching regulator and things keep going awry. My latest failure involves an inductor that is obviously scorched (for the second time now). The voltage now oscillates between 5 and 6 volts. Before I go pop in another inductor, I was wondering if someone could clue me in to some of the pitfalls of this circuitry. What might be causing the inductor to burn up? Also, D1 is a pretty hefty diode which looks suitable for a three amp circuit. To contrary, the 100uH inductor (which I am assuming handles the load output) has some fairly thin leads- seems suspect to me. I am slightly ashamed to say but for a circuit that costs about $0.75, I have destroyed more than $2 in parts trying to get it right. Any suggestions ? (besides using a 7805)
Logged
Manchester (England England)
Offline
Brattain Member
Solder is electric glue
« Reply #1 on: November 21, 2012, 04:00:55 pm » |
You need to know the rated value of the inductor, that will tell you how much current you can take. yes it takes all the current. It needs to be rated so your maximum current is not more than 70% of the rating.
Switch mode power supplies are very sensitive to circuit layout, without a good PCB it is almost impossible to get a reproducible circuit. Even with a good PCB layout I have seen many professional engineers take two or three goes at getting it stable under all current draws.
That is why you are better off buying a ready built module for this sort of thing.
Logged
Global Moderator
Boston area, metrowest
Offline
Brattain Member
Available for Design & Build services
« Reply #2 on: November 21, 2012, 04:06:02 pm » |
Are you following this?
C. Identify the inductor value from the inductor code, and select an appropriate inductor from the table shown in Figure 3. Part numbers are listed for three inductor manufacturers. The inductor chosen must be rated for operation at the LM2576 switching frequency (52 kHz) and for a current rating of 1.15 × ILOAD. For additional inductor information, see the inductor section in the Application Hints section of this data sheet.
If you are smoking the inductors, I would hazard to guess you have not selected a hefty enough rated part.
Logged
Offline
Full Member
« Reply #3 on: November 21, 2012, 04:19:18 pm » |
Wow, I didn't even take a look at the rest of that data sheet. It makes a little more sense now.
Logged
Australia
Offline
Full Member
« Reply #4 on: November 22, 2012, 05:46:48 pm » |
This link will help you determine the relavant values. http://www.daycounter.com/LabBook/BuckConverter/Buck-Converter-Equations.phtmlFor Buck Converters, the Inductor must be able to handle the peak switching current without saturating. The Peak Switching current is higher than the load current.
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #5 on: November 22, 2012, 06:43:21 pm » |
You'll get better efficiency if you leave more of a margin - partly due to lower copper losses, partly due to smaller hysteresis loop.
Logged
Anaheim CA.
Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
« Reply #6 on: November 22, 2012, 11:48:06 pm » |
I am incredibly lazy, I just find one that works as I like then "Copy It"... Works every time. Even my first very first bread boarded switchers all worked. There is a "Suggested" layout from almost every Mfr that is a great guide... just don't deviate too far.
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Belgium
Offline
Full Member
« Reply #7 on: November 23, 2012, 05:12:58 am » |
I have built a couple of boards with the LM2576. I used a 3A Schottky diode and an inductor rated for 3A. The output capacitor also needs to be of the low ESR type. I'm using some expensive Panasonic capacitors. Even with a 2A load the voltage hardly fluctuates, I measured a peak to peak voltage of 240mV with my oscilloscope. That's within spec.
Logged
Offline
Full Member
« Reply #8 on: November 23, 2012, 03:32:32 pm » |
Any suggestions for where to find said inductor? Shipping from Mouser is like 3-4 times the cost of the part itself. I think Digikey is even more. I found some inductors on ebay but they skimp on specs. Docedison, I am about 30 minutes from Anahiem; do you have local place you order from?
« Last Edit: November 23, 2012, 03:37:27 pm by seanz2003 »
Logged
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #9 on: November 23, 2012, 03:48:25 pm » |
Well for $1.53 and free shipping you could buy one of the below and pull the inductor from it for your regulator. Or would you find that much too ironic? http://www.ebay.com/itm/251066005460?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649Lefty
Logged
Belgium
Offline
Full Member
« Reply #10 on: November 23, 2012, 04:34:12 pm » |
I bought some through the hole 3A 100µH inductors on Ebay.
Logged
Samplefinger
Offline
God Member
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
« Reply #11 on: November 23, 2012, 08:17:36 pm » |
Any suggestions for where to find said inductor? Shipping from Mouser is like 3-4 times the cost of the part itself. I think Digikey is even more. I found some inductors on ebay but they skimp on specs. Docedison, I am about 30 minutes far from Anahiem; do you have local place you order from?
I wonder if anyone sells a good inductor kit (like you can find for resistors and capacitors). If I was going to be working heavily with inductors I would be thinking about getting a wide-range value kit for experimentation purposes just like the resistor and cap kits that I already have - three big ones each for electrolyic/ceramic/polyester(my newest) and 1 watt, 1/4 watt, and 1/2 watt resistors (Joe Knows) and a couple of bulk packs too.
« Last Edit: November 23, 2012, 09:42:27 pm by JoeN »
Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
