Topic: Zener diode protection question (Read 983 times) previous topic - next topic
pico
I've got a board that I'd like to protect some 3V3 peripherals from accidently getting fried by 5V from some bonehead (might be me) misconfiguring jumpers. What's a good value for the current limiting resistor to put behind the zener to ground? 50 Ohms? I'm thinking 3V3 rail -> zener -> resistor -> gnd.
WiFi shields/Yun too expensive? Embeddedcoolness.com is now selling the RFXduino nRF24L01+ <-> TCP/IP Linux gateway: Simpler, more affordable, and even more powerful wireless Internet connectivity for *all* your Arduino projects! (nRF24L01+ shield and dev board kits available too.)
Lavan
oric_dan
Actually, I'd think you could get by with just using nominal 330 ohms series Rs in the
I/O lines. That will limit the max current into the pins to (5V - 3.3V)/330 = 5 mA,
which will probably not overwhelm the built-in clamping protection diodes on the I/O
lines.
Grumpy_Mike
#3
Nov 24, 2012, 10:02 am Last Edit: Nov 24, 2012, 08:22 pm by Grumpy_Mike Reason: 1
Not sure that is the right place. The Zener goes from input to ground, the resistor goes from input to what you are connecting it to. A value of 330R is good as that limits the current to 10mA. The cases where you made the pin an output, set it high, and then had a switch short it out to ground.
xvjeko
also pay attention to zener diode temperature characteristics  ]:D
