Loading...
Pages: [1]   Go Down
Author Topic: DO I NEED A PROGRAMMER for MEGA 2560 ?  (Read 360 times)
Offline Offline
Newbie
View Profile
Helo every one. I just get  an arduino  mega  2560 .
  Do I need a programmer for uploading the program  ? Or not ?
Please tell me.  I am just a beginer with these all.
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
No, you don't have to employ a programmer, you can write the code yourself.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
no if you have a arduino mega it should have the bootloader installed, just select it from the boards menu and off you go
AWOL the question was to upload not create, very paulS of you  smiley-mad
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
That's Mr PaulS to you good sir. He is very case sensitive about such things.  smiley-wink
Lefty
Logged
Offline Offline
Newbie
View Profile
I conect the boad arduino mega 2560 only with usb.
I open  the program:     ( Arduino erg 1.0.2)
I open an example. I do compile. Is ok.
I do upload.
And now its write: Done uploading. OK .       (It can see the board in com 14. OK)
But : with red letters  writes:avrdude. exe:cant find programmer id wiring valid programmers are: .......
       On TOOLS:  I  chooce:   Programmer: Arduino as isp .  (is it ok?)
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
No. You should just choose Board, then "Arduino Mega 2560 or Mega ADK".
Logged
Offline Offline
Newbie
View Profile
I do upload.
No that's wrong. I use "AVRISP mkII" as programmer (which was the default when I installed).
As I have understood "Arduino as ISP" is used when you want to use your connected arduino to upload onto anther arduino (one perhaps custom built without USB).
So select that, change to "Arduino MEGA 2560 or ADK" under Tools->Board. And if it doesn't work, verify that the COM port used under Tools->Serial Port is actually the one used by your arduino, which you can find in device manager if your using windows.
Logged
Pages: [1]   Go Up
Print
Jump to:
