Author Topic: LCD shield - understand the mapping between Arduino and shield pins  (Read 382 times)
Hi.
I hope you can see the image I have attached.
I bought a LCD shield, compatible with the DFRobot LCD Keypad Shield. Then I attached this shield to my Arduino Uno board.
I was trying to figure out how to access the Arduino pins through the shield, therefore I make a sketch that makes a led on digital pin 3 blink.
The system works if I connect the jumper wire to the spot marked with A in the picture, as expected, as that is the pin directly inserted into the Arduino header.
Then, I tried to attach the wire to the hole marked with B, as that is next to A, but the system didn't work. I had to insert the jumper wire as shown in the picture.
To me, that is totally counterintuitive as the hole I am using is next to pin 4 of Arduino, not pin 3.
Am I missing something? How could I have anticipated that? Is there a standard for how shields map Arduino pins?
Thanks a lot for your help!
Dan
« Last Edit: November 23, 2012, 04:43:09 pm by dan_plan » Logged
Central MN, USA
Where did you buy that shield? Does the seller provide a schematic?
Thanks liudr for your help.
I bought it on eBay from a supplier based in Hong Kong.
Yes, I found the schematics - I have attached it.
But I can't find it in there how I could find out about the issue I am talking about - don't you need the PCB layout to see that? - sorry I am a newbie.
Western New York, USA
That's more like a wiring diagram than a schematic (regardless of how they name the file).
According to that diagram, near the upper left corner, Arduino digital pin 3 (D3) is connected to pin 4 of J5 on the shield.
... don't you need the PCB layout to see that?
A photo of the shield might provide the information.
Don
« Last Edit: November 23, 2012, 07:39:04 pm by floresta » Logged
That looks more like a "Cytron LCD Keypad Shield for Arduino" but D3 goes to pin 4 of J5 on that board as well.
http://www.cytron.com.my/usr_attachment/LCDKeypad%20Shield%20SCH.pdf
Don
Central MN, USA
Apart from the pin layout, you should solder some female pins on the board to have some reliable connections.
