Topic: ATtiny45 TinyDebugSerial wont compile (Read 4161 times) previous topic - next topic
123tcpip
I'm having a compiling issue with TinyDebugSerial
I have searched the forums but can't seem to find the answer (this was the closest, http://arduino.cc/forum/index.php/topic,123388.0.html)
I  can get the SoftwareSerial working fine but I can't get TinyDebugSerial to compile.
The error is
tiny_serial:5: error: 'TinyDebugSerial' does not name a type
tiny_serial.cpp: In function 'void setup()':
tiny_serial:9: error: 'mySerial' was not declared in this scope
tiny_serial.cpp: In function 'void loop()':
tiny_serial:15: error: 'mySerial' was not declared in this scope
tiny_serial.cpp: At global scope:
tiny_serial:20: error: function definition does not declare parameters
I have the arduino tiny library installed under hardware and TinyDebugSerial.h is in there
I'm convinced this an error on my MAC rather than an arduino issue.
Can anyone confirm if this compiles please.
The code is this.
#include <TinyDebugSerial.h>
// Definitions
#define rxPin 2
#define txPin 0
TinyDebugSerial mySerial = TinyDebugSerial();
  mySerial.begin(9600);
   mySerial.print("test");
Erni
#1
Nov 24, 2012, 01:27 pm Last Edit: Nov 24, 2012, 01:32 pm by Erni Reason: 1
If you use this core:
http://code.google.com/p/arduino-tiny/ the TinyDebugSerial is part of the core.
Example
Serial.println(" Loop\n");
You can use baud rates 9600, 38400 and 115200
The TX pin is PB3
Another possibility, is to use TinyISP. This is much easyer, because you don't have to swap connections from programmer to serial/usb connectors.
http://arduino.cc/forum/index.php/topic,123388.30.html
123tcpip
Erni
As always thanks for the response.
I found the issue and this may be useful to others.
When I extracted the http://code.google.com/p/arduino-tiny/ I created the directory "hardware" and copied the folder into it and closed and reopened Arduino.
The problem was MAC OSX created a folder called "arduino-tiny-0100-0015" with the Tiny library sat inside (folder name is the zip name)
e.g
hardware/arduino-tiny-0100-0015/arduino-tiny/tiny etc....
However when I restarted  and checked under Tools>Board none of the Tiny Library boards where there.
So I dropped the Library down one level
e.g
hardware/arduino-tiny/tiny etc....
Restarted and now it all works fine.
I assume there is some limit on the amount of directories before Arduino stops looking?
Also for those who get garbled text when they get this working I haven't been able to get any of my Uno or Due boards to display clear text so i have just hooked up and FTDI (USB to Serial board) and it works fine.
Has anybody else had success using the Uno board (pin0) as the RS232 interface?
Enri
Again thanks for the prompt in the right direction.
Coding Badly
Has anybody else had success using the Uno board (pin0) as the RS232 TTL-serial interface?
Yes but, if you use an Arduino as the programmer, there is an easier way.  Start reading about here...
http://arduino.cc/forum/index.php/topic,123388.msg930061.html#msg930061
123tcpip
Coding Badly
Thanks for the reply & this look likes the ideal solution.
I had a read then downloaded the master and dropped it into the library as TinyISP (MAC OSX IDE 1.01)
If I compile I get a lot of errors, before I continue  I assume it works with 1.01?
TinyISP/KnockBangParser.cpp.o: In function `TinyDebugKnockBangParserClass::process()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/KnockBangParser.cpp:51: multiple definition of `TinyDebugKnockBangParserClass::process()'
KnockBangParser.cpp.o:KnockBangParser.cpp:51: first defined here
TinyISP/KnockBangParser.cpp.o:/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/KnockBangParser.cpp:51: multiple definition of `TinyDebugParser'
TinyISP/TinyISP_AispLED.cpp.o: In function `AispLEDClass::setMode(AispLEDClass::mode_t)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_AispLED.cpp:94: multiple definition of `AispLEDClass::setMode(AispLEDClass::mode_t)'
TinyISP_AispLED.cpp.o:TinyISP_AispLED.cpp:94: first defined here
TinyISP/TinyISP_AispLED.cpp.o: In function `AispLEDClass::update()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_AispLED.cpp:108: multiple definition of `AispLEDClass::update()'
TinyISP_AispLED.cpp.o:TinyISP_AispLED.cpp:108: first defined here
TinyISP/TinyISP_AispLED.cpp.o: In function `AispLEDClass::flash()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_AispLED.cpp:77: multiple definition of `AispLEDClass::flash()'
TinyISP_AispLED.cpp.o:TinyISP_AispLED.cpp:77: first defined here
TinyISP/TinyISP_AispLED.cpp.o: In function `AispLEDClass::error()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_AispLED.cpp:66: multiple definition of `AispLEDClass::error()'
TinyISP_AispLED.cpp.o:TinyISP_AispLED.cpp:66: first defined here
TinyISP/TinyISP_AispLED.cpp.o: In function `AispLEDClass::begin(unsigned char)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_AispLED.cpp:53: multiple definition of `AispLEDClass::begin(unsigned char)'
TinyISP_AispLED.cpp.o:TinyISP_AispLED.cpp:53: first defined here
TinyISP/TinyISP_AispLED.cpp.o:/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_AispLED.cpp:94: multiple definition of `StatusIndicator'
TinyISP/TinyISP_Monitor.cpp.o: In function `monitor_run(unsigned char&)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_Monitor.cpp:123: multiple definition of `monitor_run(unsigned char&)'
TinyISP_Monitor.cpp.o:TinyISP_Monitor.cpp:123: first defined here
TinyISP/TinyISP_Programmer.cpp.o: In function `programmer_toggle_hold_in_reset()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_Programmer.cpp:820: multiple definition of `programmer_toggle_hold_in_reset()'
TinyISP_Programmer.cpp.o:TinyISP_Programmer.cpp:820: first defined here
TinyISP/TinyISP_Programmer.cpp.o: In function `programmer_error_occurred()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_Programmer.cpp:857: multiple definition of `programmer_error_occurred()'
TinyISP_Programmer.cpp.o:TinyISP_Programmer.cpp:857: first defined here
TinyISP/TinyISP_Programmer.cpp.o: In function `programmer_release_target_from_reset()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_Programmer.cpp:829: multiple definition of `programmer_release_target_from_reset()'
TinyISP_Programmer.cpp.o:TinyISP_Programmer.cpp:829: first defined here
TinyISP/TinyISP_Programmer.cpp.o: In function `programmer_hold_target_in_reset()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_Programmer.cpp:852: multiple definition of `programmer_hold_target_in_reset()'
TinyISP_Programmer.cpp.o:TinyISP_Programmer.cpp:852: first defined here
TinyISP/TinyISP_Programmer.cpp.o: In function `programmer_reset_target()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_Programmer.cpp:834: multiple definition of `programmer_reset_target()'
TinyISP_Programmer.cpp.o:TinyISP_Programmer.cpp:834: first defined here
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_Programmer.cpp:820: multiple definition of `param'
TinyISP/TinyISP_Programmer.cpp.o: In function `programmer_process_command(unsigned char)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_Programmer.cpp:689: multiple definition of `programmer_process_command(unsigned char)'
TinyISP_Programmer.cpp.o:TinyISP_Programmer.cpp:689: first defined here
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_Programmer.cpp:820: multiple definition of `programmer_active'
TinyISP/TinyISP_SPI.cpp.o: In function `spi_begin()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_SPI.cpp:67: multiple definition of `spi_begin()'
TinyISP_SPI.cpp.o:TinyISP_SPI.cpp:67: first defined here
TinyISP/TinyISP_SPI.cpp.o: In function `spi_end()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_SPI.cpp:102: multiple definition of `spi_end()'
TinyISP_SPI.cpp.o:TinyISP_SPI.cpp:102: first defined here
TinyISP/TinyISP_SPI.cpp.o: In function `spi_send':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_SPI.cpp:120: multiple definition of `spi_transaction(unsigned char, unsigned char, unsigned char, unsigned char)'
TinyISP_SPI.cpp.o:TinyISP_SPI.cpp:120: first defined here
TinyISP/TinyISP_SPI.cpp.o: In function `spi_transaction2(unsigned long)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/TinyISP/TinyISP_SPI.cpp:183: multiple definition of `spi_transaction2(unsigned long)'
TinyISP_SPI.cpp.o:TinyISP_SPI.cpp:183: first defined here
Coding Badly
It's a sketch not a library.  Move it up one directory level (move it to the sketchbook directory).
Yes (just verified).
dc42
Are there any instructions for installing that core? I couldn't find any.
Erni
Yes, it is in the readme.txt file
123tcpip
Coding Badly
FYI I moved the sketch and it compiled OK, Thanks.
Also the README is Zero Byte
Coding Badly
Excellent.  You are welcome.
Thank you for letting me know about the possible problem.
I have not taken the time to compose a README and Github requires one.
dc42
I did find a readme file after more searching, it was in one of the subdirectories of the zip. I was expecting to find documentation on the github page or in the root directory of the zip, which is why I didn't find it initially. However, after trying another attiny core (from MIT I think) and being alarmed by the compiler warnings that it evoked, I decided to use AVR Studio 6 instead. I didn't want unnecessary port drivers cluttering up the memory anyway, so I think this was a good choice for me.
123tcpip
Coding Badly
The Sketch works perfectly, this will certainly save some time.
Thanks for the great work.
Rob
Coding Badly
Excellent.
If you like Tiny Debug Serial + Serial Relay you'll really like Knock-Bang!  All the benefits of Serial, faster more reliable communications, less Flash, and uses a pin already connected to the Uno.  It's actually small enough to be useful with the ATtiny13 processor.
Thanks!
