Loading...
Pages: [1]   Go Down
Author Topic: 3.3V output only giving 2.55V [solved]  (Read 239 times)
Offline Offline
Newbie
View Profile
Hi Guys
Thought this would be the most appropriate place to post this as I think it's a hardware, not a software/project issue.
I'm on windows 7, I have the arduino uno R3 plugged into USB only, and have a problem with the voltage from the 3.3V power output.
I noticed it while calculating temperature for a project I was doing when it was telling me 8 degrees instead of about 20. I have now traced the problem to the 3.3V power output.
It's only giving 2.55V according to the following code:
Quote
  int therm0 = analogRead(A0);                       //1. input on Analog pin 0
  float volt0 = therm0 * (3.3 / 1023.0);             //2. conversion to Voltage
  Serial.println(volt0);                                     //3. Send voltage to Serial software display
This should be 3.3V right? do I need an external power source to achieve the full 3.3V?
- Heim
« Last Edit: November 25, 2012, 03:47:06 am by Nick Gammon » Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Code:
I believe this would only be true if you had used Aref set to 3.3V.
As written, your code would be using the defualt setting of VCC, which would be ~5V.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
Code:
Thanks for the reply,
so when I have my 3.3V output plugged straight into my analogue output, it's actually putting out 5V? or am I missing something in the code?
Logged
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
The default Analog reference is to use VCC which is nominally 5V but in actuality is whatever is coming out of the USB port of the computer.  If you plugged the 3.3V output into the AREF pin of the arduino and told it to use it
Code:
analogReference(EXTERNAL);
It will be reading a voltage relative to whatever is going in the AREF pin (3.3 volts if you connect it to 3.3 Volts).
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
You have choices for what is used for the ADC reference.
If you do nothing, then the default is 5V/1023 = ~4.88mV per BIT.
So if you connect the 3.3V output to an analog input and take a reading, the result will be
3.3/.00488 = ~676
then 676*(5/1023) =  3.3V
Logged
Offline Offline
Newbie
View Profile
3.3/.00488 = ~676
Brilliant, Thanks for this! turns out it was just a coding error smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
