Topic: USI <-> SPI simple communication fails (Read 814 times) previous topic - next topic
acid
I'm trying to do a very simple 2 wire communication between ATMega328P(master) and ATTiny45(slave).
Here I'm configuring in 3 wire mode just for debugging.
Connections(Arduino pins):
ATMega328P   ATTiny45
  12  MISO - DO (MISO) 6
  11  MOSI - DI (MOSI) 5
  13   SCK - USCK      7
Here is master code on Arduino:
#include <SPI.h>
  SPI.begin();
int r;
  r = SPI.transfer(100);
  Serial.println(r);
  delay(2000);
Here is Slave code on ATTiny45:
#define F_CPU 16000000UL
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#define LED PB3
#define output_low(port,pin) port &= ~(1<<pin)
#define output_high(port,pin) port |= (1<<pin)
#define set_input(portdir,pin) portdir &= ~(1<<pin)
#define set_output(portdir,pin) portdir |= (1<<pin)
#define CTRL_PORT   DDRB
#define DATA_PORT   PORTB
#define CLK_PIN     PB2
#define DI_PIN      PB0
// Unused
#define DO_PIN      PB1
#define SS_PIN      PB1
volatile int d;
void init()
   CTRL_PORT |= _BV(DO_PIN);
   CTRL_PORT &= ~_BV(DI_PIN) | ~_BV(CLK_PIN) | ~_BV(SS_PIN);
   DATA_PORT |= _BV(DI_PIN) | _BV(CLK_PIN);
   USICR = _BV(USIOIE) | _BV(USIWM0) | _BV(USICS0) | _BV(USICS1);
   USISR = _BV(USIOIF);
   sei();
ISR(USI_OVERFLOW_vect)
   d = USIDR;
   USIDR = ~d;
void delay_ms( int ms )
   for (int i = 0; i < ms; i++)
      _delay_ms(1);
int main(void)
   init();
   set_output(DDRB, LED);
   d = 1000;
    while(1)
      output_high(PORTB, LED);
      delay_ms(d);
      output_low(PORTB, LED);
      delay_ms(d);
It appears interrupt never happens on Slave. I have some random numbers on Arduino (244, 100, 38, etc). LED blink frequency remains intact.
Something is wrong here..
