Topic: Loop a Sketch Section (Read 715 times) previous topic - next topic
ckeyes
Nov 24, 2012, 08:08 pm Last Edit: Nov 24, 2012, 08:22 pm by ckeyes Reason: 1
Having tried everything I could find or think of I'm hoping someone might be able to point me in the
right direction to set up some loops. Nothing I'm trying will work or compile.
Just trying to have sections of my test sketch loop when serial characters
are received, i.e. "a", "b" etc.
Here's what I have so far, without the loops of course.
 // initialize the digital pin as an output.
 // Pin 13 has an LED connected on most Arduino boards:
 pinMode(13, OUTPUT);
 // read the sensor:
 if (Serial.available() > 0) {
   char inByte = Serial.read();
   Serial.print("Command Received ");
   Serial.print(inByte);
   Serial.print("\n\r");
   switch (inByte) {
   case 'a':
      //while(Serial.available() == 0)  // while there are no new characters...
     digitalWrite(13, HIGH);   // set the LED on
   delay(500);              // wait for a second
    digitalWrite(13, LOW);    // set the LED off
     break;
   case 'b':
   delay(1000);              // wait for a second
     break;
   case 'c':
   delay(1500);              // wait for a second
     break;
     case 'd':
   delay(2000);              // wait for a second
     break;
   default:
     // turn all the LEDs off:
     for (int thisPin = 13; thisPin < 13; thisPin++) {
       digitalWrite(thisPin, LOW);
Goal is to have each section loop indefinitely till another serial command is received.
Really appreciate any pointers on this!
Thanks,
Carl
AWOL
#1
Nov 24, 2012, 08:20 pm Last Edit: Nov 24, 2012, 08:24 pm by AWOL Reason: 1
And how is it behaving now?
Apart from the really obvious one called "loop()", of course.
ckeyes
When it receives a command it executes the section fine, just need the section to loop
till it receives another input.
Thanks,
Carl
guix
Just do something like this, for example:
bool A_enabled;
bool B_enabled;
 // check for serial input etc
 switch ( inByte )
   case 'a' :
     A_enabled = !A_enabled; // invert this variable, so if you retype 'a' later it will be set to false
     B_enabled = false;
   case 'b' :
      B_enabled = !B_enabled;
      A_enabled = false;
 //end of serial input checks
 if ( A_enabled )
   DoSomethingA();
 else if ( B_enabled )
   DoSomethingB();
 ... etc etc
liudr
You need to rewrite your code to do the following logic:
have a state variable to indicate what state the machine is in, such as not received anything, received a, received b, etc. Assign it not received anything state first.
Build a while loop, check for serial in the beginning, decide whether the machine needs to change state.
Then have the switch case to do what a certain state does. Then as long as you are not receiving any new command, the state is kept and the action repeats itself.
BTW, guix's solution is good for only a couple of different states.
Arrch
#5
Nov 24, 2012, 08:56 pm Last Edit: Nov 24, 2012, 09:16 pm by Arrch Reason: 1
   switch (inByte) {
If you want it to continuously run the code, then you shouldn't have the code inside the if (Serial.available() > 0) part. Of course, you also couldn't destroy the inByte after each iteration of the loop() function, so it would need to be static or global.
billroy
Does this help with the concept?
case 'a':
while (!Serial.available()) {
break;
-br
ckeyes
case 'a':
break;
-br
Thanks a bunch everyone. This one seems to work perfectly! Now on to the fun stuff of getting
my LPD8806's programmed.
Carl
