Topic: Temperature sur LCD (Read 5016 times) previous topic - next topic
laurentjeuxlille
Dec 08, 2012, 06:09 pm Last Edit: Dec 09, 2012, 06:48 pm by Jean-François Reason: 1
Voila, mon premier montage, l'affichage de la temperature sur un LCD et sur le moniteur serie...
Un debut pour ma prochaine station météo...
Des bouts de codes recuperes dans les exemples, sur le net...
Modification apportées en fonction du capteur de temp que j'ai et qui differe de celui de l'exemple, un LCD pas cher et donc peu lisible...
Commentaires bienvenus.
Code :
Code: [Select]
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
//MCP9701E-TO Pin Variables
int sensorPin = 0; //the analog pin the MCP9701E's Vout (sense) pin is connected to
//the resolution is 19.5 mV / degree centigrade with a
//400 mV offset to allow for negative temperatures
* setup() - this function runs once when you turn your Arduino on
* We initialize the serial connection with the computer
   // set up the LCD's number of columns and rows:
 lcd.begin(16, 2);
 // Print a message to the LCD.
 lcd.print("Temperature");
Serial.begin(9600); //Start the serial connection with the computer
//to view the result open the serial monitor
void loop() // run over and over again
//getting the voltage reading from the temperature sensor
int reading = analogRead(sensorPin);
// converting that reading to voltage, for 3.3v arduino use 3.3
float voltage = reading * 5.0;
voltage /= 1024.0;
// print out the voltage
Serial.print(voltage); Serial.println(" volts");
// now print out the temperature
float temperatureC = (voltage - 0.4) * 51; //converting from 19.5 mv per degree with 400 mV offset
//to degrees ((volatge - 400mV) times 100)
Serial.print(temperatureC,1); Serial.println(" degres C");
// set the cursor to column 0, line 1
 // (note: line 1 is the second row
 lcd.setCursor(0, 1);
 // print the Temperature:
 lcd.print(temperatureC,1);
delay(5000); //waiting 5 seconds
fdufnews
Merci de faire partager ton expérience.
Juste 2 remarques:
1) les images plus petites (800x600 selon la charte du site)
2) le programme entre balises
Code: [Select]
     (bouton # dans la barre d'outils de la page de saisie des posts)
atlas2003
Salut
Félicitation pour ton premier montage.
Tu dis, LCD peu lisible. Sur ta photo, on dirait que le "backlight" n'est pas en fonction.
Est ce le cas?
laurentjeuxlille
#3
Dec 09, 2012, 06:30 pm Last Edit: Dec 09, 2012, 06:55 pm by laurentjeuxlille Reason: 1
Code: [Select]
Code :
 lcd.begin(16, 2);
voltage /= 1024.0;
laurentjeuxlille
Salut
Est ce le cas?
Bonne question pour le backlight... aucune idée en fait... j'ai juste un potentiometre 10k pour regler le texte, mais le backlight je ne sais pas. Peut etre une histoire de jumper au dos, j'ai vu ca dans le datasheet, mais ne sachant pas dans quoi je me lancais, je n'y ai pas touché. Une aide de ton côté ?
Merci
jfs
Tu n'as pas tout lu.....
Code: [Select]
laurentjeuxlille
#6
Dec 09, 2012, 06:35 pm Last Edit: Dec 09, 2012, 06:37 pm by laurentjeuxlille Reason: 1
Euh, si, le code est dans les quote... il me semble. La ref du ldc est LCD16216SBH si moyen de modifier le backlight, je suis preneur.
jfs
Pas lors de mon derniers message.....  :smiley-mr-green: elle est facile celle là...
Autrement c'est pas entre quote qu'il faut mettre, mais code le bouton avec # .... voilà, voilà  XD
laurentjeuxlille
je vais y arriver !
sinon une info, il me semble qu'il faut connecter les pin 15 et 16 pour utiliser le backlight...
jfs
Oui :
http://www.mon-club-elec.fr/pmwiki_mon_club_elec/pmwiki.php?n=MAIN.TechniquePreparationLCD
laurentjeuxlille
Yep, connection cathode/anode et  !!!!!!!!!!!!!!!!!! lumière.
Tout de suite on voit mieux.
Merci
jfs
C'est bientôt Nowelll...  XD
