Topic: Infrared send and recieve (Read 891 times) previous topic - next topic
papy08
Hello everyone,
I have a work project involving IR. I'm suppose to send and receive IR signal with the same arduino. For sending and reciving i'm using the IRremote library, an IR receiver and an IR transmitter.
The library works perfectly when i'm using one arduino to send, and another to receive.
But when I implement the code for both receiving and sendind, I blocks on sending. That's my code
Code: [Select]
#include <IRremote.h> // Include the library
int RECV_PIN= 11; //Pin of the receiver
IRrecv irrecv(RECV_PIN); // Start the reciever
decode_results results;
IRsend irsend;
int incomingByte=0;
void setup(){
  irrecv.enableIRIn(); // enables the reciver
void loop (){
  if(irrecv.decode(&results)){
    Serial.println(results.value,HEX); // decodes results
    irrecv.resume();
  if (Serial.available() > 0){
    incomingByte= Serial.read(); // if i send 1, start isend
      if(incomingByte=49){
        isend();
void isend(){
  cli();
  for (int i = 0; i < 3; i++) {
   irsend.sendSony(0xa90, 12); // Sony TV power code
   delay(40);
  sei();
Until I don't send 1 to the port com, it receives IR perfectly, but when I send 1 to com, it send an IR signal but does not stop sending it. I would like to send an IR signal for a given time then go back to receiving IR.
Do anyblody has an idea ? My work project is blocked until I find a solution.
Thanks in advance
IR receiver  : http://www.dfrobot.com/index.php?route=product/product&filter_name=ir%20receiver&product_id=351#.ULE3I4faU74
IR transmitter : http://www.dfrobot.com/index.php?route=product/product&filter_name=ir%20transmitter&product_id=355#.ULE484faU74
Arduino used : http://www.zartronic.fr/dfrduino-romeo-robotique-328-rev11-compatible-arduino-p-146.html
MarkT
Replace assignment:
Code: [Select]
by comparison:
Code: [Select]
      if(incomingByte == 49){
papy08
Replace assignment:
Code: [Select]
by comparison:
Code: [Select]
I already did and it didn't work. That's why I changed it. It just can't stop sending the IR signal.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
