Topic: Elapsed Timing Library for 1.02 (Read 3522 times) previous topic - next topic
BlackSnake
Hi all,
I have the Elapsed Timer library for Arduino 022 and my program works great.
However it will not work in version 1.02, I get the following error messages.
Can anyone point me to the updated library or a fix ?
C:\Users\Denis\arduino-1.0.2\libraries\Elapsed\Elapsed.cpp: In member function 'void Elapsed::reset()':
C:\Users\Denis\arduino-1.0.2\libraries\Elapsed\Elapsed.cpp:52: error: 'micros' was not declared in this scope
C:\Users\Denis\arduino-1.0.2\libraries\Elapsed\Elapsed.cpp:53: error: 'millis' was not declared in this scope
C:\Users\Denis\arduino-1.0.2\libraries\Elapsed\Elapsed.cpp: In member function 'long unsigned int Elapsed::intervalMs()':
C:\Users\Denis\arduino-1.0.2\libraries\Elapsed\Elapsed.cpp:59: error: 'millis' was not declared in this scope
C:\Users\Denis\arduino-1.0.2\libraries\Elapsed\Elapsed.cpp: In member function 'long unsigned int Elapsed::intervalUs()':
C:\Users\Denis\arduino-1.0.2\libraries\Elapsed\Elapsed.cpp:65: error: 'micros' was not declared in this scope
PaulS
Where did you get this library, which does not appear to have been updated for 1.0?
pYro_65
#2
Nov 25, 2012, 03:51 am Last Edit: Nov 25, 2012, 03:54 am by pYro_65 Reason: 1
Here is a little class I use to time stuff,
its template parameter is  'true' for high resolution ( micros ), or false for low ( millis ).
template< bool _HiRes = true >
 class TimeThis{
   protected:
     typedef TimeThis< _HiRes > MYTYPE;
     inline static const unsigned long GetTime( void )  { return ( _HiRes ? micros : millis )(); }
   public:
     TimeThis( unsigned long &u_TimeRef ) : u_Time( u_TimeRef = MYTYPE::GetTime() )  { return; }
     ~TimeThis( void )  { this->u_Time = MYTYPE::GetTime() - this->u_Time; }
   private:
     unsigned long   &u_Time;
void loop(){
   unsigned long u_Time;
     TimeThis< true > t_Time( u_Time );
     //Lengthy operation
   Serial.print( "Run Time: " );
   Serial.println( u_Time );
void setup(){Serial.begin(9600);}
Forum Mod anyone?
https://arduino.land/Moduino/
nickgammon
Looks like it might be one of mine, however the current one compiles OK under 1.0.2.
@OP: try downloading this file:
http://www.gammon.com.au/Arduino/Elapsed.zip
The original one probably didn't have the test for WProgram.h / Arduino.h.
More info:
robtillaart
alternative - http://arduino.cc/playground/Code/StopWatchClass -
Rob Tillaart
