Loading...
Pages: [1]   Go Down
Author Topic: Cheapest WiFi Module?  (Read 2007 times)
0 Members and 2 Guests are viewing this topic.
ਪੰਜਾਬ
Offline Offline
Edison Member
WANTED! A Girl with LOVE for me and Arduino!
View Profile
WWW
Hi fellows, ANybody here aware of the cheapest WiFi modules that would be around there? and would have suffiecient beef to be handled by a standard 8-Bitter like ATmega's?
Logged
"Real Men can Accomplish  Anything"
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
Southern California
Offline Offline
Sr. Member
I like blinky lights
View Profile
WWW
This is the least expensive one that I know about (US $34.95):
https://www.sparkfun.com/products/10822
http://www.mouser.com/ProductDetail/Roving-Networks/RN171XVW-I-RM/?qs=sGAEpiMZZMsSm7LhMeloEDuLr0wvUPSm
You speak to it via a serial link; I have had no problems talking to it using the software serial library.
Good luck!
Logged
http://en.wiktionary.org/wiki/magagna <-- My last name.  Pretty apt.
Dallas, TX
Offline Offline
Sr. Member
View Profile
This one from Digi seems to be similar for the same price.
http://store.digi.com/index.cfm?fuseaction=product.display&Product_ID=2557
Logged
ਪੰਜਾਬ
Offline Offline
Edison Member
View Profile
WWW
These are still expensive in comparison to this ElectricIMP module >> http://electricimp.com/ a complete single module consisting of Cortex-M3 and WiFi at about 25 USD, How they are able to get this price?
Logged
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
Southern California
Offline Offline
Sr. Member
View Profile
WWW
That's pretty interesting. I hadn't seen that before, thanks.
The cheapest I can find for it is $29.95 at Amazon, have you seen it for less? I may have to order one to check it out.
I'm not sure why there aren't cheaper WiFi solutions. Economies of scale?
Thanks again for the Electric Imp pointer.
Logged
Australia
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Check ebay or other online shops for the nrf24l01 - should be about $2-3 smiley
Logged
Cleveland, TN
Offline Offline
Full Member
View Profile
Quote
The Nordic is a great module but it is not a completely functional plug and play module in that format. It requires peripheral components including some sort of PCB, adapter board, or socket to hold that dinky 4mm chip.
The biggest expense associated with building these types of functional modules is the PCB. If you total all of the components needed at wholesale price its probably about $5. So yeah its economics of scale as mentioned above. If you build ten of them you are going to pay a lot more than if you build 100,000 of them. This becomes really clear if you have looked into having PCB's manufactured either raw or populated.
Logged
Luck,
Wade
Belgium
Offline Offline
Full Member
View Profile
WWW
You can find functional nRF24L01 modules on Ebay for less then 2$: http://www.ebay.co.uk/itm/2-4Ghz-nRF24L01-RF-Transceiver-Module-ISM-Breakout-/271095195228?pt=LH_DefaultDomain_0&hash=item3f1e88665c
I have played with them and used them in my robots. Big difference with a Wifi chip though...
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
I don't think nrf24l01 is wifi.
Logged
Kitchen-Sink Arduino-compatible boards
Europe
Offline Offline
Full Member
View Profile
wrt routers for ~20$
Logged
Belgium
Offline Offline
Full Member
View Profile
WWW
Correct, the nRF24L01 is a wireless transceiver that uses the 2.4GHz band. Same frequency as Wifi but that doesn't make it a Wifi device. I have a setup at home were an ATmega328 with some sensors connected to it sends an array of data to an ATmega1284 through 2 nRF24L01 modules. That ATmega1284 sends data over I2C to an Arduino Uno with an Ethernet shield. The Uno writes that data to an sd card and runs a small webserver. Sounds complicated, but it wasn't very difficult to program. And I'm very new to micro controllers and programming.
Logged
Cleveland, TN
Offline Offline
Full Member
View Profile
Quote
I stand corrected! Awesome find. I'm tempted to buy 10 of them just to have them around!
Logged
Luck,
Wade
ਪੰਜਾਬ
Offline Offline
Edison Member
View Profile
WWW
I already have 2.4 GHz supporting nordic's nrf IC's but the reason I think they cant be used because they aren't 802.15.4 protocol supporting, what you folks say? have you used it as a WiFi?
Logged
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
Belgium
Offline Offline
Full Member
View Profile
WWW
They do NOT support Wifi. It's much simpler chip then Wifi chips... There is a reason they are that cheap smiley
Logged
Offline Offline
Newbie
View Profile
I guess the arduino wifi shield is too expensive.... maybe use and XBee?
Logged
Pages: [1]   Go Up
Print
Jump to:
