Loading...
Pages: [1] 2 3 ... 5   Go Down
Author Topic: ArduinoISP Arduino uno & blank atmega8 bootloader burn trouble  (Read 3110 times)
Offline Offline
Newbie
View Profile
i cant believe this 9500 character limit so i had to split it into 7 posts, please go forth and read
pardon if i sound at all rude but ive seen so many tutorials im getting sick of the links to one another,
ive been trying to burn a bootloader to sevral chips using my arduino uno with NO luck,
i just got 3 atmega8 chips completely blank no bootloader, so i tried all methods of burning a bootloader for use with internal 8mhz tutorials,
if you can google it(with all kindsa peramiters in search) ive looked at and tried it,
i DO NOT HAVE and WILL NOT BUY external crystals for sevral reasons, i have NO MONEY to buy any,
and if i dont need one (as it seems) i wont use one for saving on space, time, money, and parts,
if i was ABSOLUTELY SURE it would work if i bought a crystal i would buy 1 but im not so i wont, so please do not ask me to do so
I SERIOUSLY NEED HELP PEOPLE
im no expert at any programming language but im very smart and can follow STEP-BY-STEP instructions,
please for the love of god DO NOT "LINK" TUTORIALS just lay out what i need to do HERE
im running Ubuntu/linux 12.04 w/Arduino IDE 1.0
« Last Edit: November 25, 2012, 05:27:45 am by mysteredding » Logged
Offline Offline
Newbie
View Profile
heres all my arduinoisp sketches
Code:
#include "pins_arduino.h"  // defines SS,MOSI,MISO,SCK
#define RESET SS
#define LED_HB 9
#define LED_ERR 8
#define LED_PMODE 7
#define HWVER 2
#define SWMAJ 1
#define SWMIN 18
// STK Definitions
#define STK_OK 0x10
#define STK_FAILED 0x11
#define STK_UNKNOWN 0x12
#define STK_INSYNC 0x14
#define STK_NOSYNC 0x15
#define CRC_EOP 0x20 //ok it is a space...
void pulse(int pin, int times);
  Serial.begin(19200);
  pinMode(7, OUTPUT);
  pulse(7, 2);
  pinMode(8, OUTPUT);
  pulse(8, 2);
  pinMode(9, OUTPUT);
  pulse(9, 2);
int error=0;
int pmode=0;
// address for reading and writing, set by 'U' command
int here;
uint8_t buff[256]; // global block storage
#define beget16(addr) (*addr * 256 + *(addr+1) )
typedef struct param {
  uint8_t devicecode;
  uint8_t revision;
  uint8_t progtype;
  uint8_t parmode;
  uint8_t polling;
  uint8_t selftimed;
  uint8_t lockbytes;
  uint8_t fusebytes;
  int flashpoll;
  int eeprompoll;
  int pagesize;
  int eepromsize;
  int flashsize;
parameter;
parameter param;
// this provides a heartbeat on pin 9, so you can tell the software is running.
uint8_t hbval=128;
int8_t hbdelta=8;
void heartbeat() {
  if (hbval > 192) hbdelta = -hbdelta;
  if (hbval < 32) hbdelta = -hbdelta;
  hbval += hbdelta;
  analogWrite(LED_HB, hbval);
  delay(40);
void loop(void) {
  // is pmode active?
  if (pmode) digitalWrite(LED_PMODE, HIGH);
  else digitalWrite(LED_PMODE, LOW);
  // is there an error?
  if (error) digitalWrite(LED_ERR, HIGH);
  else digitalWrite(LED_ERR, LOW);
  // light the heartbeat LED
  heartbeat();
  if (Serial.available()) {
    avrisp();
uint8_t getch() {
  while(!Serial.available());
  return Serial.read();
void readbytes(int n) {
  for (int x = 0; x < n; x++) {
    buff[x] = Serial.read();
#define PTIME 30
void pulse(int pin, int times) {
  do {
    digitalWrite(pin, HIGH);
    delay(PTIME);
    digitalWrite(pin, LOW);
    delay(PTIME);
  while (times--);
void spi_init() {
  uint8_t x;
  SPCR = 0x53;
  x=SPSR;
  x=SPDR;
void spi_wait() {
  do {
  while (!(SPSR & (1 << SPIF)));
uint8_t spi_send(uint8_t b) {
  uint8_t reply;
  SPDR=b;
  spi_wait();
  reply = SPDR;
  return reply;
uint8_t spi_transaction(uint8_t a, uint8_t b, uint8_t c, uint8_t d) {
  uint8_t n;
  spi_send(a);
  n=spi_send(b);
  //if (n != a) error = -1;
  n=spi_send(c);
  return spi_send(d);
void empty_reply() {
  if (CRC_EOP == getch()) {
    Serial.print((char)STK_INSYNC);
    Serial.print((char)STK_OK);
  else {
    Serial.print((char)STK_NOSYNC);
void breply(uint8_t b) {
    Serial.print((char)b);
  else {
void get_version(uint8_t c) {
  switch(c) {
  case 0x80:
    breply(HWVER);
  case 0x81:
    breply(SWMAJ);
  case 0x82:
    breply(SWMIN);
  case 0x93:
    breply('S'); // serial programmer
  default:
    breply(0);
void set_parameters() {
  // call this after reading paramter packet into buff[]
  param.devicecode = buff[0];
  param.revision = buff[1];
  param.progtype = buff[2];
  param.parmode = buff[3];
  param.polling = buff[4];
  param.selftimed = buff[5];
  param.lockbytes = buff[6];
  param.fusebytes = buff[7];
  param.flashpoll = buff[8];
  // ignore buff[9] (= buff[8])
  //getch(); // discard second value
  // WARNING: not sure about the byte order of the following
  // following are 16 bits (big endian)
  param.eeprompoll = beget16(&buff[10]);
  param.pagesize = beget16(&buff[12]);
  param.eepromsize = beget16(&buff[14]);
  // 32 bits flashsize (big endian)
  param.flashsize = buff[16] * 0x01000000
    + buff[17] * 0x00010000
    + buff[18] * 0x00000100
    + buff[19];
void start_pmode() {
  spi_init();
  // following delays may not work on all targets...
  pinMode(RESET, OUTPUT);
  digitalWrite(RESET, HIGH);
  pinMode(SCK, OUTPUT);
  digitalWrite(SCK, LOW);
  delay(50);
  digitalWrite(RESET, LOW);
  delay(50);
  pinMode(MISO, INPUT);
  pinMode(MOSI, OUTPUT);
  spi_transaction(0xAC, 0x53, 0x00, 0x00);
  pmode = 1;
void end_pmode() {
  pinMode(MOSI, INPUT);
  pinMode(SCK, INPUT);
  pinMode(RESET, INPUT);
  pmode = 0;
void universal() {
  int w;
  uint8_t ch;
  for (w = 0; w < 4; w++) {
    buff[w] = getch();
  ch = spi_transaction(buff[0], buff[1], buff[2], buff[3]);
  breply(ch);
void flash(uint8_t hilo, int addr, uint8_t data) {
  spi_transaction(0x40+8*hilo,
  addr>>8 & 0xFF,
  addr & 0xFF,
  data);
void commit(int addr) {
  spi_transaction(0x4C, (addr >> 8) & 0xFF, addr & 0xFF, 0);
//#define _current_page(x) (here & 0xFFFFE0)
int current_page(int addr) {
  if (param.pagesize == 32) return here & 0xFFFFFFF0;
  if (param.pagesize == 64) return here & 0xFFFFFFE0;
  if (param.pagesize == 128) return here & 0xFFFFFFC0;
  if (param.pagesize == 256) return here & 0xFFFFFF80;
  return here;
uint8_t write_flash(int length) {
  if (param.pagesize < 1) return STK_FAILED;
  //if (param.pagesize != 64) return STK_FAILED;
  int page = current_page(here);
  int x = 0;
  while (x < length) {
    if (page != current_page(here)) {
      commit(page);
    flash(LOW, here, buff[x++]);
    flash(HIGH, here, buff[x++]);
    here++;
  commit(page);
  return STK_OK;
uint8_t write_eeprom(int length) {
  // here is a word address, so we use here*2
  // this writes byte-by-byte,
  // page writing may be faster (4 bytes at a time)
  for (int x = 0; x < length; x++) {
    spi_transaction(0xC0, 0x00, here*2+x, buff[x]);
    delay(45);
  return STK_OK;
void program_page() {
  char result = (char) STK_FAILED;
  int length = 256 * getch() + getch();
  if (length > 256) {
      Serial.print((char) STK_FAILED);
      return;
  char memtype = getch();
    buff[x] = getch();
    Serial.print((char) STK_INSYNC);
    if (memtype == 'F') result = (char)write_flash(length);
    if (memtype == 'E') result = (char)write_eeprom(length);
    Serial.print(result);
  else {
    Serial.print((char) STK_NOSYNC);
uint8_t flash_read(uint8_t hilo, int addr) {
  return spi_transaction(0x20 + hilo * 8,
    (addr >> 8) & 0xFF,
    addr & 0xFF,
    0);
char flash_read_page(int length) {
  for (int x = 0; x < length; x+=2) {
    uint8_t low = flash_read(LOW, here);
    Serial.print((char) low);
    uint8_t high = flash_read(HIGH, here);
    Serial.print((char) high);
    here++;
  return STK_OK;
char eeprom_read_page(int length) {
  // here again we have a word address
    uint8_t ee = spi_transaction(0xA0, 0x00, here*2+x, 0xFF);
    Serial.print((char) ee);
  return STK_OK;
void read_page() {
  char result = (char)STK_FAILED;
  if (CRC_EOP != getch()) {
    return;
  if (memtype == 'F') result = flash_read_page(length);
  if (memtype == 'E') result = eeprom_read_page(length);
  return;
void read_signature() {
    return;
  uint8_t high = spi_transaction(0x30, 0x00, 0x00, 0x00);
  uint8_t middle = spi_transaction(0x30, 0x00, 0x01, 0x00);
  Serial.print((char) middle);
  uint8_t low = spi_transaction(0x30, 0x00, 0x02, 0x00);
  Serial.print((char) STK_OK);
1/2
Logged
Offline Offline
Newbie
View Profile
2/2
Code:
int avrisp() {
  uint8_t data, low, high;
  uint8_t ch = getch();
  switch (ch) {
  case '0': // signon
    empty_reply();
  case '1':
    if (getch() == CRC_EOP) {
      Serial.print("AVR ISP");
  case 'A':
    get_version(getch());
  case 'B':
    readbytes(20);
    set_parameters();
    empty_reply();
  case 'E': // extended parameters - ignore for now
    readbytes(5);
    empty_reply();
  case 'P':
    start_pmode();
    empty_reply();
  case 'U':
    here = getch() + 256 * getch();
    empty_reply();
  case 0x60: //STK_PROG_FLASH
    low = getch();
    high = getch();
    empty_reply();
  case 0x61: //STK_PROG_DATA
    data = getch();
    empty_reply();
  case 0x64: //STK_PROG_PAGE
    program_page();
  case 0x74: //STK_READ_PAGE
    read_page();
  case 'V':
    universal();
  case 'Q':
    error=0;
    end_pmode();
    empty_reply();
  case 0x75: //STK_READ_SIGN
    read_signature();
  // expecting a command, not CRC_EOP
  // this is how we can get back in sync
  case CRC_EOP:
  // anything else we will return STK_UNKNOWN
  default:
      Serial.print((char)STK_UNKNOWN);
Logged
Offline Offline
Newbie
View Profile
slight alteration to delay(40) to (20) and i think thats it
Code:
// this sketch turns the Arduino into a AVRISP
// using the following pins:
// 10: slave reset
// 11: MOSI
// 12: MISO
// 13: SCK
// Put an LED (with resistor) on the following pins:
// 9: Heartbeat - shows the programmer is running
// 8: Error - Lights up if something goes wrong (use red if that makes sense)
// 7: Programming - In communication with the slave
// October 2009 by David A. Mellis
// - Added support for the read signature command
// February 2009 by Randall Bohn
// - Added support for writing to EEPROM (what took so long?)
// Windows users should consider WinAVR's avrdude instead of the
// avrdude included with Arduino software.
// January 2008 by Randall Bohn
// - Thanks to Amplificar for helping me with the STK500 protocol
// - The AVRISP/STK500 (mk I) protocol is used in the arduino bootloader
// - The SPI functions herein were developed for the AVR910_ARD programmer
// - More information at http://code.google.com/p/mega-isp
#define RESET SS
#define LED_HB 9
#define LED_ERR 8
#define LED_PMODE 7
#define HWVER 2
#define SWMAJ 1
#define SWMIN 18
// STK Definitions
#define STK_OK 0x10
  pinMode(7, OUTPUT);
  pulse(7, 2);
  pinMode(8, OUTPUT);
  pulse(8, 2);
  pinMode(9, OUTPUT);
  pulse(9, 2);
int error=0;
int pmode=0;
int here;
  uint8_t devicecode;
  uint8_t revision;
  uint8_t progtype;
  uint8_t parmode;
  uint8_t polling;
  uint8_t selftimed;
  uint8_t lockbytes;
  uint8_t fusebytes;
  int flashpoll;
  int eeprompoll;
  int pagesize;
  int eepromsize;
  int flashsize;
parameter;
parameter param;
uint8_t hbval=128;
int8_t hbdelta=8;
void heartbeat() {
  hbval += hbdelta;
  delay(20);
void loop(void) {
  // is pmode active?
  heartbeat();
    avrisp();
uint8_t getch() {
#define PTIME 30
  do {
    delay(PTIME);
    delay(PTIME);
  while (times--);
void spi_init() {
  uint8_t x;
  SPCR = 0x53;
  x=SPSR;
  x=SPDR;
void spi_wait() {
  do {
  uint8_t reply;
  SPDR=b;
  spi_wait();
  reply = SPDR;
  return reply;
  uint8_t n;
  spi_send(a);
  n=spi_send(b);
  n=spi_send(c);
  return spi_send(d);
  else {
  else {
  switch(c) {
  case 0x80:
    breply(HWVER);
  case 0x81:
    breply(SWMAJ);
  case 0x82:
    breply(SWMIN);
  case 0x93:
  default:
    breply(0);
    + buff[19];
  spi_init();
  delay(50);
  delay(50);
  pmode = 1;
void end_pmode() {
  pmode = 0;
void universal() {
  int w;
  uint8_t ch;
    buff[w] = getch();
  breply(ch);
  addr>>8 & 0xFF,
  addr & 0xFF,
  data);
  return here;
  int x = 0;
      commit(page);
    here++;
  commit(page);
  return STK_OK;
    delay(45);
  return STK_OK;
  if (length > 256) {
      return;
    buff[x] = getch();
  else {
    (addr >> 8) & 0xFF,
    addr & 0xFF,
    0);
    here++;
  return STK_OK;
  return STK_OK;
void read_page() {
    return;
  return;
    return;
1/2
Logged
Offline Offline
Newbie
View Profile
2/2
Code:
int avrisp() {
  switch (ch) {
  case '0': // signon
    empty_reply();
  case '1':
  case 'A':
  case 'B':
    readbytes(20);
    set_parameters();
    empty_reply();
    readbytes(5);
    empty_reply();
  case 'P':
    start_pmode();
    empty_reply();
  case 'U':
    empty_reply();
    low = getch();
    high = getch();
    empty_reply();
    data = getch();
    empty_reply();
    program_page();
    read_page();
  case 'V':
    universal();
  case 'Q':
    error=0;
    end_pmode();
    empty_reply();
    read_signature();
  case CRC_EOP:
  default:
Logged
Offline Offline
Newbie
View Profile
2011 version
Code:
#include "SPI.h"
#define RESET     SS
#define LED_HB    9
#define LED_ERR   8
#define LED_PMODE 7
#define PROG_FLICKER true
#define HWVER 2
#define SWMAJ 1
#define SWMIN 18
// STK Definitions
#define STK_OK      0x10
  SPI.setDataMode(0);
  SPI.setBitOrder(MSBFIRST);
  // Clock Div can be 2,4,8,16,32,64, or 128
  SPI.setClockDivider(SPI_CLOCK_DIV128);
  pinMode(LED_PMODE, OUTPUT);
  pulse(LED_PMODE, 2);
  pinMode(LED_ERR, OUTPUT);
  pulse(LED_ERR, 2);
  pinMode(LED_HB, OUTPUT);
  pulse(LED_HB, 2);
int error=0;
int pmode=0;
int here;
  uint8_t devicecode;
  uint8_t revision;
  uint8_t progtype;
  uint8_t parmode;
  uint8_t polling;
  uint8_t selftimed;
  uint8_t lockbytes;
  uint8_t fusebytes;
  uint8_t flashpoll;
  uint16_t eeprompoll;
  uint16_t pagesize;
  uint16_t eepromsize;
  uint32_t flashsize;
parameter;
parameter param;
uint8_t hbval=128;
int8_t hbdelta=8;
void heartbeat() {
  hbval += hbdelta;
  delay(40);
void loop(void) {
  // is pmode active?
  heartbeat();
    avrisp();
uint8_t getch() {
void fill(int n) {
    buff[x] = getch();
#define PTIME 30
  do {
    delay(PTIME);
    delay(PTIME);
  while (times--);
void prog_lamp(int state) {
  if (PROG_FLICKER)
    digitalWrite(LED_PMODE, state);
  uint8_t n;
  SPI.transfer(a);
  n=SPI.transfer(b);
  n=SPI.transfer(c);
  return SPI.transfer(d);
  else {
    error++;
  else {
    error++;
  switch(c) {
  case 0x80:
    breply(HWVER);
  case 0x81:
    breply(SWMAJ);
  case 0x82:
    breply(SWMIN);
  case 0x93:
  default:
    breply(0);
    + buff[19];
  SPI.begin();
  delay(20);
  pmode = 1;
void end_pmode() {
  SPI.end();
  pmode = 0;
void universal() {
  int w;
  uint8_t ch;
  fill(4);
  breply(ch);
  addr>>8 & 0xFF,
  addr & 0xFF,
  data);
  if (PROG_FLICKER) prog_lamp(LOW);
  if (PROG_FLICKER) {
    delay(PTIME);
    prog_lamp(HIGH);
  return here;
void write_flash(int length) {
  fill(length);
    Serial.print((char) write_flash_pages(length));
  else {
    error++;
uint8_t write_flash_pages(int length) {
  int x = 0;
      commit(page);
    here++;
  commit(page);
  return STK_OK;
#define EECHUNK (32)
  // here is a word address, get the byte address
  int start = here * 2;
  int remaining = length;
  if (length > param.eepromsize) {
    error++;
    return STK_FAILED;
  while (remaining > EECHUNK) {
    write_eeprom_chunk(start, EECHUNK);
    start += EECHUNK;
    remaining -= EECHUNK;
  write_eeprom_chunk(start, remaining);
  return STK_OK;
// write (length) bytes, (start) is a byte address
uint8_t write_eeprom_chunk(int start, int length) {
  fill(length);
  prog_lamp(LOW);
    int addr = start+x;
    spi_transaction(0xC0, (addr>>8) & 0xFF, addr & 0xFF, buff[x]);
    delay(45);
  prog_lamp(HIGH);
  return STK_OK;
  int length = 256 * getch();
  length += getch();
  // flash memory @here, (length) bytes
  if (memtype == 'F') {
    return;
  if (memtype == 'E') {
    else {
      error++;
    return;
  Serial.print((char)STK_FAILED);
  return;
  (addr >> 8) & 0xFF,
  addr & 0xFF,
  0);
    here++;
  return STK_OK;
    int addr = start + x;
    uint8_t ee = spi_transaction(0xA0, (addr >> 8) & 0xFF, addr & 0xFF, 0xFF);
  return STK_OK;
void read_page() {
  length += getch();
    error++;
    return;
  return;
    error++;
    return;
1/2
Logged
Offline Offline
Newbie
View Profile
2/2
Code:
int avrisp() {
  switch (ch) {
  case '0': // signon
    error = 0;
    empty_reply();
  case '1':
      error++;
  case 'A':
  case 'B':
    fill(20);
    set_parameters();
    empty_reply();
    fill(5);
    empty_reply();
  case 'P':
    if (pmode) {
      pulse(LED_ERR, 3);
      start_pmode();
    empty_reply();
  case 'U': // set address (word)
    here = getch();
    here += 256 * getch();
    empty_reply();
    low = getch();
    high = getch();
    empty_reply();
    data = getch();
    empty_reply();
    program_page();
  case 0x74: //STK_READ_PAGE 't'
    read_page();
  case 'V': //0x56
    universal();
  case 'Q': //0x51
    error=0;
    end_pmode();
    empty_reply();
  case 0x75: //STK_READ_SIGN 'u'
    read_signature();
  case CRC_EOP:
    error++;
  default:
    error++;
Logged
Offline Offline
Newbie
View Profile
heres my boards.txt, this isnt the full list just what im trying to bootload
Code:
atmega8.name=ATmega8-noxtal @8MHz
atmega8.upload.protocol=arduino
atmega8.upload.maximum_size=7168
atmega8.upload.speed=38400
atmega8.bootloader.low_fuses=0xe4
atmega8.bootloader.high_fuses=0xc2
atmega8.bootloader.path=atmega8_noxtal
atmega8.bootloader.file=ATmegaBOOT.hex
atmega8.bootloader.unlock_bits=0x3F
atmega8.bootloader.lock_bits=0x0F
atmega8.build.mcu=atmega8
atmega8.build.f_cpu=8000000L
atmega8.build.core=arduino
atmega8.build.variant=standard
atmega8.name=Arduino NG or older w/ ATmega8
atmega8.upload.protocol=stk500
atmega8.upload.speed=19200
atmega8.bootloader.low_fuses=0xdf
atmega8.bootloader.high_fuses=0xca
atmega8.build.f_cpu=16000000L
atmega8bb.name=ATmega8 on a breadboard (8 MHz internal clock)
atmega8bb.upload.protocol=stk500
atmega8bb.upload.maximum_size=7168
atmega8bb.upload.speed=19200
atmega8bb.bootloader.low_fuses=0xD4
atmega8bb.bootloader.high_fuses=0xCA
atmega8bb.bootloader.path=arduino:atmega8
atmega8bb.bootloader.file=ATmegaBOOT.hex
atmega8bb.bootloader.unlock_bits=0x3F
atmega8bb.bootloader.lock_bits=0x2F
atmega8bb.build.mcu=atmega8
atmega8bb.build.f_cpu=8000000L
atmega8bb.build.core=arduino:arduino
atmega8noxtal.name=ATmega8-noxtal @8MHz
atmega8noxtal.upload.protocol=stk500
atmega8noxtal.upload.maximum_size=7168
atmega8noxtal.upload.speed=19200
atmega8noxtal.bootloader.low_fuses=0xe4
atmega8noxtal.bootloader.high_fuses=0xc4
atmega8noxtal.bootloader.path=atmega8
atmega8noxtal.bootloader.file=ATmegaBOOT.hex
atmega8noxtal.bootloader.unlock_bits=0x3F
atmega8noxtal.bootloader.lock_bits=0x0F
atmega8noxtal.build.mcu=atmega8
atmega8noxtal.build.f_cpu=8000000L
atmega8noxtal.build.core=arduino
atmega8.name=Arduino NG8 mhz
atmega8.bootloader.high_fuses=0xd1
as you can see ive got quite a few boards ive tried already with avrdude: stk500_recv(): programmer is not responding when i use a pull-up resistor and avrdude: stk500_getsync(): not in sync: resp=0x## with different # each time and even sometimes get avrdude: stk500_getsync(): not in sync: expect:0x## or something to that effect, im stressing hard guys i need your help somebody anybody tell me what im doing wrong and what i need to do to fix this problem, or atleast a step in the right direction, please for the love of god DO NOT "LINK" TUTORIALS just lay out what i need to do HERE
Logged
Offline Offline
Full Member
View Profile
Follow this tutorial:
http://pdp11.byethost12.com/AVR/ArduinoAsProgrammer.htm
Replace the atmega328p with your atmega8 and do not add any crystal and capacitors.
By doing so you can burn any code you like in your atmega8, including a bootloader if you really want to write one. In most cases, for stand alone applications, the bootloader is not necessary.
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
If you don't use a crystal or ceramic resonator on your atmel mcu, then the clock frequency will very probably not be accurate enough for the bootloader to work even if you do manage to burn it. However, you can still use ArduinoISP to upload your sketch directly, without a bootloader. See http://miscsolutions.wordpress.com/2011/08/09/prototyping-small-embedded-projects-with-arduino/ for how I used to do it before I purchased an AVRISPmkII.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Good point. And now that the IDE has a 'upload using programmer' option one can really easily live without messing with bootloaders at all. And seeing that an arduino board running the arduinoISP sketch becomes a hardware programmer, there is a lot to be said for just not messing with bootloaders.
 Just think your mega boards won't suffer if you want to use the WDT or if your compiled code happens to have a !!! string for random data in it, it won't hang the upload. One could make a good argument to 'just say no' when the subject of bootloaders come up.  smiley-grin
Lefty
Logged
Offline Offline
Newbie
View Profile
ive been to that page (which i said not to link) and it failed with same errors, try again and this time READ MY POST
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
You can attach files to your post you know. Making 7 posts just to attach files is a mis-use of the forum. You can attach multiple files, or make a single .zip file.
Quote
If there is a tutorial, that explains what to do, why should it be copied and pasted here, when you just have to go to a link? The tutorial might have photos, etc.
Logged
Offline Offline
Newbie
View Profile
Quote
ive never used forums before and so i didnt know you could attach files, as for the linking im just tired of sifting thru bullshit just to find out it didnt work, i just want short simple answers to whats wrong
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
OP, please DO NOT hit the "report to moderator" control again.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Pages: [1] 2 3 ... 5   Go Up
Print
Jump to:
