« on: November 25, 2012, 05:08:03 am » |
i cant believe this 9500 character limit so i had to split it into 7 posts, please go forth and read pardon if i sound at all rude but ive seen so many tutorials im getting sick of the links to one another, ive been trying to burn a bootloader to sevral chips using my arduino uno with NO luck, i just got 3 atmega8 chips completely blank no bootloader, so i tried all methods of burning a bootloader for use with internal 8mhz tutorials, if you can google it(with all kindsa peramiters in search) ive looked at and tried it, i DO NOT HAVE and WILL NOT BUY external crystals for sevral reasons, i have NO MONEY to buy any, and if i dont need one (as it seems) i wont use one for saving on space, time, money, and parts, if i was ABSOLUTELY SURE it would work if i bought a crystal i would buy 1 but im not so i wont, so please do not ask me to do so I SERIOUSLY NEED HELP PEOPLE im no expert at any programming language but im very smart and can follow STEP-BY-STEP instructions, please for the love of god DO NOT "LINK" TUTORIALS just lay out what i need to do HERE
im running Ubuntu/linux 12.04 w/Arduino IDE 1.0
« Last Edit: November 25, 2012, 05:27:45 am by mysteredding »
« Reply #1 on: November 25, 2012, 05:12:58 am » |
heres all my arduinoisp sketches #include "pins_arduino.h" // defines SS,MOSI,MISO,SCK #define RESET SS
#define LED_HB 9 #define LED_ERR 8 #define LED_PMODE 7
#define HWVER 2 #define SWMAJ 1 #define SWMIN 18
// STK Definitions #define STK_OK 0x10 #define STK_FAILED 0x11 #define STK_UNKNOWN 0x12 #define STK_INSYNC 0x14 #define STK_NOSYNC 0x15 #define CRC_EOP 0x20 //ok it is a space...
void pulse(int pin, int times);
void setup() { Serial.begin(19200); pinMode(7, OUTPUT); pulse(7, 2); pinMode(8, OUTPUT); pulse(8, 2); pinMode(9, OUTPUT); pulse(9, 2); }
int error=0; int pmode=0; // address for reading and writing, set by 'U' command int here; uint8_t buff[256]; // global block storage
#define beget16(addr) (*addr * 256 + *(addr+1) ) typedef struct param { uint8_t devicecode; uint8_t revision; uint8_t progtype; uint8_t parmode; uint8_t polling; uint8_t selftimed; uint8_t lockbytes; uint8_t fusebytes; int flashpoll; int eeprompoll; int pagesize; int eepromsize; int flashsize; } parameter;
parameter param;
// this provides a heartbeat on pin 9, so you can tell the software is running. uint8_t hbval=128; int8_t hbdelta=8; void heartbeat() { if (hbval > 192) hbdelta = -hbdelta; if (hbval < 32) hbdelta = -hbdelta; hbval += hbdelta; analogWrite(LED_HB, hbval); delay(40); } void loop(void) { // is pmode active? if (pmode) digitalWrite(LED_PMODE, HIGH); else digitalWrite(LED_PMODE, LOW); // is there an error? if (error) digitalWrite(LED_ERR, HIGH); else digitalWrite(LED_ERR, LOW); // light the heartbeat LED heartbeat(); if (Serial.available()) { avrisp(); } }
uint8_t getch() { while(!Serial.available()); return Serial.read(); } void readbytes(int n) { for (int x = 0; x < n; x++) { buff[x] = Serial.read(); } }
#define PTIME 30 void pulse(int pin, int times) { do { digitalWrite(pin, HIGH); delay(PTIME); digitalWrite(pin, LOW); delay(PTIME); } while (times--); }
void spi_init() { uint8_t x; SPCR = 0x53; x=SPSR; x=SPDR; }
void spi_wait() { do { } while (!(SPSR & (1 << SPIF))); }
uint8_t spi_send(uint8_t b) { uint8_t reply; SPDR=b; spi_wait(); reply = SPDR; return reply; }
uint8_t spi_transaction(uint8_t a, uint8_t b, uint8_t c, uint8_t d) { uint8_t n; spi_send(a); n=spi_send(b); //if (n != a) error = -1; n=spi_send(c); return spi_send(d); }
void empty_reply() { if (CRC_EOP == getch()) { Serial.print((char)STK_INSYNC); Serial.print((char)STK_OK); } else { Serial.print((char)STK_NOSYNC); } }
void breply(uint8_t b) { if (CRC_EOP == getch()) { Serial.print((char)STK_INSYNC); Serial.print((char)b); Serial.print((char)STK_OK); } else { Serial.print((char)STK_NOSYNC); } }
void get_version(uint8_t c) { switch(c) { case 0x80: breply(HWVER); break; case 0x81: breply(SWMAJ); break; case 0x82: breply(SWMIN); break; case 0x93: breply('S'); // serial programmer break; default: breply(0); } }
void set_parameters() { // call this after reading paramter packet into buff[] param.devicecode = buff[0]; param.revision = buff[1]; param.progtype = buff[2]; param.parmode = buff[3]; param.polling = buff[4]; param.selftimed = buff[5]; param.lockbytes = buff[6]; param.fusebytes = buff[7]; param.flashpoll = buff[8]; // ignore buff[9] (= buff[8]) //getch(); // discard second value // WARNING: not sure about the byte order of the following // following are 16 bits (big endian) param.eeprompoll = beget16(&buff[10]); param.pagesize = beget16(&buff[12]); param.eepromsize = beget16(&buff[14]);
// 32 bits flashsize (big endian) param.flashsize = buff[16] * 0x01000000 + buff[17] * 0x00010000 + buff[18] * 0x00000100 + buff[19];
void start_pmode() { spi_init(); // following delays may not work on all targets... pinMode(RESET, OUTPUT); digitalWrite(RESET, HIGH); pinMode(SCK, OUTPUT); digitalWrite(SCK, LOW); delay(50); digitalWrite(RESET, LOW); delay(50); pinMode(MISO, INPUT); pinMode(MOSI, OUTPUT); spi_transaction(0xAC, 0x53, 0x00, 0x00); pmode = 1; }
void end_pmode() { pinMode(MISO, INPUT); pinMode(MOSI, INPUT); pinMode(SCK, INPUT); pinMode(RESET, INPUT); pmode = 0; }
void universal() { int w; uint8_t ch;
for (w = 0; w < 4; w++) { buff[w] = getch(); } ch = spi_transaction(buff[0], buff[1], buff[2], buff[3]); breply(ch); }
void flash(uint8_t hilo, int addr, uint8_t data) { spi_transaction(0x40+8*hilo, addr>>8 & 0xFF, addr & 0xFF, data); } void commit(int addr) { spi_transaction(0x4C, (addr >> 8) & 0xFF, addr & 0xFF, 0); }
//#define _current_page(x) (here & 0xFFFFE0) int current_page(int addr) { if (param.pagesize == 32) return here & 0xFFFFFFF0; if (param.pagesize == 64) return here & 0xFFFFFFE0; if (param.pagesize == 128) return here & 0xFFFFFFC0; if (param.pagesize == 256) return here & 0xFFFFFF80; return here; } uint8_t write_flash(int length) { if (param.pagesize < 1) return STK_FAILED; //if (param.pagesize != 64) return STK_FAILED; int page = current_page(here); int x = 0; while (x < length) { if (page != current_page(here)) { commit(page); page = current_page(here); } flash(LOW, here, buff[x++]); flash(HIGH, here, buff[x++]); here++; }
commit(page);
return STK_OK; }
uint8_t write_eeprom(int length) { // here is a word address, so we use here*2 // this writes byte-by-byte, // page writing may be faster (4 bytes at a time) for (int x = 0; x < length; x++) { spi_transaction(0xC0, 0x00, here*2+x, buff[x]); delay(45); } return STK_OK; }
void program_page() { char result = (char) STK_FAILED; int length = 256 * getch() + getch(); if (length > 256) { Serial.print((char) STK_FAILED); return; } char memtype = getch(); for (int x = 0; x < length; x++) { buff[x] = getch(); } if (CRC_EOP == getch()) { Serial.print((char) STK_INSYNC); if (memtype == 'F') result = (char)write_flash(length); if (memtype == 'E') result = (char)write_eeprom(length); Serial.print(result); } else { Serial.print((char) STK_NOSYNC); } } uint8_t flash_read(uint8_t hilo, int addr) { return spi_transaction(0x20 + hilo * 8, (addr >> 8) & 0xFF, addr & 0xFF, 0); }
char flash_read_page(int length) { for (int x = 0; x < length; x+=2) { uint8_t low = flash_read(LOW, here); Serial.print((char) low); uint8_t high = flash_read(HIGH, here); Serial.print((char) high); here++; } return STK_OK; }
char eeprom_read_page(int length) { // here again we have a word address for (int x = 0; x < length; x++) { uint8_t ee = spi_transaction(0xA0, 0x00, here*2+x, 0xFF); Serial.print((char) ee); } return STK_OK; }
void read_page() { char result = (char)STK_FAILED; int length = 256 * getch() + getch(); char memtype = getch(); if (CRC_EOP != getch()) { Serial.print((char) STK_NOSYNC); return; } Serial.print((char) STK_INSYNC); if (memtype == 'F') result = flash_read_page(length); if (memtype == 'E') result = eeprom_read_page(length); Serial.print(result); return; }
void read_signature() { if (CRC_EOP != getch()) { Serial.print((char) STK_NOSYNC); return; } Serial.print((char) STK_INSYNC); uint8_t high = spi_transaction(0x30, 0x00, 0x00, 0x00); Serial.print((char) high); uint8_t middle = spi_transaction(0x30, 0x00, 0x01, 0x00); Serial.print((char) middle); uint8_t low = spi_transaction(0x30, 0x00, 0x02, 0x00); Serial.print((char) low); Serial.print((char) STK_OK); } ////////////////////////////////////////// //////////////////////////////////////////
1/2
« Reply #2 on: November 25, 2012, 05:17:23 am » |
2/2 //////////////////////////////////// //////////////////////////////////// int avrisp() { uint8_t data, low, high; uint8_t ch = getch(); switch (ch) { case '0': // signon empty_reply(); break; case '1': if (getch() == CRC_EOP) { Serial.print((char) STK_INSYNC); Serial.print("AVR ISP"); Serial.print((char) STK_OK); } break; case 'A': get_version(getch()); break; case 'B': readbytes(20); set_parameters(); empty_reply(); break; case 'E': // extended parameters - ignore for now readbytes(5); empty_reply(); break;
case 'P': start_pmode(); empty_reply(); break; case 'U': here = getch() + 256 * getch(); empty_reply(); break;
case 0x60: //STK_PROG_FLASH low = getch(); high = getch(); empty_reply(); break; case 0x61: //STK_PROG_DATA data = getch(); empty_reply(); break;
case 0x64: //STK_PROG_PAGE program_page(); break; case 0x74: //STK_READ_PAGE read_page(); break;
case 'V': universal(); break; case 'Q': error=0; end_pmode(); empty_reply(); break; case 0x75: //STK_READ_SIGN read_signature(); break;
// expecting a command, not CRC_EOP // this is how we can get back in sync case CRC_EOP: Serial.print((char) STK_NOSYNC); break; // anything else we will return STK_UNKNOWN default: if (CRC_EOP == getch()) Serial.print((char)STK_UNKNOWN); else Serial.print((char)STK_NOSYNC); } }
« Reply #3 on: November 25, 2012, 05:22:08 am » |
slight alteration to delay(40) to (20) and i think thats it // this sketch turns the Arduino into a AVRISP // using the following pins: // 10: slave reset // 11: MOSI // 12: MISO // 13: SCK
// Put an LED (with resistor) on the following pins: // 9: Heartbeat - shows the programmer is running // 8: Error - Lights up if something goes wrong (use red if that makes sense) // 7: Programming - In communication with the slave // // October 2009 by David A. Mellis // - Added support for the read signature command // // February 2009 by Randall Bohn // - Added support for writing to EEPROM (what took so long?) // Windows users should consider WinAVR's avrdude instead of the // avrdude included with Arduino software. // // January 2008 by Randall Bohn // - Thanks to Amplificar for helping me with the STK500 protocol // - The AVRISP/STK500 (mk I) protocol is used in the arduino bootloader // - The SPI functions herein were developed for the AVR910_ARD programmer // - More information at http://code.google.com/p/mega-isp
void setup() { Serial.begin(9600); pinMode(7, OUTPUT); pulse(7, 2); pinMode(8, OUTPUT); pulse(8, 2); pinMode(9, OUTPUT); pulse(9, 2); }
parameter param;
// this provides a heartbeat on pin 9, so you can tell the software is running. uint8_t hbval=128; int8_t hbdelta=8; void heartbeat() { if (hbval > 192) hbdelta = -hbdelta; if (hbval < 32) hbdelta = -hbdelta; hbval += hbdelta; analogWrite(LED_HB, hbval); delay(20); }
commit(page);
return STK_OK; }
void read_signature() { if (CRC_EOP != getch()) { Serial.print((char) STK_NOSYNC); return; } Serial.print((char) STK_INSYNC); uint8_t high = spi_transaction(0x30, 0x00, 0x00, 0x00); Serial.print((char) high); uint8_t middle = spi_transaction(0x30, 0x00, 0x01, 0x00); Serial.print((char) middle); uint8_t low = spi_transaction(0x30, 0x00, 0x02, 0x00); Serial.print((char) low); Serial.print((char) STK_OK); } ////////////////////////////////////////// ////////////////////////////////////////// 1/2
« Reply #4 on: November 25, 2012, 05:22:40 am » |
« Reply #5 on: November 25, 2012, 05:24:14 am » |
2011 version #include "SPI.h" #include "pins_arduino.h" #define RESET SS
#define LED_HB 9 #define LED_ERR 8 #define LED_PMODE 7 #define PROG_FLICKER true
void setup() { Serial.begin(9600); SPI.setDataMode(0); SPI.setBitOrder(MSBFIRST); // Clock Div can be 2,4,8,16,32,64, or 128 SPI.setClockDivider(SPI_CLOCK_DIV128); pinMode(LED_PMODE, OUTPUT); pulse(LED_PMODE, 2); pinMode(LED_ERR, OUTPUT); pulse(LED_ERR, 2); pinMode(LED_HB, OUTPUT); pulse(LED_HB, 2); }
#define beget16(addr) (*addr * 256 + *(addr+1) ) typedef struct param { uint8_t devicecode; uint8_t revision; uint8_t progtype; uint8_t parmode; uint8_t polling; uint8_t selftimed; uint8_t lockbytes; uint8_t fusebytes; uint8_t flashpoll; uint16_t eeprompoll; uint16_t pagesize; uint16_t eepromsize; uint32_t flashsize; } parameter;
parameter param;
uint8_t getch() { while(!Serial.available()); return Serial.read(); } void fill(int n) { for (int x = 0; x < n; x++) { buff[x] = getch(); } }
void prog_lamp(int state) { if (PROG_FLICKER) digitalWrite(LED_PMODE, state); }
uint8_t spi_transaction(uint8_t a, uint8_t b, uint8_t c, uint8_t d) { uint8_t n; SPI.transfer(a); n=SPI.transfer(b); //if (n != a) error = -1; n=SPI.transfer(c); return SPI.transfer(d); }
void empty_reply() { if (CRC_EOP == getch()) { Serial.print((char)STK_INSYNC); Serial.print((char)STK_OK); } else { error++; Serial.print((char)STK_NOSYNC); } }
void breply(uint8_t b) { if (CRC_EOP == getch()) { Serial.print((char)STK_INSYNC); Serial.print((char)b); Serial.print((char)STK_OK); } else { error++; Serial.print((char)STK_NOSYNC); } }
void set_parameters() { // call this after reading paramter packet into buff[] param.devicecode = buff[0]; param.revision = buff[1]; param.progtype = buff[2]; param.parmode = buff[3]; param.polling = buff[4]; param.selftimed = buff[5]; param.lockbytes = buff[6]; param.fusebytes = buff[7]; param.flashpoll = buff[8]; // ignore buff[9] (= buff[8]) // following are 16 bits (big endian) param.eeprompoll = beget16(&buff[10]); param.pagesize = beget16(&buff[12]); param.eepromsize = beget16(&buff[14]);
void start_pmode() { SPI.begin(); digitalWrite(RESET, HIGH); pinMode(RESET, OUTPUT); digitalWrite(SCK, LOW); delay(20); digitalWrite(RESET, LOW); spi_transaction(0xAC, 0x53, 0x00, 0x00); pmode = 1; }
void end_pmode() { SPI.end(); digitalWrite(RESET, HIGH); pinMode(RESET, INPUT); pmode = 0; }
fill(4); ch = spi_transaction(buff[0], buff[1], buff[2], buff[3]); breply(ch); }
void flash(uint8_t hilo, int addr, uint8_t data) { spi_transaction(0x40+8*hilo, addr>>8 & 0xFF, addr & 0xFF, data); } void commit(int addr) { if (PROG_FLICKER) prog_lamp(LOW); spi_transaction(0x4C, (addr >> 8) & 0xFF, addr & 0xFF, 0); if (PROG_FLICKER) { delay(PTIME); prog_lamp(HIGH); } }
void write_flash(int length) { fill(length); if (CRC_EOP == getch()) { Serial.print((char) STK_INSYNC); Serial.print((char) write_flash_pages(length)); } else { error++; Serial.print((char) STK_NOSYNC); } }
uint8_t write_flash_pages(int length) { int x = 0; int page = current_page(here); while (x < length) { if (page != current_page(here)) { commit(page); page = current_page(here); } flash(LOW, here, buff[x++]); flash(HIGH, here, buff[x++]); here++; }
commit(page);
return STK_OK; }
#define EECHUNK (32) uint8_t write_eeprom(int length) { // here is a word address, get the byte address int start = here * 2; int remaining = length; if (length > param.eepromsize) { error++; return STK_FAILED; } while (remaining > EECHUNK) { write_eeprom_chunk(start, EECHUNK); start += EECHUNK; remaining -= EECHUNK; } write_eeprom_chunk(start, remaining); return STK_OK; } // write (length) bytes, (start) is a byte address uint8_t write_eeprom_chunk(int start, int length) { // this writes byte-by-byte, // page writing may be faster (4 bytes at a time) fill(length); prog_lamp(LOW); for (int x = 0; x < length; x++) { int addr = start+x; spi_transaction(0xC0, (addr>>8) & 0xFF, addr & 0xFF, buff[x]); delay(45); } prog_lamp(HIGH); return STK_OK; }
void program_page() { char result = (char) STK_FAILED; int length = 256 * getch(); length += getch(); char memtype = getch(); // flash memory @here, (length) bytes if (memtype == 'F') { write_flash(length); return; } if (memtype == 'E') { result = (char)write_eeprom(length); if (CRC_EOP == getch()) { Serial.print((char) STK_INSYNC); Serial.print(result); } else { error++; Serial.print((char) STK_NOSYNC); } return; } Serial.print((char)STK_FAILED); return; }
char eeprom_read_page(int length) { // here again we have a word address int start = here * 2; for (int x = 0; x < length; x++) { int addr = start + x; uint8_t ee = spi_transaction(0xA0, (addr >> 8) & 0xFF, addr & 0xFF, 0xFF); Serial.print((char) ee); } return STK_OK; }
void read_page() { char result = (char)STK_FAILED; int length = 256 * getch(); length += getch(); char memtype = getch(); if (CRC_EOP != getch()) { error++; Serial.print((char) STK_NOSYNC); return; } Serial.print((char) STK_INSYNC); if (memtype == 'F') result = flash_read_page(length); if (memtype == 'E') result = eeprom_read_page(length); Serial.print(result); return; }
void read_signature() { if (CRC_EOP != getch()) { error++; Serial.print((char) STK_NOSYNC); return; } Serial.print((char) STK_INSYNC); uint8_t high = spi_transaction(0x30, 0x00, 0x00, 0x00); Serial.print((char) high); uint8_t middle = spi_transaction(0x30, 0x00, 0x01, 0x00); Serial.print((char) middle); uint8_t low = spi_transaction(0x30, 0x00, 0x02, 0x00); Serial.print((char) low); Serial.print((char) STK_OK); } ////////////////////////////////////////// //////////////////////////////////////////
1/2
« Reply #6 on: November 25, 2012, 05:25:14 am » |
2/2 //////////////////////////////////// //////////////////////////////////// int avrisp() { uint8_t data, low, high; uint8_t ch = getch(); switch (ch) { case '0': // signon error = 0; empty_reply(); break; case '1': if (getch() == CRC_EOP) { Serial.print((char) STK_INSYNC); Serial.print("AVR ISP"); Serial.print((char) STK_OK); } else { error++; Serial.print((char) STK_NOSYNC); } break; case 'A': get_version(getch()); break; case 'B': fill(20); set_parameters(); empty_reply(); break; case 'E': // extended parameters - ignore for now fill(5); empty_reply(); break;
case 'P': if (pmode) { pulse(LED_ERR, 3); } else { start_pmode(); } empty_reply(); break; case 'U': // set address (word) here = getch(); here += 256 * getch(); empty_reply(); break;
case 0x74: //STK_READ_PAGE 't' read_page(); break;
case 'V': //0x56 universal(); break; case 'Q': //0x51 error=0; end_pmode(); empty_reply(); break;
case 0x75: //STK_READ_SIGN 'u' read_signature(); break;
// expecting a command, not CRC_EOP // this is how we can get back in sync case CRC_EOP: error++; Serial.print((char) STK_NOSYNC); break;
// anything else we will return STK_UNKNOWN default: error++; if (CRC_EOP == getch()) Serial.print((char)STK_UNKNOWN); else Serial.print((char)STK_NOSYNC); } }
« Reply #7 on: November 25, 2012, 05:26:05 am » |
heres my boards.txt, this isnt the full list just what im trying to bootload ##############################################################
atmega8.name=ATmega8-noxtal @8MHz
atmega8.upload.protocol=arduino atmega8.upload.maximum_size=7168 atmega8.upload.speed=38400
atmega8.bootloader.low_fuses=0xe4 atmega8.bootloader.high_fuses=0xc2 atmega8.bootloader.path=atmega8_noxtal atmega8.bootloader.file=ATmegaBOOT.hex atmega8.bootloader.unlock_bits=0x3F atmega8.bootloader.lock_bits=0x0F
atmega8.build.mcu=atmega8 atmega8.build.f_cpu=8000000L atmega8.build.core=arduino atmega8.build.variant=standard
atmega8.name=Arduino NG or older w/ ATmega8
atmega8.upload.protocol=stk500 atmega8.upload.maximum_size=7168 atmega8.upload.speed=19200
atmega8.bootloader.low_fuses=0xdf atmega8.bootloader.high_fuses=0xca atmega8.bootloader.path=atmega8 atmega8.bootloader.file=ATmegaBOOT.hex atmega8.bootloader.unlock_bits=0x3F atmega8.bootloader.lock_bits=0x0F
atmega8.build.mcu=atmega8 atmega8.build.f_cpu=16000000L atmega8.build.core=arduino
atmega8bb.name=ATmega8 on a breadboard (8 MHz internal clock)
atmega8bb.upload.protocol=stk500 atmega8bb.upload.maximum_size=7168 atmega8bb.upload.speed=19200
atmega8bb.bootloader.low_fuses=0xD4 atmega8bb.bootloader.high_fuses=0xCA atmega8bb.bootloader.path=arduino:atmega8 atmega8bb.bootloader.file=ATmegaBOOT.hex atmega8bb.bootloader.unlock_bits=0x3F atmega8bb.bootloader.lock_bits=0x2F
atmega8bb.build.mcu=atmega8 atmega8bb.build.f_cpu=8000000L atmega8bb.build.core=arduino:arduino
atmega8noxtal.name=ATmega8-noxtal @8MHz
atmega8noxtal.upload.protocol=stk500 atmega8noxtal.upload.maximum_size=7168 atmega8noxtal.upload.speed=19200
atmega8noxtal.bootloader.low_fuses=0xe4 atmega8noxtal.bootloader.high_fuses=0xc4 atmega8noxtal.bootloader.path=atmega8 atmega8noxtal.bootloader.file=ATmegaBOOT.hex atmega8noxtal.bootloader.unlock_bits=0x3F atmega8noxtal.bootloader.lock_bits=0x0F
atmega8noxtal.build.mcu=atmega8 atmega8noxtal.build.f_cpu=8000000L atmega8noxtal.build.core=arduino
atmega8.name=Arduino NG8 mhz
atmega8.bootloader.low_fuses=0xe4 atmega8.bootloader.high_fuses=0xd1 atmega8.bootloader.path=atmega8 atmega8.bootloader.file=ATmegaBOOT.hex atmega8.bootloader.unlock_bits=0x3F atmega8.bootloader.lock_bits=0x0F
as you can see ive got quite a few boards ive tried already with avrdude: stk500_recv(): programmer is not responding when i use a pull-up resistor and avrdude: stk500_getsync(): not in sync: resp=0x## with different # each time and even sometimes get avrdude: stk500_getsync(): not in sync: expect:0x## or something to that effect, im stressing hard guys i need your help somebody anybody tell me what im doing wrong and what i need to do to fix this problem, or atleast a step in the right direction, please for the love of god DO NOT "LINK" TUTORIALS just lay out what i need to do HERE
« Reply #8 on: November 25, 2012, 01:24:47 pm » |
Follow this tutorial: http://pdp11.byethost12.com/AVR/ArduinoAsProgrammer.htmReplace the atmega328p with your atmega8 and do not add any crystal and capacitors. By doing so you can burn any code you like in your atmega8, including a bootloader if you really want to write one. In most cases, for stand alone applications, the bootloader is not necessary.
United Kingdom
« Reply #9 on: November 25, 2012, 01:51:34 pm » |
If you don't use a crystal or ceramic resonator on your atmel mcu, then the clock frequency will very probably not be accurate enough for the bootloader to work even if you do manage to burn it. However, you can still use ArduinoISP to upload your sketch directly, without a bootloader. See http://miscsolutions.wordpress.com/2011/08/09/prototyping-small-embedded-projects-with-arduino/ for how I used to do it before I purchased an AVRISPmkII.
Left Coast, CA (USA)
Measurement changes behavior
« Reply #10 on: November 25, 2012, 02:00:51 pm » |
Good point. And now that the IDE has a 'upload using programmer' option one can really easily live without messing with bootloaders at all. And seeing that an arduino board running the arduinoISP sketch becomes a hardware programmer, there is a lot to be said for just not messing with bootloaders. Just think your mega boards won't suffer if you want to use the WDT or if your compiled code happens to have a !!! string for random data in it, it won't hang the upload. One could make a good argument to 'just say no' when the subject of bootloaders come up.  Lefty
« Reply #11 on: November 25, 2012, 03:37:06 pm » |
Follow this tutorial: http://pdp11.byethost12.com/AVR/ArduinoAsProgrammer.htmReplace the atmega328p with your atmega8 and do not add any crystal and capacitors. By doing so you can burn any code you like in your atmega8, including a bootloader if you really want to write one. In most cases, for stand alone applications, the bootloader is not necessary. ive been to that page (which i said not to link) and it failed with same errors, try again and this time READ MY POST
Melbourne, Australia
Shannon Member
Lua rocks!
« Reply #12 on: November 25, 2012, 03:47:03 pm » |
You can attach files to your post you know. Making 7 posts just to attach files is a mis-use of the forum. You can attach multiple files, or make a single .zip file. please for the love of god DO NOT "LINK" TUTORIALS just lay out what i need to do HERE If there is a tutorial, that explains what to do, why should it be copied and pasted here, when you just have to go to a link? The tutorial might have photos, etc.
« Reply #13 on: November 25, 2012, 03:49:48 pm » |
You can attach files to your post you know. Making 7 posts just to attach files is a mis-use of the forum. You can attach multiple files, or make a single .zip file. please for the love of god DO NOT "LINK" TUTORIALS just lay out what i need to do HERE If there is a tutorial, that explains what to do, why should it be copied and pasted here, when you just have to go to a link? The tutorial might have photos, etc. ive never used forums before and so i didnt know you could attach files, as for the linking im just tired of sifting thru bullshit just to find out it didnt work, i just want short simple answers to whats wrong
UK
« Reply #14 on: November 25, 2012, 03:50:13 pm » |
OP, please DO NOT hit the "report to moderator" control again.
