Topic: ArduinoISP Arduino uno & blank atmega8 bootloader burn trouble (Read 23732 times) previous topic - next topic
nickgammon
... im gonna give this a fair shake and read in detail as a favor to myself to atleast give one more chance ...
Good work. I made up that sketch because I wanted to be able to program without all those annoying messages from avrdude.
I warn you that I don't have an Atmega8 (I might order one) so that isn't actually tested with one. It did work with all the other chips I tried in the post.
However at the very least it should report the chip signature, like this:
Atmega chip programmer.
Written by Nick Gammon.
Entered programming mode OK.
Signature = 0x1E 0x95 0x0F
Processor = ATmega328P
Flash memory size = 32768 bytes.
LFuse = 0xFF
HFuse = 0xDE
EFuse = 0xFD
Lock byte = 0xCF
Bootloader address = 0x7E00
Bootloader length = 512 bytes.
(Of course yours will be a different signature).
That will prove that you can "talk" to the chip, and that your wires are around the right way etc.
These messages appear in the Serial Monitor so make sure you turn that on after uploading the sketch, and set it to 115200 baud.
I believe I incorporated the correct bootloader into the sketch, as someone else had asked about it a while back.
simplex
#31
Nov 25, 2012, 10:29 pm Last Edit: Nov 25, 2012, 10:32 pm by simplex Reason: 1
Quote from: mysteredding
because i was looking for arduinoisp error fixes not a whole new method of use, when i get done with this other tutorial if it doesnt work i'll give yours a look and try again
This is a completely different story. You should have told it from the beginning.
mysteredding
im gonna be hella mad if it doesnt work
Likely microcontrollers and electronics in general are not for you.
It is self evident you have not read any help page from the beginning to the end. You do not have enough patience.
apparently you have never met me and therefore dont know me so dont go making an assumption about me thats obviously wrong, ive been repairing electronics for YEARS and working with arduino for only 1 so im still very new to it, but if you arent gonna give help and just criticize then dont post again
nickgammon
You shouldn't need a crystal, by the way.
Just as a heads-up, I think those chips are usually shipped to run off the internal 8 MHz oscillator, with the "divide clock by 8" fuse set. My programmer should work OK, I've used it with other "fresh" chips, but you might find you need to alter the fuse to get it up to full speed (once you have the bootloader on it). If you don't, it will be running at the wrong baud rate and the bootloader will appear not to be working.
mysteredding
i had noticed tho your tutorial doesnt incorporate completely blank(no-bootloader) bare(no-crystal) microcontrollers, have you tried it that way to see if itll work? im trying to get as much info on this as i can before i try it
mysteredding
(from tutorial) Type 'L' to use Lilypad (8 MHz) loader, or 'U' for Uno (16 MHz) loader
is that for the chip being bootloaded(blank chip)?
mysteredding
somewhere along the line i got this error
/usr/share/arduino/hardware/arduino/cores/arduino/Arduino.h:212:26: fatal error: pins_arduino.h: No such file or directory
compilation terminated.
mysteredding
this is all i get, then hit reset
nickgammon
Perhaps not on that page, but on this one I did:
http://www.gammon.com.au/forum/?id=11637
Example:
nickgammon
Yes, that's for the target chip. It only asks that for an Atmega328P. One answer gives you an 8 MHz internal oscillator bootloader, the other one gives you the 16 MHz bootloader.
nickgammon
Right. That indicates that you are not succesfully "talking" to the target chip. I think the wiring is the same as the Atmega328 so your wiring should exactly match the photo above.
mysteredding
ive read your second tutorial and im guessing my 3rd party order has a pre-loaded bootloader to need a crystal, ive got some rip-outs(salvaged from old electronics) ive got a 13.#### mhz it fits onto that 4-20 range but am very limited on capacitors to use with it, are the capacitor numbers crucial to the crystal? or can i use some 47pico? and im not even sure about that number either i bought em took em out of package and forgot about em for a good while
nickgammon
See this photo:
Note the extra "clock" wire. That should be enough to clock the chip over. I'm pretty sure it worked for me.
mysteredding
tell you what Nick, you gave me a hell of a step in the right direction, plugging the crystal in and whatever capacitors im using(22j ceramic) which im guessing are the 22pico i needed read the chip found out yea it has a bootloader on it, im gonna try all i can to get this to work now, and thank you very much for having so much patients with me even tho my attitude was less than deserving of it, and i saw how busy you were helping everyone else, i really do appreciate everything you've done
nickgammon
That could work, plus there's a school of thought that the stray capacitance on the breadboard will be enough.
