Topic: uint64_t in Serial.print (Read 17149 times) previous topic - next topic
sspence65
Nov 25, 2012, 01:04 pm Last Edit: Nov 25, 2012, 07:36 pm by Steve Spence - KK4HFJ Reason: 1
I'm working with the Card info sketch in the sd examples, and my 16gb sd card reports as 3gb. It's my understanding that this is a result of Serial.print only understanding uint32_t. I've tried editing print.h to understand long long int, but it's not taking.
What am I not understanding?
   size_t print(const __FlashStringHelper *);
   size_t print(const String &);
   size_t print(const char[]);
   size_t print(char);
   size_t print(unsigned char, int = DEC);
   size_t print(int, int = DEC);
   size_t print(unsigned int, int = DEC);
   size_t print(long, int = DEC);
//size_t print(long long, int = DEC);
   size_t print(unsigned long, int = DEC);
//size_t print(unsigned long long, int = DEC);
   size_t print(double, int = 2);
   size_t print(const Printable&);
   size_t println(const __FlashStringHelper *);
   size_t println(const String &s);
   size_t println(const char[]);
   size_t println(char);
   size_t println(unsigned char, int = DEC);
   size_t println(int, int = DEC);
   size_t println(unsigned int, int = DEC);
   size_t println(long, int = DEC);
//size_t println(long long, int = DEC);
   size_t println(unsigned long, int = DEC);
//size_t println(unsigned long long, int = DEC);
   size_t println(double, int = 2);
   size_t println(const Printable&);
   size_t println(void);
Steve Spence - ET/AT/R&D KK4HFJ
robtillaart
add this to print.cpp and the signatures to print.h - be aware long long is slow slow ;)
void Print::println(long long n, int base)
  print(n, base);
  println();
void Print::print(long long n, int base)
  if (n < 0) write('-');
  if (base == 0) write(n);
  else printLLNumber(n, base);
void Print::println(unsigned long long n, int base)
  print(n, base);
  println();
void Print::print(unsigned long long n, int base)
void Print::printLLNumber(unsigned long long n, uint8_t base)
  unsigned char buf[16 * sizeof(long)]; // Assumes 8-bit chars.
  unsigned long long i = 0;
  if (n == 0) {
    print('0');
    return;
  while (n > 0) {
    buf[i++] = n % base;
    n /= base;
  for (; i > 0; i--)
    print((char) (buf[i - 1] < 10 ?
      '0' + buf[i - 1] :
      'A' + buf[i - 1] - 10));
Rob Tillaart
sspence65
I get
C:\Users\Steve\Programs\arduino-1.0.2\hardware\arduino\cores\arduino\nPrint.cpp:230: error: prototype for 'size_t Print::printNumber(long long unsigned int, uint8_t)' does not match any in class 'Print'
C:\Users\Steve\Programs\arduino-1.0.2\hardware\arduino\cores\arduino\/Print.h:38: error: candidate is: size_t Print::printNumber(long unsigned int, uint8_t)
When I run
 SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
 * SD card attached to SPI bus as follows:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module.
Pin 4 used here for consistency with other Arduino examples
created  28 Mar 2011
by Limor Fried
modified 9 Apr 2012
by Tom Igoe
// include the SD library:
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
const int chipSelect = 4;
  while (!Serial) {
   ; // wait for serial port to connect. Needed for Leonardo only
 Serial.print("\nInitializing SD card...");
 // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
 // Note that even if it's not used as the CS pin, the hardware SS pin
 // (10 on most Arduino boards, 53 on the Mega) must be left as an output
 // or the SD library functions will not work.
 pinMode(10, OUTPUT);     // change this to 53 on a mega
 // we'll use the initialization code from the utility libraries
 // since we're just testing if the card is working!
 if (!card.init(SPI_HALF_SPEED, chipSelect)) {
   Serial.println("initialization failed. Things to check:");
   Serial.println("* is a card is inserted?");
   Serial.println("* Is your wiring correct?");
   Serial.println("* did you change the chipSelect pin to match your shield or module?");
   return;
  Serial.println("Wiring is correct and a card is present.");
 // print the type of card
 Serial.print("\nCard type: ");
 switch(card.type()) {
   case SD_CARD_TYPE_SD1:
     Serial.println("SD1");
     break;
   case SD_CARD_TYPE_SD2:
     Serial.println("SD2");
     break;
   case SD_CARD_TYPE_SDHC:
     Serial.println("SDHC");
     break;
   default:
     Serial.println("Unknown");
 // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
 if (!volume.init(card)) {
   Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
   return;
 // print the type and size of the first FAT-type volume
 uint64_t volumesize;
 Serial.print("\nVolume type is FAT");
 Serial.println(volume.fatType(), DEC);
 Serial.println();
 volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
 volumesize *= volume.clusterCount();       // we'll have a lot of clusters
 // volumesize *= 512;                            // SD card blocks are always 512 bytes
 // Serial.print("Volume size (bytes): ");
 // Serial.println(volumesize);
 Serial.print("Volume size (Kbytes): ");
 // volumesize /= 1024;
 volumesize /= 2;
 Serial.print("Volume size (Mbytes): ");
 volumesize /= 1024;
 Serial.println("\nFiles found on the card (name, date and size in bytes): ");
 root.openRoot(volume);
 // list all files in the card with date and size
 root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
WizenedEE
sspence65
I attached print.h
Does it look correct?
robtillaart
#5
Nov 25, 2012, 06:19 pm Last Edit: Nov 25, 2012, 07:09 pm by robtillaart Reason: 1
I'll will try the code myself, be back asap
[update]
unexpected conflicts - pity ...
Rob Tillaart
robtillaart
a workaround: print it in 2 steps
  Serial.println("start...");
  uint64_t ll = 123456789012345678ULL;
  uint64_t xx = ll/1000000000ULL;
  if (xx >0) Serial.print((long)xx);
  Serial.print((long)(ll-xx*1000000000));
void loop(){}
Rob Tillaart
sspence65
ok. I get
start...
12345678912345678
robtillaart
does this 'trick' solve your problem enough?
An "integrated solution" is more difficult than I expected.
I also had a quick look at - http://www.nongnu.org/avr-libc/user-manual/modules.html - but found no solutions there either.
Rob Tillaart
sspence65
Not sure how to merge that into the sd cardinfo sketch .....
robtillaart
becomes
  uint64_t xx = volumesize/1000000000ULL;
  Serial.print((long)(volumesize - xx*1000000000));
give it a try
Rob Tillaart
sspence65
I get:
Initializing SD card...Wiring is correct and a card is present.
Card type: SDHC
Volume type is FAT32
Volume size (bytes): 31099904
DCIM/         2011-06-20 14:58:52
 100_PANA/     2011-06-20 19:07:48
   P1000812.JPG  2011-09-08 09:19:54 4158647
   P1000781.JPG  2011-08-20 21:02:02 4309863
   P1000813.JPG  2011-09-08 09:20:00 4258311
robtillaart
Is this what you expected? if not what did you expect?
Rob Tillaart
sspence65
I was expecting somewhere around 16,000,000,000 bytes .....
robtillaart
can you post your complete code again?
Rob Tillaart
