I read the part of the datasheet. The complete 16-bit set can be accessed by reading " TCNT1 " according to 16.11.4 "The two Timer/Counter I/O locations (TCNT1H and TCNT1L, combined TCNT1) give direct access, both for read and for write operations, to the Timer/Counter unit 16-bit counter."
Correct result shown. Thanks for your hint to the right part of the datasheet
#include <avr/io.h>
#include <avr/interrupt.h>
#define LEDPIN 13
int timer;
long counter;
pinMode(LEDPIN, OUTPUT);
cli(); // disable global interrupts
pinMode(2, INPUT); // Enable Pin2 as input to interrupt
EIMSK |= (1 << INT0); // Enable external interrupt INT0 (see table 13-2-2 in Atmel 328 spec)
EICRA |= (1 << ISC01); // Trigger INT0 on rising edge (see table 13-1 in Atmel 328 spec)
EICRA |= (1 << ISC00); // Trigger INT0 on riding edge (see table 13-1 in Atmel 328 spec)
// initialize Timer1
// ZERO Timer1
TCCR1A = 0; // set entire TCCR1A register to 0
TCCR1B = 0; // same for TCCR1B
// set compare match register to desired timer count:
OCR1A = 7000; // turn on CTC mode:initial value changed in loop
OCR1B = 14000; // turn on CTC mode:initial value changed in loop
//TCCR1B |= (1 << WGM12); // Set CTC mode. Resets the timer after compA has been reached
TCCR1B |= (1 << CS10); // prescaler 1024
TCCR1B |= (1 << CS12); // prescaler 1024
TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt:
TIMSK1 |= (1 << OCIE1B); // enable timer compare interrupt:
sei(); // Enable global interrupts
ISR(TIMER1_COMPA_vect){
counter= TCNT1;
digitalWrite(LEDPIN, HIGH);
counter= TCNT1;
Serial.print ("counteran:");
Serial.println(counter);
ISR(TIMER1_COMPB_vect){
digitalWrite(LEDPIN, LOW);
Serial.print ("counteraus:");
counter= TCNT1;
TCNT1 = 0; // Reset Timer1 Count
