Topic: analogRead problem (Read 1 time) previous topic - next topic
zdillman
Nov 26, 2012, 01:26 am Last Edit: Nov 26, 2012, 01:53 am by zdillman Reason: 1
I'm running this code,
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial mySerial(0,1);
int val = 0;
  mySerial.begin(9600);
  val = analogRead(2);
  mySerial.println(val);
  delay(3000);
on an ATTiny85 and I'm measuring the voltage through one of the analog inputs. I am using a bench DC power supply and it's staying at a constant voltage, but the serial print that it does when it reads a voltage is erratic, and inconsistent. I have tried averaging, as seen in the code, but it doesn't seem to help. Please take a look!
Here's the serial output.
736
724
860
712
751
856
696
790
838
687
822
816
673
850
797
686
868
765
706
870
736
728
861
708
756
851
691
791
833
682
824
815
674
852
790
686
869
756
708
867
725
735
860
704
762
Edit: Changed code to test code. Same situation.
marcello.romani
What is connected to analog 3?
zdillman
A small votage under 5 volts, specifically 3.9v. I just wrote this code really quickly to just test the voltage and it's still giving me erratic numbers.
Code: [Select]
int val = 0;
  delay(3000);
483
464
451
440
438
436
438
443
457
465
464
It should be around 700, not around 400.
Coding Badly
Is the small voltage connected to analog pin 2 or digital pin 2...
http://arduino.cc/forum/index.php/topic,87517.msg657039.html#msg657039
Coding Badly
Which core are you using?
zdillman
I'm using Pin 2, (Analog input 1).
What do you mean by core?
dhenry
Quote
Nice random number generators.
dhenry
Quote
Check against your code, :)
zdillman
In the revised test code I'm using the 2. I've also used 3 and 4 with the same results.
Coding Badly
[font=Courier New]void loop() {
 val = analogRead(  2  );
[/font]
Which analog pin are you using?
Quote
You downloaded something to add support for the ATtiny85 processor to the Arduino IDE.  Where did you get the download?
zdillman
I am using analog pin 1, but it is pin 2 in the pinout chart. I am using a core I found that is from here. http://code.google.com/p/arduino-tiny/downloads/detail?name=arduino-tiny-0022-0008.zip&can=2&q=
This added support for the Tone function, which I need once I can get the analogread to work properly.
zdillman
dhenry
Quote
Any ideas?
Reading some documents on Aruidno and its functions would be greatly helpful to you now.
zdillman
I've found the pin diagram in the core I am using. Could someone tell me what I should put in the parenthesis for analogRead() for analog input 1?
//  Ain0       (D  5)  PB5  1|    |8   VCC
//  Ain3       (D  3)  PB3  2|    |7   PB2  (D  2)  INT0  Ain1
//  Ain2       (D  4)  PB4  3|    |6   PB1  (D  1)        pwm1
//                        GND  4|    |5   PB0  (D  0)        pwm0
dhenry
