Pages: 1 [2]   Go Down
Author Topic: analogRead problem  (Read 801 times)
Offline Offline
Newbie
View Profile
I tried 1 and it gave me odd numbers again. A1 does the same thing.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Then perhaps the problem is an electrical one with the signal going to the analog input pin. What is it's output impedenace? Is there a common ground wired from the arduino to the circuit supplying the measurement signal?
One way to test your software is to remove your signal wire from the analog pin and first wire a ground to the analog input pin and see if your raw count value is a stable 0 value, then remove the ground wire and wire from the shield 5V pin to the analog input pin and see if your raw count value is a stable 1023 value.
Lefty
Logged
0
Offline Offline
God Member
Get Bitlash: http://bitlash.net
View Profile
I'm guessing door number 2.  Is it hard to test the other free pins in your setup?
-br
Edit: Nevermind.  The data sheet confirms (p. 63) pin 7 / PB2 is analog input channel 1.  But I would still test the other pins if it's quick… fortune favors those with a slight distrust for the documentation.
« Last Edit: November 25, 2012, 09:23:35 pm by billroy » Logged
Pages: 1 [2]   Go Up
Jump to:
