Loading...
Pages: [1]   Go Down
Author Topic: question of code display  (Read 281 times)
Offline Offline
Newbie
View Profile
i connect ct sensor to arduino and i connect lcd to arduino.
i want to read analog input (current of lamp) and display the value to lcd
this code is true:
#include <LiquidCrystal.h> // include the LCD library
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int analogPin = A0;
int val = 0;
  Serial.begin(9600);          //  setup serial
lcd.begin(16, 2); // lcd rows and columns
    lcd.print("lampe"); // title
  val = analogRead(analogPin);    // read the input pin
lcd.setCursor(0, 1);
  lcd.print("lampe=");
   lcd.print(val);
  Serial.println(val);             // debug value
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
What is the question?
Logged
Offline Offline
Newbie
View Profile
if code is true?
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Does it compile? What happens when you run it?
You might need to add
Code:
#include <Wire.h>
at the top.
« Last Edit: November 27, 2012, 05:33:06 am by dxw00d » Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
if code is true?
If you are asking if the code does what you want it to, only you can answer that.  Run the code and see.  It will not harm your Arduino to try.
Logged
Pages: [1]   Go Up
Print
Jump to:
