Topic: display stored string using 8uglib (Read 785 times) previous topic - next topic
djosimd
im kind of a newbie on arduino and i need help from experts :p
I've been able to display pretty much what i want on my GLCD TF7565 using th u8glib library. I'm able to display a string using this commande
u8g.drawStr(0, 0, "hello world");
but i want to display a double that i converted to a string but when i do something like this:
String testString;
//code puting a double value in testString
u8g.drawStr(0, 0, testString);
the program is giving  me an error while compiling, it says:
no matching function for call to 'U8GLIB_LM6059::drawStr(int,int,String&)
im i doing something wrong or its just impossible to display a previously stored String using the u8glib library ?
Thank you !
olikraus
I assume, that you need to convert the String object to a character array before passing it to drawStr.
Use http://arduino.cc/en/Reference/StringToCharArray.
Oliver
djosimd
I just tried it and its working Thank you so much !!!!
bperrybap
#3
Nov 26, 2012, 11:52 pm Last Edit: Nov 26, 2012, 11:56 pm by bperrybap Reason: 1
glcd includes overloaded functions to handle all the string types.
For String it uses an overloaded wrapper function to handle it.
For u8g, It would be something like:
u8g_uint_t U8GLIB::drawStr(u8g_uint_t x, u8g_uint_t y, String &str )
  return( drawStr(x, y, str));
--- bill
