Topic: input from barcode (Read 7419 times) previous topic - next topic
maddave
error: 'cardcnt' was not declared in scope
PaulS
Code: [Select]
int bufferLength = 64;
After this: // <-- what's this?
Where did this:
Code: [Select]
int cardCnt = sizeof(goodCards)/sizeof(goodCards[0]);
disappear to?
maddave
scalar object 'goodCard' requires one element in initialiaer
maddave
think i better start again
PaulS
I'm sorry. This:
Code: [Select]
char *goodCards = { "3455192327218", "4005209057240", "5060048310337" };
should have been this:
Code: [Select]
char *goodCards[] = { "3455192327218", "4005209057240", "5060048310337" };
maddave
Code: [Select]
Barcode Scanner
This code reads the input from a ps/2 keyboard or keyboard-like
device (e.g. a barcode scanner), translates the scan-codes into
numbers (only numbers from 0 to 9 can be used at the moment)
It is nowhere near a complete implementation of the ps/2 protocol,
but it should give you a starting point.
mys .// Benjamin Maus ( benjamin.maus <at> allesblinkt.com )
2007
int SCAN_ENTER = 0x5a; int SCAN_BREAK = 0xf0;
int breakActive = 0;
int clockPin = 3; // Clock is only output.
int dataPin = 2; // The data pin is bi-directional
// But at the moment we are only interested in receiving
int ledPin = 13;  // When a SCAN_ENTER scancode is received the LED blink
int clockValue = 0; byte dataValue;
byte scanCodes[10] = {0x45,0x16,0x1e,0x26,0x25,0x2e,0x36,0x3d,0x3e,0x46}; char characters[10] = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9'};
int quantityCodes = 10;
char buffer[64] = {}; // This saves the characters (for now only numbers)
int bufferPos = 0;
pinMode(dataPin, INPUT);
pinMode(clockPin, INPUT);
pinMode(ledPin, OUTPUT);
dataValue = dataRead();
// If there is a break code, skip the next byte
if (dataValue == SCAN_BREAK) {
breakActive = 1;
// Translate the scan codes to numbers
// If there is a match, store it to the buffer
for (int i = 0; i < quantityCodes; i++) {
byte temp = scanCodes[i];
if(temp == dataValue){
if(!breakActive == 1){
buffer[bufferPos] = characters[i];
bufferPos++;
//Serial.print('*'); // Output an asterix for every byte
// Print the buffer if SCAN_ENTER is pressed.
if(dataValue == SCAN_ENTER){
Serial.print("\nbuffer: ");
// Read the buffer
int goodMatch = -1;
for(int c=0; c<cardCnt; c++)
   if(strcmp(buffer, goodCards[c]) == 0)
      goodMatch = c;
Serial.print("goodMatch  = ");
Serial.println(goodMatch);     // Will print index of good card in array
                int i=0;
if (buffer[i] != 0) {
while(buffer[i] != 0) {
Serial.print( buffer[i] );
buffer[i] = 0;
i++;
Serial.println(" [Enter]");
bufferPos = 0;
// Blink the LED
digitalWrite(ledPin, HIGH);
delay(300);
digitalWrite(ledPin, LOW);
int goodMatch = -1;
      goodMatch = c;
Serial.println(goodMatch);     // Will print index of good card in array// Reset the SCAN_BREAK state if the byte was a normal one
if(dataValue != SCAN_BREAK){
breakActive = 0;
dataValue = 0;
int dataRead() {
byte val = 0;
// Skip start state and start bit
while (digitalRead(clockPin));  // Wait for LOW.
// clock is high when idle
while (!digitalRead(clockPin)); // Wait for HIGH.
for (int offset = 0; offset < 8; offset++) {
val |= digitalRead(dataPin) << offset; // Add to byte
// Skipping parity and stop bits down here.
return val;
PaulS
See reply #16 - bottom half.
maddave
thanks for that but no matter what barcode i scan it prints good match even one's thats not registered
maddave
PaulS
One of the scans showed 40052005724. You said that the valid value was 4005209057240. Similar, but not the same. Try putting "40052005724" in the array.
johnwasser
will not complile
Change:
Code: [Select]
char *goodCards = {"3455192327218", "4005209057240", "5060048310337" };
to
Code: [Select]
const int cardCnt = 3;
char *goodCards[cardCnt] = { "3455192327218", "4005209057240", "5060048310337" };
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
maddave
For some reason the it is not reading all the number's … the barcode is 5060048310337 it  reads 5060041033. But this is not a problem as long as if reads the same number for that barcode every time ……. So is this how it should look  ?
