Loading...
Pages: [1]   Go Down
Author Topic: Consistent output with arduino  (Read 98 times)
Norway
Offline Offline
Newbie
Fresh and learning..
View Profile
WWW
Hi guys!
I have a little project that i could use some help with. I am quite new to the arduino, and not that steady in the code, but im hoping on getting there!
The project im building is a litte controller that drives a relay output. The controller is connected to a photo-cell that has a two pin output. This output is shorted at various times depending on the movement in front of the photocell.
What i need is for the arduino to close the relay for the same period (say 0,5s) each time the photocell circut is closed. And maybe block a repeating signal from the photocell within 0,5s
Is this possible in some way?
Any help much appreciated!
Logged
UK
Offline Offline
Tesla Member
View Profile
Connect the sensor so that the photocell state can be read at an input pin.
Write a sketch that reads the input pin state each time loop() is called. If the state has changed from 'open' to 'closed' then close the relay, wait for half a second, open the relay, wait another half second.
Logged
Pages: [1]   Go Up
Print
Jump to:
