« on: November 26, 2012, 08:53:06 pm » |
Hello friends! Im having a lot of trouble figuring this out. Im building a small rover, 3 WD with amni wheels, gunna be awesome, but i cant seems to find a motor shield that will supply 3 DC motors. I need at around 2 amps out of the motor and around 12 volts, i dont want it going insanely slow. The adfruit shield is only good for very small motors and the L298 only supports 2 motors. Can i make my own bridge. Advice? thanks for your time!
« Reply #2 on: November 26, 2012, 10:14:36 pm » |
can you controll speed and direction? with the transistor circuit?
United Kingdom
« Reply #3 on: November 27, 2012, 04:04:10 am » |
« Reply #4 on: November 27, 2012, 06:49:43 am » |
Is there enough room on the uno to fit three?
United Kingdom
« Reply #5 on: November 27, 2012, 07:28:42 am » |
Yes. To control each bridge you need only the DIR and PWM pins, so that's 2 pins per motor, 6 in total. If you want to set the current limit then you need the SPI pins as well (you may need them anyway to configure the device the way you want it), but the controllers can be daisy chained (see http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00268302.pdf). So that's 4 shared pins. If you also want to power all 3 down, you will need one more output pin to drive either the EN inputs or the DI inputs. Total 3 PWM pins and 7 normal outputs (8 if you want to power the drivers down to save battery). You still have 9 or 10 pins left, also 3 of the SPI pins can be shared with other SPI devices. BTW I've never used that board so I can't vouch for its quality, however the chip it is built around looks very nice. [EDIT: by "enough room" I assumed you meant "enough output pins". These are not shields so they do not plug directly on top of a Uno.]
« Last Edit: November 27, 2012, 07:32:23 am by dc42 »
« Reply #6 on: November 27, 2012, 09:44:15 am » |
yeah i did mean pins, that clear up a lot thanks. also do you know how many amps those bridges can support per motor? it wasnt on the description
United Kingdom
« Reply #7 on: November 27, 2012, 09:59:10 am » |
The chip (see datasheet I linked to before) has built-in current limiting which you can set (by SPI) to set 4 different current limits: 2.5A, 4A, 6.6A and 8.6A. At the higher end of that range you would probably need a fan to keep the heatsink cool.
« Reply #8 on: November 27, 2012, 11:05:18 am » |
But the link on ebay isnt a L9958 (the data sheet you sent me), and how do you daisy chain? Does all the stuff from the data sheet apply to that bridge? Thanks for all your time. Also can you run brushless motors on it?
« Last Edit: November 27, 2012, 11:18:44 am by amp625 »
United Kingdom
« Reply #9 on: November 27, 2012, 11:48:11 am » |
Good point. The eBay page says the unit is a SX8847. When I googled "SX8847 datasheet", the first match was the L9958 datasheet I linked to. I don't know why, I can't find any mention of SX8847 in the datasheet. However, the description of the I/O interface on the eBay page matches the description in the datasheet, so does the block diagram. Also, another item I found on eBay that appears to be a rather similar board has a L9958 chip in the photo, see http://www.ebay.co.uk/itm/Arduino-240W-High-power-H-Bridge-Motor-Driver-Module-Smart-Car-Driver-/330817755465?pt=LH_DefaultDomain_0&hash=item4d06465949. So I think it very likely that the unit I linked to is based on the L9958.
« Reply #11 on: January 09, 2013, 12:59:14 am » |
I have a couple of the sx8847 sonxun high power h bridges. Bought on ebay. I have one working with the following code:
/* Motor test with Sonxun high power h bridge sx8847 MN 2013 Motor waits for one second, goes clockwise for 4 seconds, waits for one second, anticlockwise for 4 seconds, waits for 1 second, repeats. Monitor with serial port updates. */
//Functions used on h bridge pcbs. int oneen = 8; // enable int onedir = 9; // direction int onepwm = 10; // pulse width modulation int onedi = 2; // disable //also connect GND and VCC obviously
// the setup routine runs once when you press reset: void setup() { // initialize the digital pins. pinMode(onedir, OUTPUT); pinMode(onepwm, OUTPUT); pinMode(oneen, OUTPUT); pinMode(onedi, OUTPUT); Serial.begin(9600); //starts serial port }
// the loop routine runs over and over again forever: void loop() { /* //turn all low digitalWrite(oneen, LOW); // part 1, h bridge activation digitalWrite(onedi, LOW); // part no disable digitalWrite(onedir, LOW); // high turns forwards, low is reverse digitalWrite(onepwm, LOW); // high runs motor (if h bridge is on) */ Serial.print(" wait1"); delay(1000); // onedir high, onepwm low, works clockwise digitalWrite(oneen, HIGH); // part 1, h bridge enable digitalWrite(onedi, LOW); // part 2, h bridge no disable digitalWrite(onedir, LOW); // high turns anticlockwise, low is clockwise digitalWrite(onepwm, HIGH); // high runs motor (if h bridge is activen) Serial.print(" clockwise"); delay(4000);
//turn all low (motor off) digitalWrite(oneen, LOW); digitalWrite(onedi, LOW); digitalWrite(onedir, LOW); digitalWrite(onepwm, LOW);
Serial.print(" wait2"); delay(1000); //onedir high, onepwm high, works anticlockwise digitalWrite(oneen, HIGH); // part 1, h bridge activation digitalWrite(onedi, LOW); // part 2, h bridge no disable digitalWrite(onedir, HIGH); // high turns anticlockwise, low is clockwise digitalWrite(onepwm, HIGH); // high runs motor (if h bridge is on) Serial.print(" anticlockwise"); delay(4000); // wait for 1 second
//turn all low (motor off) digitalWrite(oneen, LOW); // part 1, h bridge activation digitalWrite(onedi, LOW); // part no disable digitalWrite(onedir, LOW); // high turns forwards, low is reverse digitalWrite(onepwm, LOW); // high runs motor (if h bridge is on)
Serial.println(" wait3"); delay(1000); }
« Reply #12 on: April 11, 2013, 02:39:41 pm » |
Hi thefarmer42, and all other, I bought the same board from ebay and wait for it now. Do you or anybody else have some expierience with the SPI interface of ths board? I read already the datasheet of the ST - L9958. I found out that it is necessary to enable there the "CL_2" flag in the configuration register to get the highest current limitation(8.6A). The standard is 6.6A. In fact I look for an open source example for a SPI-communication to this board (sx8847). Or anything what helps to start. My project is very simple  Only control the speed of a 12V DC motor with 100W. Thanks it advance.
London
« Reply #13 on: April 11, 2013, 07:43:38 pm » |
I have an Adafruit motor shield. It has 2 * L293s and supports up to 4 motors. The L293 can supply up to 1Amp to each motor. To get up to 2Amps, Adafruit suggests 'piggybacking' another L293 on each of the other L293s. Just put one chip on top of the other and solder the legs of the top chip to the top of the legs of the bottom chip. The result resembles two cockroaches mating
« Reply #14 on: April 12, 2013, 03:09:02 pm » |
Thanks for your answer. I calculate approx. 8 to 10A for my motor. So I have to use many of these IC's. That is not my solution. Does anybody have used this motor driver?
