Topic: Serial problem (Read 2073 times) previous topic - next topic
alva
#15
Nov 29, 2012, 08:51 am Last Edit: Nov 29, 2012, 09:14 am by alva Reason: 1
@ Wildbill:
Thanks for your explanation as it helps me out with my problem.
I still some other issues:
1. How would you get a newer version of IDE?
2. What is the maximum character I could send in 64 bytes read buffer?
3. If I throw out String, what is the substitute?
4. Considering question no.3, is there other way to solve my problem without re-writing the program? Can I limit the character of the data without rewriting the program?
@Nick Gammon:
Thank you for advice. However, if I don't use delay, based on your experience, what function should I use to hold the led to light for 5 second? if I use interupts timer,can i use 2 different timers in one arduino?
@others:
Is there any other comment? I do appreciate your participation :)
AWOL
Quote
Have a look at the "blink without delay" example that came with the IDE for a clue.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
nickgammon
You don't send in a read buffer, however I think the answer would be 64.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
wildbill
1. You can download the latest version from the main site if you don't already have it, but the issue isn't the IDE, your code needs to change.
2. 64. Tweak your input data to be less than 64 and reduce the number of commas that trigger printing and you should see something coming from the Arduino.
3. Null terminated arrays of char and the standard c functions that handle them with names that start with str, such as strcpy, strcat.
4. You can still use String, though it is ill advised because of the memory allocation bug that comes with it. But you need to get rid of delay as AWOL advised.
AWOL
Let me give you a really good reason not to use "delay()".
At 9600 bits per second, if you were executing a "delay (1000);", and the transmitter were sending continuously, you could overflow the receive buffer (and know nothing about it!) 15 times.
Sadly, you're not executing "delay (1000)", you're executing "delay (5000)".
That's 4800 characters lost.
alva
hii....thanks for replying
Is there any other way to omit delay other than milis?
PaulS
Quote
There's micros().
nickgammon
@Nick Gammon:
http://www.gammon.com.au/blink
More info:
