Author Topic: load a file in eeprom  (Read 239 times)
 smiley-zipper 'lo there...
i try to load a txt file in my wonderful 24c01 used in i2c way..
what do you suggest me to use for load it into it ? string sequence ? stream ?
i'd look on the library, but i did not see exemple of file's handles.
ever test it ?  smiley-eek-blue many thanks
If your .txt file located in SdCard read the file in chunks(size of chunk must equal to size of EEPROM memory block)
http://fritzing.org/projects/readwrite-serial-eeprom-via-i2c/ for 24c01 interfacing
From Idea To Invention
 smiley-zipper yes i 'd ever test this fritzing beta and it works very nice.. smiley-mr-green
but instead of counting basicly, i want to push a little file.txt into it..(size=300 bytes) smiley-small
First Step
Reading a file from Sd Card
void readFile(char* file ,char *fileData)
  int16_t  readed;
  File myFile = SD.open(file,FILE_READ);
  if(myFile!=NULL){
    char* buf = (char*) malloc(myFile.size()+1);
    readed = myFile.read(buf,myFile.size());
    buf[readed]='\0';
    myFile.close();
    strcpy(fileData,buf);
    free(buf);
      strcpy(fileData,"Fail to open file");
Second step
call this funtion when you want to readfile for e.g file name test.txt
char fileData[300];
readFile("test.txt",fileData)
last step push data from fileData to EEPROM it's on you smiley-cool
One important point intialize the SD (Sd.begin(4)) in setup
« Last Edit: November 27, 2012, 08:02:19 am by Cybernetician » Logged
Seattle, WA USA
Seattle, WA USA
What's wrong with counting? It's incredibly simple:
count++;
Read a character, write to EEPROM, increment the address. Repeat until the end of the file is reached.
 smiley-eek ok i going to see that...sd card libraries gives many idea about this...
thanks very much everyone....
 smiley-wink
Milton Keynes UK
Assuming you want to read the content back from EEPROM at some point, you'd need to provide some way to know how long the 'file' was. You might be willing to remember the number of bytes that were written and hard-code that value in the code to read it - it would work, although it isn't an elegant solution.
