Topic: Arduino to Arduino for ROV (Read 2156 times) previous topic - next topic
mech_eng
Hello all, I am working on an ROV which requires communication over 50' of wire. The current design has an onboard Arduino which reads analog inputs from the surface. I currently have code which reads analog pot inputs and it works, even over 50' of wire (no noise issues). However, I would like to reduce the size and cost of the tether which runs to the ROV to supply power, video, and control input. The method that I have functioning requires 7 wires of an ethernet line for control input, power is supplied over 10 gauge wire, and video has its on line as well.
The control inputs need to control a servo and the speed and direction of 6 thrusters. I would like to reduce the control input to 2 wires, using an Arduino on the surface to read the analog inputs and transmit this data to another arduino onboard the ROV.
Before I invest a lot of research time I want to make sure this is feasible. How feasible is it to establish RS232 or RS485 communication to accomplish this task? If possible point me in the right direction.
Thank you!
holmes4
You need to get this post moved to project guidance.
Mark
AWOL
#2
Nov 27, 2012, 03:01 pm Last Edit: Nov 27, 2012, 03:03 pm by AWOL Reason: 1
http://www.ti.com/lit/ds/symlink/max232.pdf
http://arduino.cc/forum/index.php/topic,133970.msg1007882.html#msg1007882
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
mech_eng
Sorry about that, I should have been more specific.
Is the programming of this set up possible?
holmes4
If this is what your asking about
Quote
Then yes, the uno can just cope. 2 pins for comms, 1 pin for the servo, 6 PWM pins (motor speed) and 6 direction pins for the motors. Connecting the two Unos via pins 0&1 will allow you to use Serial between the two.
Mark
mech_eng
Okay here is what I want to do:
From the Arduino on surface I would like to send the following: Start  Case#  Speed    End
Start would be the Start of packet marker,   <
Case # would determine which motors and which direction to fire motors, I have 10 possible cases  1-10
Speed would be the PWM value   0-255
End would be End of packet marker,   >
Then on the receiving side I would like to  process this information to make it comply with my will lol, I can handle the sending of the packet but I have no clue how to process this information on the receiving Arduino. I am finding some useful links and will post code if I can develop something post worthy.
Point me to some good examples if possible.
guix
#6
Nov 27, 2012, 05:54 pm Last Edit: Nov 28, 2012, 03:24 am by guix Reason: 1
Hello, the receiving part could be done with something like this:
Code: [Select]
 if ( Serial.available() > 0 )
   char c = Serial.read();
   static uint8_t i;
   static char input[12];
   if ( c != '\r' && i < 11)
     input[i++] = c;
     input[i] = '\0';
     i = 0;
     uint8_t var1;
     uint8_t var2;
     char output[20];
     if ( sscanf( input, "<%hhu %hhu>", &var1, &var2 ) == 2 )
       sprintf( output, "case:%hhu speed:%hhu", var1, var2 );
       Serial.println( output );
With this code, your other Arduino will need to send the following format to Serial:
Code: [Select]
<Case Speed>\r
Good luck :)
zoomkat
Something like the below could be used on the receiving arduino to control servos.
Code: [Select]
//zoomkat 11-22-12 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
  //myservoa.writeMicroseconds(1500); //set initial servo position if desired
  myservoa.attach(6);  //the pin for the servoa control
  myservob.attach(7);  //the pin for the servob control
  myservoc.attach(8);  //the pin for the servoc control
  myservod.attach(9);  //the pin for the servod control
  Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
  //expect single strings like 700a, or 1500c, or 2000d,
  //or like 30c, or 90a, or 180d,
  //or 30c,180b,70a,120d,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
          if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.write(n);
          if(readString.indexOf('b') >0) myservob.write(n);
          if(readString.indexOf('c') >0) myservoc.write(n);
          if(readString.indexOf('d') >0) myservod.write(n);
         readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
mech_eng
Thank yall!! Extremely helpful. I've tested out the first batch of code with the Serial Monitor sending <Case Speed>/r to the Arduino and it works great. However, when I send it something random it freezes. Will I need to find a way to code this out or is this even a concern?
guix
Sorry I made a little mistake in the code, it's corrected now but I'm not sure if that will solve your problem, try again :)
