Loading...
Pages: 1 [2]   Go Down
Author Topic: Happiness is SdFat with DMA SPI  (Read 1999 times)
0
Offline Offline
Edison Member
Arduino rocks
View Profile
I think a block transfer function could be added.  Maybe something like
Code:
 bool SPIClass::transfer(uint8_t* rxBuf, uint8_t* txBuf, uint16_t size);
You need to allow either rxBuf or txBuf to be null.  The transfer size is limited to a 16-bt field unless you use chained buffers.
The main problem is that SPI.h uses the variable chip select mode.  This mode can be used with DMA but doesn't seem like what users would want.
« Last Edit: December 01, 2012, 07:50:44 pm by fat16lib » Logged
Offline Offline
Sr. Member
View Profile
How would this be integrated into the standard SPI lib so that you could use multiple SPI devices at once without them all or none having to use DMA?
Strikes me as a pity that you need to go the DMA route to get performance that is equivalent to a simple FIFO buffer as found on the Teensy chip. Seems like _a lot_ of added complexity with all the attendent issues just to get to a baseline of a reasonably efficient SPI performance.
I gather from what you've written there would be little or no point in terms of a speed benefit in doing DMA SPI for the Teensy 3, for example?
Do you think there is really no hope to get the poor Due SPI performance improved to any significant degree without resorting to DMA?
« Last Edit: December 01, 2012, 09:25:29 pm by pico » Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
You could use DMA or not on any device or any transfer to a given device.  SAM3X DMA is just an engine to move memory to/from a device register with the appropriate handshake/flow control.
I get twice the performance on SAM3X as on Teensy 3.0. I run SAM3X at 42 MHz and Teensy 3.0 at 24 Mhz.  I use a lot of tricks on Teensy so DMA on Due is simpler.
I suspect there would be a slight improvement on Teensy 3.0 with DMA.
DMA could be a real advantage with a RTOS.  If you run the SD task at low priority, more CPU would be available.  Even better a task could wait on a DMA done interrupt.
Finally, I have the option in my SPI layer of using optimized SPI without DMA.  It runs much faster than the standard SPI library but has none of the options.
I don't see what you have against SAM3X DMA.
Logged
Offline Offline
Sr. Member
View Profile
I have nothing against DMA per se, it's just that by your own account, it seems to be adding  a great deal of complexity to the SPI implementation. Of course, the simpler the solution the more robust, generally speaking.
But if you say the Teensy 3.0 FIFO code is even more complex, it's probably a better way of going -- and perhaps even means the Teensy would benefit from a DMA implementation after all, if only to make things less complex.
Logged
Michigan
Offline Offline
Newbie
IR Combat
View Profile
WWW
So I'm planning to try out your improved DUE SPI / SD card library this weekend on my laser tag system.  I'll let you know how it goes.  I currently use the ATmega328P with your old SD library, but use file indexing to open files quickly.  Not very user friendly for coding, but it works.  Maybe I can retire the file indexing if this works much faster?
What is the status on this being implemented into the DUE library non beta?
http://code.google.com/p/beta-lib/downloads/list
Logged
IR Combat laser tag developer/inventor
Pages: 1 [2]   Go Up
Print
Jump to:
