The ULN2003 has 7 arrays, so you would need 2 chip to run the columns.
Have you tested your cube to make sure each LED lights, and only one LED lights at a time?
You may want to write a simple test program that lights 1 LED, then pauses, then turns off the LED, then lights the next LED, until it sequences all the LEDs. 2 loops (1 to 3, and 1 to 9) would be nice, but you can do it any way you like.
Once you have the wiring setup right, everything seems to light properly, you can go back and add your other components if you want, then make sure it still works.
http://arduino.cc/playground/Main/LEDCube3x3I found this 3x3x3 cube code, Ive modified it to work with your cubes pinout.
It uses pins 0-8 and 11,12,13 (i didnt know there was a pin0, but I did put it in the code, to match the pins used in your code.
Based on ledcube.c from Make: September 7, 2007 weekend podcast
http://blog.makezine.com/archive/2007/09/make_a_pocket_led_cube_we.html
Custom animation programmed by Mark Boszko, http://stationinthemetro.com
#include <avr/pgmspace.h> // allows use of PROGMEM to store patterns in flash
#define CUBESIZE 3
#define PLANESIZE CUBESIZE*CUBESIZE
#define PLANETIME 3333 // time each plane is displayed in us -> 100 Hz refresh
#define TIMECONST 20 // multiplies DisplayTime to get ms - why not =100?
// LED Pattern Table in PROGMEM - last column is display time in 100ms units
// TODO this could be a lot more compact but not with binary pattern representation
prog_uchar PROGMEM PatternTable[] = {
// blink on and off
B111, B111, B111, B111, B111, B111, B111, B111, B111, 5,
B000, B000, B000, B000, B000, B000, B000, B000, B000, 1,
// flash each LED in sequence:
// Left->Right column, then Top->Bottom row, then Upper->Lower plane
B100, B000, B000, B000, B000, B000, B000, B000, B000, 1,
B010, B000, B000, B000, B000, B000, B000, B000, B000, 1,
B001, B000, B000, B000, B000, B000, B000, B000, B000, 1,
B000, B100, B000, B000, B000, B000, B000, B000, B000, 1,
B000, B010, B000, B000, B000, B000, B000, B000, B000, 1,
B000, B001, B000, B000, B000, B000, B000, B000, B000, 1,
B000, B000, B100, B000, B000, B000, B000, B000, B000, 1,
B000, B000, B010, B000, B000, B000, B000, B000, B000, 1,
B000, B000, B001, B000, B000, B000, B000, B000, B000, 1,
B000, B000, B000, B100, B000, B000, B000, B000, B000, 1,
B000, B000, B000, B010, B000, B000, B000, B000, B000, 1,
B000, B000, B000, B001, B000, B000, B000, B000, B000, 1,
B000, B000, B000, B000, B100, B000, B000, B000, B000, 1,
B000, B000, B000, B000, B010, B000, B000, B000, B000, 1,
B000, B000, B000, B000, B001, B000, B000, B000, B000, 1,
B000, B000, B000, B000, B000, B100, B000, B000, B000, 1,
B000, B000, B000, B000, B000, B010, B000, B000, B000, 1,
B000, B000, B000, B000, B000, B001, B000, B000, B000, 1,
B000, B000, B000, B000, B000, B000, B100, B000, B000, 1,
B000, B000, B000, B000, B000, B000, B010, B000, B000, 1,
B000, B000, B000, B000, B000, B000, B001, B000, B000, 1,
B000, B000, B000, B000, B000, B000, B000, B100, B000, 1,
B000, B000, B000, B000, B000, B000, B000, B010, B000, 1,
B000, B000, B000, B000, B000, B000, B000, B001, B000, 1,
B000, B000, B000, B000, B000, B000, B000, B000, B100, 1,
B000, B000, B000, B000, B000, B000, B000, B000, B010, 1,
B000, B000, B000, B000, B000, B000, B000, B000, B001, 10,
// this is a dummy element for end of table (duration=0)
B000, B000, B000, B000, B000, B000, B000, B000, B000, 0
** Defining pins in array makes it easier to rearrange how cube is wired
** Adjust numbers here until LEDs flash in order - L to R, T to B
** Note that analog inputs 0-5 are also digital outputs 14-19!
** Pin DigitalOut0 (serial RX) and AnalogIn5 are left open for future apps
//TheColdest's cube uses pins 0-9, 11-13, I would suggest using
//int LEDPin[] = {16, 3, 1, 15, 4, 6, 14, 5, 7};
// Using pins 0-8 for columns
int LEDPin[] = {0, 1, 2, 3, 4, 5, 6, 7, 8};
//int PlanePin[] = {19, 18, 17};
//using pins 11,12,13 for planes
int PlanePin[] = {11, 12, 13};
// initialization
int pin; // loop counter
// set up LED pins as output (active HIGH)
for (pin=0; pin<PLANESIZE; pin++) {
pinMode( LEDPin[pin], OUTPUT );
// set up plane pins as outputs (active LOW)
for (pin=0; pin<CUBESIZE; pin++) {
pinMode( PlanePin[pin], OUTPUT );
// display pattern in table until DisplayTime is zero (then repeat)
// declare variables
byte PatternBuf[ PLANESIZE ]; // saves current pattern from PatternTable
int PatternIdx;
byte DisplayTime; // time*100ms to display pattern
unsigned long EndTime;
int plane; // loop counter for cube refresh
int patbufidx; // indexes which byte from pattern buffer
int ledrow; // counts LEDs in refresh loop
int ledcol; // counts LEDs in refresh loop
int ledpin; // counts LEDs in refresh loop
// Initialize PatternIdx to beginning of pattern table
PatternIdx = 0;
// loop over entries in pattern table - while DisplayTime>0
do {
// read pattern from PROGMEM and save in array
memcpy_P( PatternBuf, PatternTable+PatternIdx, PLANESIZE );
PatternIdx += PLANESIZE;
// read DisplayTime from PROGMEM and increment index
DisplayTime = pgm_read_byte_near( PatternTable + PatternIdx++ );
// compute EndTime from current time (ms) and DisplayTime
EndTime = millis() + ((unsigned long) DisplayTime) * TIMECONST;
// loop while DisplayTime>0 and current time < EndTime
while ( millis() < EndTime ) {
patbufidx = 0; // reset index counter to beginning of buffer
// loop over planes
for (plane=0; plane<CUBESIZE; plane++) {
// turn previous plane off
if (plane==0) {
digitalWrite( PlanePin[CUBESIZE-1], HIGH );
digitalWrite( PlanePin[plane-1], HIGH );
// load current plane pattern data into ports
ledpin = 0;
for (ledrow=0; ledrow<CUBESIZE; ledrow++) {
for (ledcol=0; ledcol<CUBESIZE; ledcol++) {
digitalWrite( LEDPin[ledpin++], PatternBuf[patbufidx] & (1 << ledcol) );
patbufidx++;
// turn current plane on
digitalWrite( PlanePin[plane], LOW );
// delay PLANETIME us
delayMicroseconds( PLANETIME );
} // for plane
} // while <EndTime
} while (DisplayTime > 0); // read patterns until time=0 which signals end
