Hey everyone. I've been after this for a while now but have yet to resolve this problem:
I purchased a 3.2" tft lcd shield + touch panel TF Reader for arduino that claims that it works with the Arduino UNO (even shows it being attached to an Arduino Uno in the product image). I have no idea what the name of the shield is since it doens't mention it on the shield or in the description for the item but it does say that it uses SSD1289 controller and links to that same website (but a different code [other than UTFT]?? check out the "downloads" on that ebay listing).
Link to the item (hopefully it will stick around for a while): http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270972145966&fromMakeTrack=true#ht_2045wt_699
I've attached it to my Arduino UNO and am using code and libraries from the link below (standard UTFT). The display resolution on the LCD monitor is 320240 pixels so naturally I tried the __UTFT example meant for 320240.__ I've modified the code for my display (as far as I know) but all I get is a white, randomly flickering screen (doesn't always flicker). In the code, I inserted SSD1289 for the controller (search for "DotScott" on this page to see my notes in the code).
Link to UTFT: Electronics - Henning Karlsen
320*240 example code, modified for UNO and my shield:
// UTFT_Demo_320x240 (C)2012 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of how to use most of the functions
// of the library with a supported display modules.
// This demo was made for modules with a screen resolution
// of 320x240 pixels.
// This program requires the UTFT library.
#include <UTFT.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
// Uncomment the next line for Arduino 2009/Uno
UTFT myGLCD(SSD1289,A1,A2,A0,A4,A5); // Remember to change the model parameter to suit your display module!
//DotScott note: originally with UTFT myGLCD(SSD1289,19,18,17,16); but items' //code says UTFT myGLCD(SSD1289,A1,A2,A0,A4,A5);
// DotScott note: ^changed ITDB32S to SSD1289
// Uncomment the next line for Arduino Mega
//UTFT myGLCD(ITDB32S,38,39,40,41); // Remember to change the model parameter to suit your display module!
randomSeed(analogRead(0));
// Setup the LCD
myGLCD.InitLCD(); // DotScott note: I've tried values of 0 and 1 here.
myGLCD.setFont(SmallFont);
int buf[318];
int x, x2;
int y, y2;
int r;
// Clear the screen and draw the frame
myGLCD.clrScr();
myGLCD.setColor(255, 0, 0);
myGLCD.fillRect(0, 0, 319, 13);
myGLCD.setColor(64, 64, 64);
myGLCD.fillRect(0, 226, 319, 239);
myGLCD.setColor(255, 255, 255);
myGLCD.setBackColor(255, 0, 0);
myGLCD.print("* Universal Color TFT Display Library *", CENTER, 1);
myGLCD.setBackColor(64, 64, 64);
myGLCD.setColor(255,255,0);
myGLCD.print("<http://electronics.henningkarlsen.com>", CENTER, 227);
myGLCD.setColor(0, 0, 255);
myGLCD.drawRect(0, 14, 319, 225);
// Draw crosshairs
myGLCD.setBackColor(0, 0, 0);
myGLCD.drawLine(159, 15, 159, 224);
myGLCD.drawLine(1, 119, 318, 119);
for (int i=9; i<310; i+=10)
myGLCD.drawLine(i, 117, i, 121);
for (int i=19; i<220; i+=10)
myGLCD.drawLine(157, i, 161, i);
// Draw sin-, cos- and tan-lines
myGLCD.setColor(0,255,255);
myGLCD.print("Sin", 5, 15);
for (int i=1; i<318; i++)
myGLCD.drawPixel(i,119+(sin(((i*1.13)*3.14)/180)*95));
myGLCD.setColor(255,0,0);
myGLCD.print("Cos", 5, 27);
myGLCD.drawPixel(i,119+(cos(((i*1.13)*3.14)/180)*95));
myGLCD.print("Tan", 5, 39);
myGLCD.drawPixel(i,119+(tan(((i*1.13)*3.14)/180)));
delay(2000);
myGLCD.setColor(0,0,0);
myGLCD.fillRect(1,15,318,224);
// Draw a moving sinewave
x=1;
for (int i=1; i<(318*20); i++)
x++;
if (x==319)
x=1;
if (i>319)
if ((x==159)||(buf[x-1]==119))
myGLCD.setColor(0,0,255);
myGLCD.drawPixel(x,buf[x-1]);
y=119+(sin(((i*1.1)*3.14)/180)*(90-(i / 100)));
myGLCD.drawPixel(x,y);
buf[x-1]=y;
delay(2000);
// Draw some filled rectangles
for (int i=1; i<6; i++)
switch (i)
case 1:
myGLCD.setColor(255,0,255);
case 2:
case 3:
myGLCD.setColor(0,255,0);
case 4:
case 5:
myGLCD.fillRect(70+(i*20), 30+(i*20), 130+(i*20), 90+(i*20));
delay(2000);
// Draw some filled, rounded rectangles
switch (i)
case 1:
case 2:
case 3:
case 4:
case 5:
myGLCD.fillRoundRect(190-(i*20), 30+(i*20), 250-(i*20), 90+(i*20));
delay(2000);
// Draw some filled circles
switch (i)
case 1:
case 2:
case 3:
case 4:
case 5:
myGLCD.fillCircle(100+(i*20),60+(i*20), 30);
delay(2000);
// Draw some lines in a pattern
myGLCD.setColor (255,0,0);
for (int i=15; i<224; i+=5)
myGLCD.drawLine(1, i, (i*1.44)-10, 224);
for (int i=224; i>15; i-=5)
myGLCD.drawLine(318, i, (i*1.44)-11, 15);
myGLCD.setColor (0,255,255);
myGLCD.drawLine(1, i, 331-(i*1.44), 15);
myGLCD.drawLine(318, i, 330-(i*1.44), 224);
delay(2000);
myGLCD.fillRect(1,15,318,225);
// Draw some random circles
for (int i=0; i<100; i++)
myGLCD.setColor(random(255), random(255), random(255));
x=32+random(256);
y=45+random(146);
r=random(30);
myGLCD.drawCircle(x, y, r);
delay(2000);
// Draw some random rectangles
x=2+random(316);
y=16+random(207);
x2=2+random(316);
y2=16+random(207);
myGLCD.drawRect(x, y, x2, y2);
delay(2000);
// Draw some random rounded rectangles
x=2+random(316);
y=16+random(207);
x2=2+random(316);
y2=16+random(207);
myGLCD.drawRoundRect(x, y, x2, y2);
delay(2000);
x=2+random(316);
y=16+random(209);
x2=2+random(316);
y2=16+random(209);
myGLCD.drawLine(x, y, x2, y2);
delay(2000);
for (int i=0; i<10000; i++)
myGLCD.drawPixel(2+random(316), 16+random(209));
delay(2000);
myGLCD.fillScr(0, 0, 255);
myGLCD.fillRoundRect(80, 70, 239, 169);
myGLCD.print("That's it!", CENTER, 93);
myGLCD.print("Restarting in a", CENTER, 119);
myGLCD.print("few seconds...", CENTER, 132);
myGLCD.setColor(0, 255, 0);
myGLCD.setBackColor(0, 0, 255);
myGLCD.print("Runtime: (msecs)", CENTER, 210);
myGLCD.printNumI(millis(), CENTER, 225);
delay (10000);
Arduino 1.0.1 as well as Arduino 0023.
Am I missing something somewhere? Is anyone else out there having this problem?
