Topic: Help with Sketch (Read 2783 times) previous topic - next topic
SAButter
Nov 28, 2012, 05:15 am Last Edit: Nov 28, 2012, 05:23 am by SAButter Reason: 1
I just started playing with microcontrollers and I am learning.
I'm working on a water tank level indicator and I'm having some trouble figuring it out whats wrong with the sketch. What I am trying to do is have a pot activate pins that correspond to a 7 seg common anode display. Hopefully someone has some time to look at this that would be a big help thanks.
int aPin = 13;                // Red LED connected to digital pin 13
int bPin = 12;
int cPin = 11;
int dPin = 10;
int ePin = 9;
int fPin = 8;
int gPin = 7;
int hPin = 6; //BI Blanking input LOW turns off segments HIGH normal op.
int sensePin = 0;    // select the input pin for the Map
void setup()                      // run once, when the sketch starts
  analogReference (DEFAULT);
  pinMode(aPin, OUTPUT);        // sets the digital pin as output
  pinMode(bPin, OUTPUT);
  pinMode(cPin, OUTPUT);
  pinMode(dPin, OUTPUT);
  pinMode(ePin, OUTPUT);
  pinMode(fPin, OUTPUT);
  pinMode(gPin, OUTPUT);
  pinMode(hPin, OUTPUT); //BI Blanking input LOW turns off segments HIGH normal op if used on 7447 driver.
  Serial.println(analogRead(sensePin));
  delay (200);
  int val = analogRead(sensePin);
  if (val >= 1 && val <= 100)
  digitalWrite(aPin, HIGH);
  digitalWrite(bPin, HIGH);
  digitalWrite(cPin, HIGH);
  digitalWrite(dPin, HIGH);
  digitalWrite(ePin, HIGH);
  digitalWrite(fPin, HIGH);
  digitalWrite(gPin, LOW);
  if (val >= 101 && val <= 200)
  digitalWrite(aPin, LOW);
  digitalWrite(dPin, LOW);
  digitalWrite(ePin, LOW);
  digitalWrite(fPin, LOW);
  if (val >= 201 && val <= 300)
  digitalWrite(cPin, LOW);
  digitalWrite(gPin, HIGH);
  if (val >= 301 && val <= 400)
  if (val >= 401 && val <= 500)
  if (val >= 501 && val <= 600)
  digitalWrite(bPin, LOW);
  if (val >= 601 && val <= 700)
  if (val >= 701 && val <= 800)
  if (val >= 801 && val <= 900)
  if (val >= 901 && val <= 1023)
patduino
Hi SAButter, and welcome to the forums.
Before we can help, you'll need to explain what the sketch does that is incorrect.  What's it doing wrong?
There are 10 types of people in the world, those who understand binary, and those that don't.
Cybernetician
if (val >= 1 && val <= 100);
Search for how to use of IF statement
From Idea To Invention
guix
#3
Nov 28, 2012, 05:22 am Last Edit: Nov 28, 2012, 05:30 am by guix Reason: 1
Hello, there are some mistakes in your code, I will correct a few and you do the rest:
 Serial.println( val );
 delay (200);
 else if (val >= 101 && val <= 200)
 //etc etc
Study the changes, and apply them to the rest of your code :)
Also you will have to restore the pins to HIGH, or they will stay LOW You fixed it already :)
Cybernetician
If you want to do action on val >= 1 && val <= 100
SAButter
OOOooo
Sorry guys I didn't think that I would have a response that fast. I noticed that I posted a newer sketch of what I am working on so I edited my original post and changed the code.
Sorry
Cybernetician
again wrong attemp first read comments and apply them. 8)
SAButter
The leds on the output pins to the segment are all high and not changing with the input state.
guix
#8
Nov 28, 2012, 05:32 am Last Edit: Nov 28, 2012, 05:40 am by guix Reason: 1
Also change:
int sensePin = 0;
to:
uint8_t sensePin = A0;
Pin 0 is digital pin 0
Pin A0 is analog pin 0
I think that may be your problem :)
FYI, A0 is defined for each Arduino boards, for example on my Arduino Mega:
static const uint8_t A0 = 54;
So I could replace "A0" by "54", but then it won't work on a different board. See <arduino ide folder>\hardware\arduino\variants\ for pins names and other interesting things
SAButter
 delay (200);
 //etc etc
I will do that Thanks for looking at it
Man I cant believe how many people are on this site so late at night.
Cybernetician
All of them are not from same place. 8)
SAButter
 delay (200);
 //etc etc
Thanks a million with your help it's working now.
I remember twenty years ago when to school for electronics the coolest new chip that just came out could store 7 seconds of audio. So thing have changed a bit  :) thanks for the help guys
guix
AWOL
It depends on the context - A0 and 0 mean exactly the same thing in the context of analogRead (as is the case here), though they have different numerical values.
guix
Okay, thanks I didn't know ;)
