Loading...
Pages: [1] 2 3   Go Down
Author Topic: Which Arduino to buy to use with HD video  (Read 872 times)
Offline Offline
Newbie
View Profile
Hi.
I'm fairly new to this whole arduino thing, so I'm not really sure which one to go with.
I have ordered the starter pack to introduce myself to it and teach myself how to use it, but I have a project in mind which involves laying text over HD video in various formats (1080p and 720p for starters).
Would there be one Arduino over another that would be better at handling the video?
Ryan
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
I don't know of any Arduino that could do what you want.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
1080p format would be 1,920×1,080 = 2,073,600 pixels. Assuming a frame rate of 60 fps, then you need to draw 124,416,000 pixels per second, which is totally disregarding the front and back porch.
Therefore you have 8 nS (nanoseconds) for each pixel. Since the clock on most Arduinos is 62.5 nS it is way too slow to do that. Many instructions take two clock cycles, and to lay text over video you would need to make decisions, read the text, etc., all of which takes time.
Arduinos are great for process control, and handling slow to medium speed situations (eg. washing machines, dishwashers, plant watering, timing races, security systems,  cat feeding, robots, etc.). For stuff like audio and video you need to go to faster (and more expensive) processors.
Logged
Offline Offline
Sr. Member
View Profile
Try the Arduino called "Raspberry Pi" (Just kidding. Not an Arduino, of course.)
But RPi does have the hardware grunt to do what you want (fast cpu, 512MB of ram, dedicated gpu), and are inexpensive.
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
If your overlaying text on live video then your probably going to need some external hardware no matter what microcontroller you use. I have seen cheap(ish) SD (standard definition) versions (http://www.decadenet.com/bob4/bob4.html) but not HD (high definition) versions. Only cheap(ish) thing I can think is to use a Raspberry-Pi and purchase a standalone HD DSK (Down Stream Keyer) or a PC with a Decklink Studio (http://www.blackmagicdesign.com/products/decklink/) I'm sure there are probably dedicated video overlay chips that someone else can suggest.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Yes not a beginners project.
While the Pi will generate video at the required rate your main problem will be the synchronisation of the overlay video with the live video. This is not a simple matter and calls for a circuit called a genlock.
This means you having to use the sync pulses from one source to control the other source. I am not sure you can genlock the Pi to anything because the video drivers are secrete so you can't get at them. Therefore you would have to look to locking your video to your live source.
In the absence of this the alternative is called a frame store or buffer. Basically you write video into it and genlock the read video rate. These are expensive.
Logged
Poole, Dorset, UK
Offline Offline
God Member
View Profile
Still be not a biginners project but this may do the job
http://www.coolcomponents.co.uk/catalog/video-experimenter-p-723.html
the trick is not to put the video through the arduino its self.
Mark
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Quote
this may do the job
For HD?
I think not.
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
Nice find, alas not HD.
Logged
Poole, Dorset, UK
Offline Offline
God Member
View Profile
Maybe one of hardware type would like to upgrade the idea for HD?
Mark
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Quote
HDMI is something like 350MHz, 10Gbits-1.
Unlikely.
It is far, far less forgiving than analogue standards and equipment.
« Last Edit: November 28, 2012, 07:47:06 am by AWOL » Logged
Ayer, Massachusetts, USA
Offline Offline
Edison Member
View Profile
WWW
While the R-pi is clocked at 700 Mhz, but my impression is even at 700 Mhz, it would struggle to read a full 1080p stream in real-time.  I see somebody asked a similar question two weeks ago in the r-pi forums, and didn't get much of an answer: http://www.raspberrypi.org/phpBB3/viewtopic.php?f=30&t=23231
Logged
Offline Offline
Sr. Member
View Profile
Well, _my_ Pi is clocked at 840MHz smiley-razz These days, it's de rigeur to overclock your Pi if you want to be one of the "cool set". And if you want to be a "bad boy", you overvolt it as well (but you will have to endure the stigma (or cachet, depending on whom you are trying to impress) of having your warranty bit set.)
Well, given the high-level Broadcom gpu drivers have been made open source for just over a month now, I suspect it's still early days for the video geeks to have fully come to grips with now can be done that previously could not on the Pi. I expect that situation will evolve rapidly over the next few months -- should be interesting to watch.
http://www.raspberrypi.org/archives/2221
« Last Edit: November 28, 2012, 09:34:53 am by pico » Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
But it is not the high level drivers that this needs it is the low level drivers, they are still a secret.
Quote
Is that all, when you down load RISC OS, the default config file sets it at 1GHz
Logged
Offline Offline
Sr. Member
View Profile
Is access beyond the what's available in the driver interfaces required to get timing signals onto gpio pins? Maybe, maybe not. I haven't seen a definitive list of the functionality the published gpu drivers expose. Early days.
Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
