Topic: Electrical impedance of Dout port (Read 11409 times) previous topic - next topic
LROBBINS
Grumpy,
You're absolutely correct about my logic, I didn't think past my usually-DC uses.  I am rather surprised by your results, however, as the specs on these would imply otherwise.  From the TI data sheet for the archetype CD4066B:
Low Crosstalk Between Switches: ?50 dB
Typical at fis = 8 MHz, RL = 1 k?
and
Frequency Response, Switch On = 40 MHz
Typical
Ciao,
Lenny
Grumpy_Mike
While that is what the spec sheet says, this is only true when layer out on a PCB with ground plane and terminated correctly. In other words it is the best you will get not what you will get.
dr_benway
#32
Dec 01, 2012, 04:43 pm Last Edit: Dec 01, 2012, 04:46 pm by dr.benway Reason: 1
I did the following modification in the schematic, so no more overshoots now.  ]:D
The resistor is 47 ohm, the capacitor is 10 nF
The current input of the switch is almost zero.
I'm working with analog devices  adg419
http://www.analog.com/static/imported-files/data_sheets/ADG419.pdf
The problem is the frequency.
Now with arduino duemilanove I'm working @ 10 khz but in future I will arrive at 1 mhz or more, so don't know if this is the right switch design for HF.
The biggest trouble now is the op-amp : it works perfectly for 10 minuts and after go on strike!
I have already burned two.  =( =( =(
So, where is the problem now?
Anyway, I solved the  problem of topic : I NEED THIS RC NETWORK.
100000 thanks 8)
dc42
winner10920
Have you tried it with 1mhz yet? You can get a 50%duty cycle 1mhz square wave from the 328 pretty easy, tho idont remember offhand its only a few lines of code
I would suggest making a (few) prototype pcb from batchpcb or similiar , making it as tight together as possible, will ground plane, and then check again for your overshoot, you may find its entirely related to the prototyping method you are using
dhenry
You don't need that capacitor - it is counter-productive, especially if you want to go to 1Mhz later.
You could have used some of the analog switches in the CD/HC family.
I would have used a 4.7 - 22ohm resistor to dampen, but not with an analog switch.
A few hurdles there:
1) your buffer will give out way before 1Mhz.
2) your mcu may not be fast enough to produce 1Mhz pin outs.
Two alternatives to go to 1Mhz and beyond:
1) DDS. This approach requires additional hardware + programming. But it can generate lots of different waveforms and relieve your mcu.
2) Use a counter + resistor network. This approach requires just a serial clock (from  your mcu).
A 3rd approach would be to use a memory device pre-programmed with your waveform as your own dds.
Papa G
#36
Dec 01, 2012, 06:11 pm Last Edit: Dec 01, 2012, 06:15 pm by PapaG Reason: 1
That's the approach I've found is the most versatile for generating waveforms that are very complex and that you need to repeat... well, repeatedly  :).
You can drive the address pins of an EPROM with an up-down counter clocked via your MCU or address the EPROM directly from an MCU output port. I guess you can still buy EPROMs. :) The variations are endless.
dhenry
Those are really the great-grandfather of today's cpld/fpga. Parallel eeprom and parallel sram are still available today, albeit hard to find.
Papa G
I suspected as much. Dual port SRAM is another approach if you need to change the table driving the DAC periodically. I used counters with transparent latches for the address bus part of the dual port.
dr_benway
For higher frequency I suggest you use a proper DAC rather than your home-made one. If you only want sine wave output then try this http://www.ebay.co.uk/itm/New-AD9850-DDS-Signal-Generator-Module-0-40MHz-Test-Equipment-/180820399452?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item2a19bc555c.
Yes,actually  the concept of my schematic is very poor. (it sucks  :smiley-sweat:)
I will try this Digital Device System
Thank you very much for the suggest, very appreciated.
Best regards.
