Loading...
Pages: [1]   Go Down
Author Topic: I2C eeprom problems  (Read 213 times)
Offline Offline
Newbie
View Profile
Hello,
I am trying to read from an eeprom,
http://www.google.si/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCgQFjAA&url=http%3A%2F%2Fwww.melexis.com%2FAsset%2FDatasheet-IR-thermometer-16X4-sensor-array-MLX90620-EEPROM-DownloadLink-6088.aspx&ei=AAK3UOGGIaqR0AWTy4A4&usg=AFQjCNFBlUtGBxEViZIAWJhEoIN4wypLAA&sig2=FEQhqfYZQv7q0aaGKFNT6w
but it seems I am doing something wrong. I am using the following I2C master library
http://homepage.hispeed.ch/peterfleury/group__pfleury__ic2master.html
The code
Code:
// INCLUDES //
#include <i2cmaster.h> // i2c master library
// DEFINITIONS //
#define EEPROM_address 0xA0
// VARIABLES //
word EEPROM_data[256];
// SETUP //
  Serial.begin(115200); // setup serial communication
  i2c_init(); // initialize I2C master interface
  eepromRead(); // read eeprom
// LOOP //
  Serial.println("EEPROM data:");
  Serial.println(EEPROM_data[0]);
// FUNCTIONS //
// read all from eeprom
void eepromRead()
  i2c_start_wait(EEPROM_address+I2C_WRITE); // set device address and write mode (0 is write)
  i2c_write(0x00); // write address
  i2c_rep_start(EEPROM_address+I2C_READ); // set device address and read mode (1 is read)
  for(int i=0;i<255;i++) {
    EEPROM_data[i] = i2c_readAck(); // read one byte and request more data
  i2c_stop();  // terminate data transfer and release I2C bus
Can anyone advise me please? If I do not call the eepromRead(); function in setup, I can see the output on the serial monitor ("EEPROM data: 0"). But if I call the eepromRead(); function, the serial output is blank.
Thank you and best regards,
K
Moderator edit: quote tags changed to code tags (Nick Gammon)
« Last Edit: November 29, 2012, 02:18:22 am by Nick Gammon » Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Code:
But you are only displaying the first byte.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Why not use the Wire library? I have stuff here about accessing EEPROMs:
http://www.gammon.com.au/i2c
Logged
Offline Offline
Newbie
View Profile
Dear Sirs,
I am a certified idiot. Had the wrong pin configuration. Everything working now.
Thank you for the answer and help.
Best regards,
K
Logged
Pages: [1]   Go Up
Print
Jump to:
