Loading...
Pages: [1]   Go Down
Author Topic: Gps logger  (Read 592 times)
Offline Offline
Newbie
View Profile
Hi my name is Leonardo and I was wondering if anyone can help with my gps logger. I have made a sketch but I only get to log the first line of data to my sd card and I can`t find the problem.
The sketch is the problem, both the gps and the sd shield are ok.
#include <SD.h>
#include <SoftwareSerial.h>
SoftwareSerial gpsSerial(6, 5); // RX, TX (TX not used)
const int sentenceSize = 80;
char sentence[sentenceSize];
#define LOG_INTERVAL 100
const int chipSelect = 10;
File logfile;
long idd = 0;
long ids = 0;
long idm = 0;
long idh = 0;
void error(char *str)
  Serial.print("error: ");
  Serial.println(str);
  while(1);
  gpsSerial.begin(9600);
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card Failed or not present");
    return;
  Serial.println("card initialized.");
  // create a new file
  char filename[] = "LOGGER00.CSV";
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = i/10 + '0';
    filename[7] = i%10 + '0';
    if (! SD.exists(filename)) {
      // only open a new file if it doesn't exist
      logfile = SD.open(filename, FILE_WRITE);
      break;  // leave the loop!
  if (! logfile) {
    error("couldnt create file");
  Serial.print("Logging to: ");
  Serial.println(filename);
  static int i = 0;
  if (gpsSerial.available())
    char ch = gpsSerial.read();
    if (ch != '\n' && i < sentenceSize)
      sentence = ch;
      i++;
     sentence = '\0';
     i = 0;
     displayGPS();
void displayGPS()
  char field[20];
  getField(field, 0);
  if (strcmp(field, "$GPRMC") == 0)
    Serial.print("Tiempo: ");
    getField(field, 1);
    logfile.print(field);
    logfile.print("\t");
    Serial.println(field);
    Serial.print("Lat: ");
    getField(field, 3);  // number
    Serial.print(field);
    getField(field, 4); // N/S
    Serial.print("Long: ");
    getField(field, 5);  // number
    getField(field, 6);  // E/W
    Serial.print("Velocidad: ");
    getField(field, 7);
    logfile.println(field);
    logfile.close();
    Serial.println(field) * 1.854;
void getField(char* buffer, int index)
  int sentencePos = 0;
  int fieldPos = 0;
  int commaCount = 0;
  while (sentencePos < sentenceSize)
    if (sentence[sentencePos] == ',')
      commaCount ++;
      sentencePos ++;
    if (commaCount == index)
      buffer[fieldPos] = sentence[sentencePos];
      fieldPos ++;
    sentencePos ++;
  buffer[fieldPos] = '\0';
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
First, you need to modify your post. Select the code and press the # icon. That puts your code between tags that tell the forum software that [ i ] is not an italics tag, for instance.
You open the file in setup() and close it as soon as you write the first line to it. I don't see that you open it again. It's pretty hard to write to a closed file.
Logged
Offline Offline
Newbie
View Profile
Exactly thats the problem, but if I remove the logfile.close(); command it doesn`t log anything at all, any clue why this is?
Logged
Offline Offline
Newbie
View Profile
here is the code
Code:
#include <SD.h>
File logfile;
long idd = 0;
long ids = 0;
long idm = 0;
long idh = 0;
  while(1);
    return;
  if (! logfile) {
  static int i = 0;
      sentence[i] = ch;
      i++;
     sentence[i] = '\0';
     i = 0;
     displayGPS();
void displayGPS()
  char field[20];
  getField(field, 0);
    getField(field, 1);
    getField(field, 7);
    logfile.close();
  int fieldPos = 0;
  int commaCount = 0;
      commaCount ++;
      sentencePos ++;
      fieldPos ++;
    sentencePos ++;
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Is there some part of IN THE SAME FUNCTION that is beyond your understanding? Quit opening the file in setup(). Open it in displayGPS instead. And pick a better name for that function.
Logged
Offline Offline
Newbie
View Profile
If I do that, it will log several files with diferent names with only one line of data, I have allready tryed.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Then you did it wrong. Determining the file name in setup makes sense. Actually open the file in the displayGPS() function. Then, write to it, and close it.
Logged
Offline Offline
Newbie
View Profile
I have solved the problem, I just moved the function void gpsdisplay into the void loop and replace the logfile.close() with the function logfile.flush().
Now it works just fine, thank to all for the help.
Here is the code for anyone to use it
Code:
#include <SD.h>
File logfile;
long idd = 0;
long ids = 0;
long idm = 0;
long idh = 0;
  while(1);
    return;
  if (! logfile) {
  static int i = 0;
      sentence[i] = ch;
      i++;
     sentence[i] = '\0';
     i = 0;
     char field[20];
      getField(field, 0);
    getField(field, 1);
    getField(field, 7);
    logfile.flush();
  int fieldPos = 0;
  int commaCount = 0;
      commaCount ++;
      sentencePos ++;
      fieldPos ++;
    sentencePos ++;
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Except that you never actually close the file, so it is not safe to ever power down the Arduino or remove the SD card.
Logged
Offline Offline
Newbie
View Profile
And why is that?
Logged
Offline Offline
Full Member
View Profile
b/c you didn't close the file. It's similar to the same problem one has when removing an SD card without ejecting it. Data is transferring between the microcontroller and the card. you run the risk of corrupting the data on the card.
Doing what you are doing is fine so long as reliability is irrelevant
Logged
Pages: [1]   Go Up
Print
Jump to:
