Loading...
Pages: 1 [2]   Go Down
Author Topic: attiny85 with 3 PWN pins  (Read 2242 times)
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Quote
I have all 3 LEDs working now,
You are only setting one pin as output, for one thing.
Code:
  for(int i = 0; i < 255; i++){
    digitalWrite(0, i);
    delay(50);
Quote
but there is some really weird things going on with the timing. this code basically only produces an on and off state every 30seconds or so:
That's what digitalWrite does. Turn the pin on or off.
Logged
Brisbane, Australia
Offline Offline
God Member
View Profile
You'd probably like to look at analogWrite() if you are using hardware PWM.  Digitalwrite was needed in the software PWM example because it can be used on any pin, even those where analogWrite is unsupported.
Logged
Offline Offline
Full Member
View Profile
WWW
The short form is, vary these three lines:
Code:
  OCR0A = 127;                   // duty cycle (50%)
  OCR0B = 63;                    // duty cycle (25%)
  OCR1B = 31;                   // duty cycle (25%)
They control the duty cycle. In the case of the first two, 100% is 255, and 0% is 0. The third one counts up to 127, so the duty cycle is half that (or change the line "OCR1C = 127;" to be "OCR1C = 255;" and they will all be the same).
Put your LEDs on pins 3, 5 and 6. Change the duty cycle as required and the LEDs will change brightness.
aha, ok that is very helpful. is this to save battery life? ie set duty cycle to half at 127
Logged
for(i = 0, i < 820480075, i++){ Design(); Code(); delay(1000); } // hellowoo.com
Offline Offline
Full Member
View Profile
WWW
Quote
Code:
    digitalWrite(0, i);
    delay(50);
Quote
sorry I meant the original project I was working on. I used your references to get it working. It was the new library that fixed it.
Quote
hah... yeah you are totally right, I was silly and had digital instead of analog.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
