Pages: [1]   Go Down
Author Topic: Cheap, quick, working SD for Arduino.  (Read 1035 times)
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I learn a bit every time I visit the forum.
View Profile
I started out by getting 3 of these SD Modules with header pins including SPI.
http://dx.com/p/sd-card-module-slot-socket-reader-for-arduino-arm-mcu-133709
After questions about 5V operation with a schematic and some agonizing, I went ahead and ran it jumper wired directly to the Arduino. It ran fine. Test sketch v.1 looked for SD.begin(10) and printed that, and that was that. Didn't matter since it worked first time, every time.
My parts list:
Arduino rev 0 UNO
SD Module
8 female to male jumpers
I'm still running 0022, let me know of changes needed for other versions?
Here's the test/example sketch with parts and connections spelled out in the upper comments.
Code:
// Testing SD Module connected to Arduino UNO
// This UNO is running IDE version 0022
// Arduino SPI library and SD library are imported using the
// Sketch->Import Library pop-down menu. Both are standard.
// SD Lib reference: http://arduino.cc/en/Reference/SD
// I only needed 8 female-to-male jumper wires to connect module to UNO.
// No breadboard, no diodes or protective components needed.
// A cable header can plug right onto the module and split to wire it.
// This sketch looks for a file named text.txt and if it is
// present, tries to read and print the text. Then it tries to
// open a file named test.txt and write to that.
// The SD card used is formatted FAT, is FAT 16, FAT 32 may work.
// On mine I placed a text file named text.txt to test reading.
// This sketch does not explore limits or modes of speed.
// Connections are all by direct female to male jumper wires
// No other hardware than SD Module with card, UNO and jumpers
// SD Module pin --- UNO pin
// 5V --- 5V
// 3.3V --- 3.3V
// GND --- GND
// GND --- GND
// CS --- 10
// MOSI --- 11
// MISO --- 12
// SCK --- 13
#include <SD.h>
#include <SPI.h>
byte state = 0; // controls what operation is run
byte flag = 0;  // general use True/False
byte B;         // single byte buffer
char fname[ 12 ] = "text.txt";
File sdfile;    // File object
void setup(void)
  Serial.begin( 9600 );
  // This code grew by Steps. The start was only First Step.
  // First Step, if you haved wired correctly and have SD then success
  byte f = SD.begin( 10 ); // test if card is recognized
  Serial.println( f, DEC ); // show success as 1, fail as 0
  if ( !f ) while( 1 );    // if fail then sketch ends
  // Second Step for me was to read a file name pre-placed on the card
  f = SD.exists( fname );  // test if file text.txt is present
  //  if ( !f ) while( 1 );
  Serial.println( "\nTime to do the data things.\n"  );
// Next Four Steps, 1 each state case
void loop(void)
  switch( state )
  case 0 : // open text.txt for read if possible
      sdfile = SD.open( fname, FILE_READ ); // try to open text.txt
      if ( !sdfile ) // if test.txt not found, notify and change state
        Serial.print( "Unable to open for read: " );
        Serial.println( fname );
        //        while( 1 );
        state = 2;
        state = 1; // text.txt found, change to state 1
  case 1 : // read text.txt and print contents
      if ( sdfile.available())
        B = sdfile.read();
        Serial.print( B );
      else // once data is read, close file and change state
        sdfile.close();
        //        while( 1 );
        state = 2;
  case 2 : // now try to open/create test.txt for append/write
      strcpy( fname, "test.txt" );
      sdfile = SD.open( fname, FILE_WRITE );
      if ( !sdfile )
        Serial.print( "Unable to open for write: " );
        while( 1 ); // sketch stops if reach here
      state = 3;
  case 3 : // test.txt opened for append or created for write
      for ( byte i = 'a'; i <= 'z'; i++ ) // append lowercase alphas
        sdfile.print( i );    // append == add to end of what is there
        Serial.print( i );    // this file grows with each new run
      Serial.println( "\nOver-write start of file: " );
      sdfile.seek( 0 ); // test ability to set write pointer
      // unlike some seek() functions, this one starts at 0 instead of 1
      // write over a-j with 0-9
      for ( byte i = '0'; i <= '9'; i++ )
        sdfile.print( i );
        Serial.print( i );
      Serial.println( "\nand that's all she wrote, goodbye!" );
      sdfile.close();
      while( 1 ); // sketch stops here
Logged
I find it harder to express logic in English than in Code.
Sometimes an example says more than many times as many words.
SE USA
Online Online
Faraday Member
@ssh0le
View Profile
yea that IC is a level shifter =)
whats the number on the chip? I bet its a 4050, or a 245
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
What chip? I have 3 for close inspection... that's the LM1117.
I see a regulator where power goes in, 4 10 uF caps, 4 10k resistors and the SD holder.
There's a board under those, the only chip is in the UNO.
BTW, I have read the how and why smaller SD cards write quicker. 128M is better than 512M, etc.
« Last Edit: November 29, 2012, 01:18:49 am by GoForSmoke » Logged
SE USA
Online Online
Faraday Member
@ssh0le
View Profile
on the link you posted there is a 6 pin SOIC on the SD breakout board
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
I think you mistake the regulator, an LM1117 which has 3 pins on one side.
BTW, I have asked the company for prices on 1 - 20 of several other items to see how this shapes out. Some of those are strictly 3.3V and they're all interesting.
« Last Edit: November 29, 2012, 01:26:23 am by GoForSmoke » Logged
Pages: [1]   Go Up
Jump to:
