Loading...
Pages: [1]   Go Down
Author Topic: Suggestion for audio shield/alternative board for percussion musical instrument  (Read 1194 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I am looking for suggestions for an audio shield/alternative board for a simple percussion musical instrument I am designing. There will be 30 or so isolated piezo sensors to detect knocks/strikes. I am thinking of using a Mux shield (http://mayhewlabs.com/products/arduino-mux-shield) to handle all the inputs, and I want to trigger samples (velocity sensitive) through an audio shield with an output 3.5mm jack where I can connect speakers or headphones. Any suggestions for this functionality will be appreciated.
Thanks,
Umesh
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
The problem here is getting 30 different percussive sounds out of an arduino. Without resorting to a wave shield I am not sure how you will do this.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Definitely a shield has to be used. Any suggestions for a good shield that will fit my requirements?
Logged
Offline Offline
Brattain Member
View Profile
WWW
This one:-
http://www.ladyada.net/make/waveshield/
I have one myself and it is good.
However, it is like all the other wave shields for the arduino monophonic?
Does that fit what you want to do?
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Why not using servos to really play some percussion instruments ...
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Sr. Member
View Profile
Maybe you could have the main (Master) Arduino processor connected to a load of AtTiny (Slave) chips each producing a different sound?
I`m not sure that there`s one chip that can produce thirty different sounds.
Logged
Offline Offline
Newbie
View Profile
I don't think you need to play 30 different sounds at once, unless you have 30 hands to play 30 different percussion pads!
I'm assuming you can play 2 sounds =2 hands at once.
You should additionally consider that when you hit a percussion the sound could overlap the tail of the sample that is currently played (if any).
I never wrotecode for DSPs, but that's probably what you need to do.
And this board could be the right one: http://www.openmusiclabs.com/2011/08/arduino-audio-codec-shield/
If you write good code, please share.
I'm building a drum kit that I will connect via MIDI to a PC for the generation of sounds.
If you find a good solution, my drum kit could become a stand alone device!
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
But the price:-
Quote
At only $44,
For that money go on ebay and get a MIDI sound module, that will give you all the sounds you want.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks, I'll check it out the board. I am looking for a standalone solution rather than the ability to connect to an external MIDI module or computer so that the instrument would be self contained with all sounds stored on board.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Fine, you do know it is a DSP not a generator so it will not synthesise sounds. Then it will only process them one sound at a time so are you going to have 32 of them?
Quote
I think you are missing the point. What ever you do you will have to build into your instrument a sound generating board. It can be quick and easy like MIDI or is can be difficult and expensive, like anything else. At the end of the day either way you end up with a box that sound comes out of.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I have a set of pre-recorded sound samples that I am using. The way I see it, there is a difference between a controller and and a "stand alone" instrument. Using protocols such as MIDI and OSC, data can be sent out of a controller which will leave the actual playing of the sounds to another device (computer, sound module etc.). Conversely, the sound generation could be done using on-board electronics and all a user has to do is connect an audio jack to speakers. It is like the difference between a MIDI controller and a regular electronic keyboard. Of course, you can do both in one instrument.
I am looking for a low cost way of doing an electronic instrument where you can just plug in speakers. For example, I found the Rugged Audio Shield (http://ruggedcircuits.com/html/rugged_audio_shield.html), but unfortunately there aren't any available at the moment. So I am trying to find other options that will do the job.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Very nice, however I see nothing to suggest it is polyphonic.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Good point. I am thinking that it might be easier to look at developing the controller version first (to trial the idea) before looking at the full fledged instrument design.
Logged
Pages: [1]   Go Up
Print
Jump to:
