I have an issue though, I have read (after paying for it and having it arrive) that i cannot simple use the Outputs on the Arduino to control it as it requires a Voltage input from 0-5V, and the Arduino that i have only does PWM and does not output the Analog voltage i require.
Can anyone help me with how to get my Arduino to talk to the Saber-tooth so i will be able to move my nice new motors.
If its a hassle and not worth it, is there any other Driver's that will power my 2 motors (2 x 5A) using PWM Input?
So i managed to get the robot built, and the servo functions working.
Unfortunately i cannot seem to find a way to code it to do the following:
Drive at a speed of 120 for 2 seconds
Stop
Wait for 2 seconds
Reverse at a speed of 60 for 1 second
I can get it to go forward and back but i cannot get it to drive for a set period of time.
is this an issue with using PWM? I did try using serial packets but it failed
anyone got any idea?
Here is my code
#include <Servo.h>
Servo motorR;
Servo motorL;
int speedo;
 motorR.attach(9);
 motorL.attach(10);
void drive(int speedo)
 motorR.write(speedo);
 motorL.write(speedo);
 return;
void left()
 motorR.write(120);
 motorL.write(60);
void right()
 motorR.write(60);
 motorL.write(120);
void STOP()
 motorR.write(90);
 motorL.write(90);
 return;
drive(1200);
delay(2000);
drive(1800);
//right();
//drive(105);
//left();
I am a beginner with Sabertooth and Arduino Uno Circuit.
I am having a tough time getting started and this seems kind of complex, nothing I have tried from Sabertooth and Arduino library has worked I did upload the blink test and that worked between the computer and the UNO but other than that I feel stuck.
We are running a Sabertooth 2x25 with Arduino Uno Board.
Our system is operated with a remote controller currently and we wanted to add the functionality option of autonomous.
So what we are trying to do is drive our system with remote control to a given location and then start the program.
Right now I have not even got the UNO circuit to even control the motors yet.
Can anyone help?
I uploaded programs but all seem to error out one way or the other.
Has anyone have the programs and code that works for the Saber tooth - UNO intergration?
Thanks I appreciate any help I can get!
