Author Topic: Simple Colour Change Lamp  (Read 876 times)
Norfolk UK
Just for the fun of it I made a very simple colour change/mood lamp.
It uses a single 10W RGB LED like this http://www.ebay.co.uk/itm/10W-Watt-RGB-Red-Green-Blue-HIGH-POWER-LED-Light-Lamp-DIY-UK-STOCK-/271028515764?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item3f1a8ef3b4
attached to a heatsink http://www.ebay.co.uk/itm/10W-LED-Aluminum-Heat-Sink-Heatsink-110x18mm-UK-Stock-/280935964629?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item4169169fd5
I built a triple constant current power supply to power the RGB LED and a ATtiny85. I bought a cheap  lamp from Lidl and removed it's wiring and lamp and replaced with the LED. It's powered of a 12V wall wart. I may add a IR led in the future and make it remote control the colour & intensity.
Attached are a couple of pictures, the schematic & the sketch.
Norfolk UK
The obligatory videos...
Testing the LED and constant current PSU
The money shot
Valencia, Spain
Online Online
Nice LED. I might have to get a couple!
One thing...do the MOSFETS/resistors in the power supply get very hot?
2W seems a little on the low side for the resistors. I'm thinking the resistors in the photos are more than 2W.
« Last Edit: November 29, 2012, 04:33:33 pm by fungus » Logged
Norfolk UK
I'm certainly impressed with it. Might be tempted to try this http://www.ebay.co.uk/itm/30W-30-Watt-High-Power-RGB-Full-Color-Rainbow-LED-Light-DIY-/230767996419?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item35bad82e03 next time.
Red MOSFET gets warm enough for a heatsink due to greater voltage drop but blue and green hardly get warm at all though I have put heatsinks on all of them as the electronics are in a plastic box with little air flow and will be on for hours at a time.
Without ordering online and paying P&P I could not get a small 2W 2.2ohm resistor so got the 3W wirewound ones from Maplin
The details on the constant current driver circuit came from here http://laserpointerforums.com/f51/simple-linear-mosfet-dimming-circuit-pwm-70812.html
What is the difference between the circuit you linked and this one?: http://www.tbideas.com/blog/build-an-arduino-shield-to-drive-high-power-rgb-led/
Yours has extra parts for beeing PWM friendly as it says on the page, but I really don't understand the explanation.
I did mine and I noticed that when PWM level is low the led blinks a little, I really don't know if it will bother with the other colors turned on, need to test that.
Do you think adding those extra parts will solve that?
Thanks
Norfolk UK
Apart from using different MOSFET and resistor values the circuits are the same, the schematic I attached to the first post has 3x of these circuits to separately drive the RGB colours in the LED it also has a voltage regulator to give a 5V supply for the ATtiny85 that does the PWM colour changes.
I use no extra parts to make the thing more "PWM friendly". I don't notice any flicker at low levels but that might be because at lease one other colour is always bright so may mask the flicker effect.
See above
I mean the shaded parts, it says on the webpage that those parts are for "adding PWM input support", I built it without those parts and still works (even if it blinks a little when PWM is low)
Norfolk UK
When I look at your linked page I only see the below schematic.
It also works for me without the extra circuit bits, I also removed R1 from my version. Maybe that's the cause of your flicker.
« Last Edit: May 05, 2013, 11:11:05 am by Riva » Logged
