Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Questions on making a minimal/custom Arduino circuit @ 3.3v/8Mhz?  (Read 1204 times)
0
Offline Offline
God Member
Arduino rocks
View Profile
Hi Robert-
outside of some I/O pins for some basic smd leds......and some buttons input to make those leds do something..... I dont think any (but I'll have to review to be sure)  smiley
your schematic looks similar to mine  (I'll post when I get to work)..
but mine is missing the cap on the SD socket.. and I didnt do anything with AREF yet.. just using a cap and tying to GND is ok?
(I dont need to tie that to any voltage reference point?  (ie: the 3.3v line at all?)
Lastly...  (caps).. still a bit confused on these..
from the schematic,...it looks like ALL the caps used are polarized ones??  (or am I reading the symbol wrong?.. I dont see any +/- on the cap symbols anywhere?)
I thought the CAPACITOR symbol that had two STRAIGHT lines.. meant a regular old cap.. and a CAPACTOR symbol that had  stiaght line and 1 rounded line.. was signifying a POLARIZED cap?
is this true? (or am I under the wrong impression?)
in this case.. then ALL caps used her should be polarized?
thanks!..
Oh and Robert.. the pcb design/layout is appreciated.. but when I show you the space and size (shape) of the PCB.. you'll probably just laugh at me!  lol
thanks again!
we'll post when I get to work..and open things up again.
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
Despite what the symbol is, caps less than 1 uF are typically unpolarized, and >= 1 uF
are typically polarized.
« Last Edit: November 30, 2012, 06:52:14 pm by oric_dan(333) » Logged
Something different - Kitchen-Sink Arduino-compatible boards
Offline Offline
Edison Member
View Profile
Quote
what IS the minimal (but still somewhat stable/safe) components needed?
A minimum implementation would include just the chip itself.
A reasonable minimum implementation would have a decoupling cap, a crystal + two caps, or a decoupling network on the analog supply. And then more from there, based on your needs.
I have done many "chip-only" minimum implementations myself.
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
hi..
thanks for the reply..
this can not (should not) be a chip by itself project... IMHO..
I mean I need it to be small.. but I want it to work and be somewhat stable!  lol
Since it will be running @ 3.3v & INTERNAL 8Mhz clock...  I dont need the caps/crystal.......correct?
RESET pin broken out (for easier flashing/uploading)
DTR pin broken out (for easier flashing/uploading)
AREF pin (correctly set-up... I see in the schematic Crossroads posted.. he has the AREF pin connected to GND through a cap... but I do NOT need to connect to the 3.3v for a voltage refeence?  Just keep it INTENRAL reference at the 1.1v or whatever?)
and of course I want to ensure that I 'correctly' set-up the battery/power input..
since there will NOT be any voltage regulator (battery supply will be within the 3-3.7v range max).. but I want it to be stable..no ripples.
follow same principles or ceramic/polarized cap on the input power lines?
@ oric_dan(333)
Quote
thanks!.. rules like this help a noob like me.
I am still wrestling with 'decoupling'.. and 'KNOWING' when to use a certain component or not (like when to use ceramic vs polarized..etc)
hopefully I can get to a more final version tonight/tomorrow.. and I'll post for review..
appreciate all the discussion guys!
thanks!  smiley
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
The little ceramic decoupling caps are not polarized.  Example:
http://www.digikey.com/product-detail/en/C0805C104K4RACTU/399-1167-1-ND/411442
Rule of thumb/general guidance: 0.1uF cap on every Vcc/Avcc pin on every part located as nearby as possible.
Aref - needs a 0.1uF cap to Gnd if you are using the internal references
See 2.2:
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
Quote
Lithium coin cells are usually 3.6 volts, not 3.0.
that's wrong.   You can find Li-ion coin cells with a "nominal" 3.6V or 3.7V, but the vast majority of non-rechargable Li coin cells are 3.0V  http://www.duracell.com/media/en-US/pdf/gtcl/Product_Data_Sheet/NA_DATASHEETS/CR2032_US.pdf
Logged
Offline Offline
Edison Member
View Profile
Quote
The chip-only implement will work and will be very stable.
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
update: well..  i got things up and running with a minimal/breadboard Arduino using +3.3v @ 8MHz internal clock
to be clear order of things (for me) were:
1.) hook up my Arduino Duemilanove 2009 board to USB
2.) Open IDE (I used v.23)
3.) Tools >>> Board >> (Duemilanove 2009)
4.) Tools >>> Serial Port  (select port your above Arduino is connected to)
5.) File >>> Examples >>> ArduinoISP..  (upload this sketch to your Arduino board.
6.) Disconnect.. from USB
7.) Connect a 100-120 ohm resistor between RESET & +5v (to disable auto-reset on the MAIN board)
8.) Connect your target board (minimal +3.3v/8Mhz internal clock) to the MAIN Arduino above.
Wiring Pnout:
Arduino board pin   >>>  Target board pin
               D10       >>>>           RESET
               D11       >>>>           D11
               D12       >>>>           D12
               D13       >>>>           D13
               GND      >>>>           GND
               +3.3v     >>>>           VIN on breadboard...
9.) Reconnect MAIN Arduino board to USB.
10.) Open IDE (I used v.23)
11.) Tools >>> Board >> (Breadboard 3.3v with Internal 8MHz clock)
12.) Tools >>> Serial Port  (select port your above Arduino is connected to)
13.) Tools >>> Burn Bootloader >> w/Arduino as ISP
(bootloaded and can upload sketches all day...)..
two things I noticed though...
1.) Does NOT work with Aruino IDE 1.0+ out of the box...not sure exactly how to make it work yet either.
From reading around, it seems to have something to do with:
a.) editing/adding pin_arduino.h or Arduino.h files to somewhere.
b.) edit the breadboard  'boards.txt' file.. and add a line at the end?
(not to sure.. a bit above my comfort level messign with boards.txt and stuff)
this is just specific to my project.. not about the minimal Arduino part..
2.) and the MAIN problem I need to overcome..   I cant seem to communicate/initialize an SD card???
Using an Arduino @ 16MHz (external crystal) & +5v... I have never had a problem.. with voltage divider or level shifter..or shield...
having the Arduino with +3.3v logic and INTENRAL 8MHz clock doesnt seem to work.. and I 'thought' I would be able to directly connect/communicate to it? (no voltage divider, no level shifter..etc)
been searching around.. and havent found much on using 3.3v8MHz internal clock -with- SD card..
anyone done this? (so I know Im not spinning my wheels?)
« Last Edit: January 11, 2013, 03:41:53 pm by xl97 » Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Lets see the schematic you said you'd post back in #15 & #18, and your sketch.
How'd you bootload it?
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
(sorry thought I had posted it)..
I ran into this post while searching here on the topic.. and just updated the outcome..
I started a thread about 3.3v/8MHz Internal clock and SD card communication thread here:
http://arduino.cc/forum/index.php/topic,140732.msg1065311.html#msg1065311
I have that circuit mocked-up on a breadboard right now.. before I order PCBs and make it all SMD..
this is the SAME project.. that we discussed via PM.. (ultra tiny pcb with zero space to work with & custom pcb shape/outline)
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
The last post in the other thread, you say  SD PIN        >>>     Arduino
DAT2(9)        >>>      NOT USED
CD/CS (1)      >>>     D10
CMD/DI(2)     >>>      D11
VSS1/GND(3)  >>>     GND rail
VDD/V++(4)    >>>     +3.3v rail
CLK/SCK(5)    >>>     D12
VSS2/GND(6)  >>>     GND rail
DAT0/DO(7)   >>>     D13
DAT1(        >>>     NOT USED
These are not the correct pins for SPI:
D13 - SCK
D12 - MISO
D11 - MOSI
D10 - SS
What is really connected?
Are you really running from coin cell? May not have enoughcurrent oomph for the SD card.
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
(not sure if I should post here or there) hahah
hmm.. (Im hoping I just fat finger the pinout!)...
but I thought that was how I had it wired it up:
CD/CS (1)      >>>     D10
CMD/DI(2)     >>>      D11
CLK/SCK(5)    >>>     D12
DAT0/DO(7)   >>>     D13
DAT1(smiley-cool        >>>     NOT USED
I'll have to check when I get home...  looks like I have D12 and D13 switched??
Logged
Australia
Offline Offline
Sr. Member
Arduino rocks
View Profile
This tutorial has some interesting tips on power saving a minimalist board.
http://www.sparkfun.com/tutorials/309
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
Well I checked it out.. looks like I only typed it wrong..
this is what I have:
CD/CS (1)      >>>     D10
CMD/DI(2)     >>>      D11
CLK/SCK(5)    >>>     D13
DAT0/DO(7)   >>>     D12
DAT1(8 )       >>>     NOT USED
so.. whilke I had typed it with D12 and D13 switched.. checking the wiring.. it was NOT as originally posted..
the above is how it 'is' currently wired.
I can upload any sketch.. but anything that uses the SD card 'fails'..
SD lib >>>  Files Sketch:
Initializing SD card...initialization failed!
SdFat lib >>> SdInfo:
SdFat version: 20110902
type any character to start
card.init failed
SD errorCode: 0X1
SD errorData: 0X0
Im not sure where to start troubleshooting?
* Im not sure if this is/could be a boards.txt problem? (a tweak to a fuse setting because the timing is off or something 'odd'?
* Im not sure if I just need to add a cap/resistor somewhere that I missed? (everything is direct connect except for the cap on the VDD/VSS lines of the SD lines)
* Maybe not even possible to do this with 8MHz internal clock @ 3.3v?
Gotta be something silly Im doing on my end..??
heres the schematic:
thanks!
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
also to answer you Crossroads.
I am using a PSU..
but I have powered/tried it from being powered form the FTDi cable (+5v)..
I have tried from PSU @ +3.3v...
I have 'not' tired the coin cell that I plan on using in the end..(yet).. no point in trying it yet..lol
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
