Topic: Questions on making a minimal/custom Arduino circuit @ 3.3v/8Mhz? (Read 9451 times) previous topic - next topic
xl97
Hi Robert-
outside of some I/O pins for some basic smd leds......and some buttons input to make those leds do something..... I dont think any (but I'll have to review to be sure)  :)
your schematic looks similar to mine  (I'll post when I get to work)..
but mine is missing the cap on the SD socket.. and I didnt do anything with AREF yet.. just using a cap and tying to GND is ok?
(I dont need to tie that to any voltage reference point?  (ie: the 3.3v line at all?)
Lastly...  (caps).. still a bit confused on these..
from the schematic,...it looks like ALL the caps used are polarized ones??  (or am I reading the symbol wrong?.. I dont see any +/- on the cap symbols anywhere?)
I thought the CAPACITOR symbol that had two STRAIGHT lines.. meant a regular old cap.. and a CAPACTOR symbol that had  stiaght line and 1 rounded line.. was signifying a POLARIZED cap?
is this true? (or am I under the wrong impression?)
in this case.. then ALL caps used her should be polarized?
thanks!..
Oh and Robert.. the pcb design/layout is appreciated.. but when I show you the space and size (shape) of the PCB.. you'll probably just laugh at me!  lol
thanks again!
we'll post when I get to work..and open things up again.
oric_dan
#16
Nov 30, 2012, 08:39 pm Last Edit: Dec 01, 2012, 12:52 am by oric_dan(333) Reason: 1
Despite what the symbol is, caps less than 1 uF are typically unpolarized, and >= 1 uF
are typically polarized.
dhenry
what IS the minimal (but still somewhat stable/safe) components needed?
A minimum implementation would include just the chip itself.
A reasonable minimum implementation would have a decoupling cap, a crystal + two caps, or a decoupling network on the analog supply. And then more from there, based on your needs.
I have done many "chip-only" minimum implementations myself.
xl97
hi..
thanks for the reply..
this can not (should not) be a chip by itself project... IMHO..
I mean I need it to be small.. but I want it to work and be somewhat stable!  lol
Since it will be running @ 3.3v & INTERNAL 8Mhz clock...  I dont need the caps/crystal.......correct?
RESET pin broken out (for easier flashing/uploading)
DTR pin broken out (for easier flashing/uploading)
AREF pin (correctly set-up... I see in the schematic Crossroads posted.. he has the AREF pin connected to GND through a cap... but I do NOT need to connect to the 3.3v for a voltage refeence?  Just keep it INTENRAL reference at the 1.1v or whatever?)
and of course I want to ensure that I 'correctly' set-up the battery/power input..
since there will NOT be any voltage regulator (battery supply will be within the 3-3.7v range max).. but I want it to be stable..no ripples.
follow same principles or ceramic/polarized cap on the input power lines?
@ oric_dan(333)
thanks!.. rules like this help a noob like me.
I am still wrestling with 'decoupling'.. and 'KNOWING' when to use a certain component or not (like when to use ceramic vs polarized..etc)
hopefully I can get to a more final version tonight/tomorrow.. and I'll post for review..
appreciate all the discussion guys!
thanks!  :)
CrossRoads
The little ceramic decoupling caps are not polarized.  Example:
http://www.digikey.com/product-detail/en/C0805C104K4RACTU/399-1167-1-ND/411442
Rule of thumb/general guidance: 0.1uF cap on every Vcc/Avcc pin on every part located as nearby as possible.
Aref - needs a 0.1uF cap to Gnd if you are using the internal references
See 2.2:
westfw
Lithium coin cells are usually 3.6 volts, not 3.0.
that's wrong.   You can find Li-ion coin cells with a "nominal" 3.6V or 3.7V, but the vast majority of non-rechargable Li coin cells are 3.0V  http://www.duracell.com/media/en-US/pdf/gtcl/Product_Data_Sheet/NA_DATASHEETS/CR2032_US.pdf
dhenry
The chip-only implement will work and will be very stable.
xl97
update: well..  i got things up and running with a minimal/breadboard Arduino using +3.3v @ 8MHz internal clock
to be clear order of things (for me) were:
1.) hook up my Arduino Duemilanove 2009 board to USB
2.) Open IDE (I used v.23)
3.) Tools >>> Board >> (Duemilanove 2009)
4.) Tools >>> Serial Port  (select port your above Arduino is connected to)
5.) File >>> Examples >>> ArduinoISP..  (upload this sketch to your Arduino board.
6.) Disconnect.. from USB
7.) Connect a 100-120 ohm resistor between RESET & +5v (to disable auto-reset on the MAIN board)
8.) Connect your target board (minimal +3.3v/8Mhz internal clock) to the MAIN Arduino above.
Wiring Pnout:
Arduino board pin   >>>  Target board pin
               D10       >>>>           RESET
               D11       >>>>           D11
               D12       >>>>           D12
               D13       >>>>           D13
               GND      >>>>           GND
               +3.3v     >>>>           VIN on breadboard...
9.) Reconnect MAIN Arduino board to USB.
10.) Open IDE (I used v.23)
11.) Tools >>> Board >> (Breadboard 3.3v with Internal 8MHz clock)
12.) Tools >>> Serial Port  (select port your above Arduino is connected to)
13.) Tools >>> Burn Bootloader >> w/Arduino as ISP
(bootloaded and can upload sketches all day...)..
two things I noticed though...
1.) Does NOT work with Aruino IDE 1.0+ out of the box...not sure exactly how to make it work yet either.
From reading around, it seems to have something to do with:
a.) editing/adding pin_arduino.h or Arduino.h files to somewhere.
b.) edit the breadboard  'boards.txt' file.. and add a line at the end?
(not to sure.. a bit above my comfort level messign with boards.txt and stuff)
this is just specific to my project.. not about the minimal Arduino part..
2.) and the MAIN problem I need to overcome..   I cant seem to communicate/initialize an SD card???
Using an Arduino @ 16MHz (external crystal) & +5v... I have never had a problem.. with voltage divider or level shifter..or shield...
having the Arduino with +3.3v logic and INTENRAL 8MHz clock doesnt seem to work.. and I 'thought' I would be able to directly connect/communicate to it? (no voltage divider, no level shifter..etc)
been searching around.. and havent found much on using 3.3v8MHz internal clock -with- SD card..
anyone done this? (so I know Im not spinning my wheels?)
CrossRoads
Lets see the schematic you said you'd post back in #15 & #18, and your sketch.
How'd you bootload it?
xl97
(sorry thought I had posted it)..
I ran into this post while searching here on the topic.. and just updated the outcome..
I started a thread about 3.3v/8MHz Internal clock and SD card communication thread here:
http://arduino.cc/forum/index.php/topic,140732.msg1065311.html#msg1065311
I have that circuit mocked-up on a breadboard right now.. before I order PCBs and make it all SMD..
this is the SAME project.. that we discussed via PM.. (ultra tiny pcb with zero space to work with & custom pcb shape/outline)
CrossRoads
The last post in the other thread, you say  SD PIN        >>>     Arduino
DAT2(9)        >>>      NOT USED
CD/CS (1)      >>>     D10
CMD/DI(2)     >>>      D11
VSS1/GND(3)  >>>     GND rail
VDD/V++(4)    >>>     +3.3v rail
CLK/SCK(5)    >>>     D12
VSS2/GND(6)  >>>     GND rail
DAT0/DO(7)   >>>     D13
DAT1(        >>>     NOT USED
These are not the correct pins for SPI:
D13 - SCK
D12 - MISO
D11 - MOSI
D10 - SS
What is really connected?
Are you really running from coin cell? May not have enoughcurrent oomph for the SD card.
xl97
(not sure if I should post here or there) hahah
hmm.. (Im hoping I just fat finger the pinout!)...
but I thought that was how I had it wired it up:
CD/CS (1)      >>>     D10
CMD/DI(2)     >>>      D11
CLK/SCK(5)    >>>     D12
DAT0/DO(7)   >>>     D13
DAT1(8)        >>>     NOT USED
I'll have to check when I get home...  looks like I have D12 and D13 switched??
lemming
This tutorial has some interesting tips on power saving a minimalist board.
http://www.sparkfun.com/tutorials/309
xl97
Well I checked it out.. looks like I only typed it wrong..
this is what I have:
CD/CS (1)      >>>     D10
CMD/DI(2)     >>>      D11
CLK/SCK(5)    >>>     D13
DAT0/DO(7)   >>>     D12
DAT1(8 )       >>>     NOT USED
so.. whilke I had typed it with D12 and D13 switched.. checking the wiring.. it was NOT as originally posted..
the above is how it 'is' currently wired.
I can upload any sketch.. but anything that uses the SD card 'fails'..
SD lib >>>  Files Sketch:
Initializing SD card...initialization failed!
SdFat lib >>> SdInfo:
SdFat version: 20110902
type any character to start
card.init failed
SD errorCode: 0X1
SD errorData: 0X0
Im not sure where to start troubleshooting?
* Im not sure if this is/could be a boards.txt problem? (a tweak to a fuse setting because the timing is off or something 'odd'?
* Im not sure if I just need to add a cap/resistor somewhere that I missed? (everything is direct connect except for the cap on the VDD/VSS lines of the SD lines)
* Maybe not even possible to do this with 8MHz internal clock @ 3.3v?
Gotta be something silly Im doing on my end..??
heres the schematic:
thanks!
xl97
also to answer you Crossroads.
I am using a PSU..
but I have powered/tried it from being powered form the FTDi cable (+5v)..
I have tried from PSU @ +3.3v...
I have 'not' tired the coin cell that I plan on using in the end..(yet).. no point in trying it yet..lol
