Topic: Why's SD -> Ethernet Card -> Webbrowser so slow? (Read 13228 times) previous topic - next topic
Kong
Hello guys,
Not a real problem, but could somebody explain why data transfer is so terribly slow:
I've an Arduino Ethernet card with 8GB SD card.
This SD card contains a complete html code including several jpg's and png's files.
It's all working fine: the webbrowser gives a request, arduino delivers the html page via the SD card, the webbrowser asks for the images (as put in the html file) and Arduino sent the files.
But an image of approx. 150kB takes about 20 seconds to load, what's the bottleneck around here?
(Arduino, Wiznet 5100, SD card, libraries..)
In all my simplicity :smiley-slim: I think: 8 MHz arduino, pick a byte from SD, sent it over the internet etc., 150kB shouldn't take 20 seconds?
mohamed66
hi ,
how you make arduino open webpage on sd card having pictures and open it .. i tried to do that for 2 days and failed at the end
any help please
zoomkat
The below discussion may have some useful info and examples.
http://arduino.cc/forum/index.php/topic,144675.0.html
SurferTim
#4
Feb 18, 2013, 01:31 pm Last Edit: Feb 18, 2013, 04:09 pm by SurferTim Reason: 1
If you want to avoid the fate of the OP, then you need to send these files more than one byte per packet. If you are sending a big file, this will take relatively forever.
           while (myFile.available()) {
             client.write(myFile.read());
           // close the file:
           myFile.close();
This sends the data in 64 byte packets, rather than one byte per packet.
 Serial.println("Writing");
 byte clientBuf[64];
 int clientCount = 0;
 while(fh.available())
   clientBuf[clientCount] = fh.read();
   clientCount++;
   if(clientCount > 63)
     Serial.println("Packet");
     client.write(clientBuf,64);
     clientCount = 0;
 if(clientCount > 0) client.write(clientBuf,clientCount);
edit: If you want it to work really fast, remove or comment out the Serial.println("Packet") statement. That was just for debugging.
zoomkat
I put the below in my origional code and it reduced the upload time of a 253k jpg file from 62 sec. to 15 sec.
          if (myFile) {
            byte clientBuf[64];
            while(myFile.available())
              clientBuf[clientCount] = myFile.read();
              clientCount++;
                // Serial.println("Packet");
                clientCount = 0;
            // close the file:
            myFile.close();
SurferTim
@zoomkat: You forgot this part. Without it, it may not send the last packet. There may have been less than 64 bytes in clientBuf.
Compared to 15 seconds, 62 seconds is relatively forever.
zoomkat
Good point, I went and added it back like below. Next project is to get all the file uploading into a single function.
          if (myFile) {
            byte clientBuf[64];
              clientCount++;
                clientCount = 0;
            //final <64 byte cleanup packet
            // close the file:
            myFile.close();
blastboot
Why did you choose 64 bytes??  What is the maximum bytes per packet that ethernet shield can send??
SurferTim
The maximum is about 1400. However, you can't use a variable declaration like this.
byte outBuf[1400];
You don't have that much memory in an Uno. So I wanted to insure it might be able to run on an Uno, but also send more data than header. The header is normally 48 bytes, so I picked 64.
blastboot
it makes sense   :)  in my code i have
int16_t c;
          while ((c = file.read()) >= 0) {
client.print((char)c);
adapting it with the information you provide, is something like
byte clientBuf[64];
              clientBuf[clientCount] = file.read();
              clientCount++;
                clientCount = 0;
            // close the file:
            file.close();
is this right?
SurferTim
I didn't compile it, but that looks like it!  :)
blastboot
Thanks i'll try it because i have the same speed problem with images.
One more thing... what does this line exactly do?
SurferTim
That sends the last packet. Unless you are really lucky, your files will not be an even multiple of 64, so there may be a few bytes remaining in that buffer when the file read is finished.
