Hola, puedes probar con mi librería:
https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/Home, en la sección de download puedes bajar la última versión.
Prueba con este código:
#include <Wire.h>
#include <LCD.h>
#define I2C_ADDR 0x3F // Define I2C Address where the SainSmart LCD is
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
lcd.begin (20,4);
// Switch on the backlight
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
// Position cursor and write some text
lcd.home (); // go to the first line, first character
lcd.print("SainSmart I2C tester");
lcd.setCursor ( 0, 1 ); // go to the 2nd line
lcd.print("It's Working!");
lcd.setCursor ( 0, 2 ); // go to the third line
lcd.print("Sainsmarts docs suck");
lcd.setCursor ( 0, 3 ); // go to the fourth line
lcd.print("Nice LCD Though. ");
Por otro lado, como te comentan, necesitas conocer la dirección I2C del dispositivo, si no funciona cambia 0x3F por el valor que te de el siguiente programa:
// i2c_scanner
// This program (or code that looks like it)
// can be found in many places.
// For example on the Arduino.cc forum.
// The original author is not know.
// This sketch tests the standard 7-bit addresses
// from 0 to 127. Devices with higher bit address
// might not be seen properly.
// Adapted to be as simple as possible by Arduino.cc user Krodal
// June 2012
// Using Arduino 1.0.1
#include <Wire.h>
Wire.begin();
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 0; address <= 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(8000); // wait 8 seconds for next scan
Buena suerte.
