Topic: Noob question (Accelerameter signal manipulation) (Read 510 times) previous topic - next topic
acordell
Hi all,
   I'm new to the world of micro controllers please bare with me.
  I'm curious if the arduino is capable of manipulating an analog input signal and then outputting it.
For example, I want to use an accelerameter to weight a fluid, manipulate the signal, then output a volume to an lcd.  Can a code be written which will manipulate the input in real time?
Grumpy_Mike
#1
Nov 27, 2012, 08:48 am Last Edit: Nov 27, 2012, 09:31 am by Grumpy_Mike Reason: 1
Basically yes. It has a 10bit A/D to read analogue signals.
However most accelerometers have a digital interface fo there is no need to read it from the analogue.
Mind you, you can't weigh anything with an accelerometer.
acordell
hmmm, what about a strain gauge?  I guess i didn't really think that one through all the way...
Grumpy_Mike
Quote
Yes you can weigh stuff with a strain gauge.
