Pages: 1 [2]   Go Down
Author Topic: How to avoid floating point math  (Read 936 times)
Melbourne, Australia
Shannon Member
Lua rocks!
As long as you are trying, we'll be pleased to help.
I don't see interrupts being the issue here. You have two ISRs that you say are called every couple of seconds, so they are hardly the issue.
Then you have one which does a couple of adds. How many times a second do you expect it to be called? Let's put a metric on this.
And what data types are total_pulses, Count, tenth_gallon and running?
Shannon Member
Lua rocks!
ahem...what's a code tag?
OK, here's some boilerplate. Read it, though:
Read this before posting a programming question
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Very good questions those...
I expect no more than say, 100 pulses in a second.
total_pulses-unsigned long, Count-unsigned int, tenth_gallon- unsigned int and running-boolean.
The calculating interrupt is done every 5 seconds, so I guess that can't be such an overhead issue, right?
Shannon Member
Lua rocks!
Well out of interest, I set up a test. This code:
  total_pulses++ ;
  Count++;
  tenth_gallon++;
  running=1;
Takes about 2.8 uS to execute. So if you do 100 of them you have taken 280 microseconds. Add in the overhead of 100 interrupts, say 5 uS each, and that is another 500 uS. So in total 780 uS.
You have not even used up 1/1000 of the time you have in a second. Time to look elsewhere.
Besides, none of those are floating point variables. I thought you were worried about that?
No actually, it is this interrupt and its floating point math that I jumped to conclusions about...thoug I may simply have more dumb programming mistakes to fix instead.
void Repeats(){ //interrupt timer1 repeats every second-changed to 5 seconds...
  //here is the math...we sample every 5 seconds.  9200 counts per gallon. FIXED-use float cast to convert integers to float before calculating
  Calc = ((float)Count* ((float)720 / (float)k_factor)); //(Counts in 5 seconds/ number counts per gallon, converted from seconds to hours
  //using a large value we can select any k-factor - use counts per gallon - perfect
  // Calc is the gallons per hour.
  if (!flag){  //reset flag so running total flag is run only once
    flag=true;
  }      //this is used for averaging routine for average flow rate
  if (Count>0){
    stopped_flag++; //add 5 seconds to running time length
  if (stopped_flag>5){  //this is to delay the time till we stop and wait....
    //30 seconds or so...it decrements with no flow
    stopped_flag=5; //add 5 seconds to length of time running, up to 30 seconds
    //-each unit of increase = 5 seconds of stoppage
  if (Count==0){  //decrement once per 5 second with zero flow...
    stopped_flag--;
  if (stopped_flag<=0){
    stopped_flag=0;  // no longer running
  else {
    running=true;  //added this to ensure it stays running with flow
  Count=0;  //reset for next interrupt
  //For some reason, when we start back up from stop, we re-enter the save routine.
  if ((stopped_flag<=0) && (running) ){  //we were running, then stopped
    state=10;  //keeps returning to state 10, stop and save, and looping again
    return;
You do some programming to solve a problem, and some to solve it in a particular language. (CC2)
Alarm.timerRepeat(5,Repeats);
TimeAlarms doesn't use interrupts. So Repeats is not an ISR (Interrupt Service Routine).
Quote from http://arduino.cc/forum/index.php/topic,37693.0.html
Q: Are there any restrictions on the code in a task handler function?
A: No. The scheduler does not use interrupts so your task handling function is no different from other functions you create in your sketch.
Netherlands
just a tip: division is much slower than multiply so this code can be written as
Calc = 720.0 * Count * inverse_k_factor;
As the first value is float the whole expression is float, no need to cast. Yes you need to calculate inverse_k_factor somewhere in advance.
Rob Tillaart
Your intuition is correct. Floating point math is typically implemented via calls. When floating math is used in the isr and elsewhere in the main loop, you can get into re-entrancy -> big issues.
Sometimes 32-bit multificaton is done via calls so same issue.
You can simplify the math or to use a flag.
Shannon Member
Lua rocks!
I don't see the relevance of this. As shown, the only interrupt which is called at all frequently (100 times a second) doesn't do floating maths.
Milton Keynes UK
Isn't the floating point code reentrant, in any case? I would have assumed it was, and I can't think of any good reason for it NOT to be.
I suggest you post all of your code - or attach it, if it's too big to post. Various snippets have been posted, but the only complete copy I can see is in the first post, which is formatted horribly and probably out of date.
« Last Edit: November 30, 2012, 09:10:43 am by PeterH » Logged
Just a couple thoughts...
(1) I am both surprised and respectfully humbled by the effort you guys gave in getting me in line.
I will make the multiplication versus division changes...I do have the app working, against all odds.
It's been 2 and a half weeks of grunt work to get up to speed. Newbie efforts are expensive, time wise.
But I am building something I think my fellow pilots and I will greatly benefit from, and for that, it is worth it.
Christmas came early for a couple of my friends.  Thanks all, who assisted, I will be back soon for more advice and abuse ;-)
You guys are the absolute best.
Netherlands
Can you tell a bit more (or maybe after Christmas) ?
Rob Tillaart
Pages: 1 [2]   Go Up
